zeitgeist Skrevet 30. august 2004 Skrevet 30. august 2004 når jeg prøver å logge inn på gmailen så bare står den på "loading".vet dere hva som er galt? Dette er hva Gmail sier selv: ----------------------- There might be a number of reasons why the "Loading" screen doesn't change. Here are some potential causes and solutions: INTERNET SECURITY SOFTWARE If you are using Internet security or personal firewall software, we suggest you disable it for troubleshooting purposes. BROWSER PREFERENCES If you are using Internet Explorer, please follow these steps to reset your browser's preferences: 1. From the Tools menu at the top of your browser, select 'Internet Options' 2. From the Privacy tab, select 'Low' 3. Select 'Edit' and type 'google.com' into the 'Address of Website' field 4. Select 'Accept' to override the handling of particular cookies 5. From the Security tab, check that the setting is at 'Medium' or lower 6. Click 'OK' to accept changes CACHE Clearing a browser's cache often helps resolve Gmail log in problems. To clear your browser's cache in IE, please follow these steps: 1. Close all open browser windows, and then open a new one 2. From the Tools menu at the top of your browser, select 'Internet Options' 3. From the General tab at the top of the dialog box, select 'Temporary Internet files' > 'Delete Files' 4. Check the 'Delete all offline content' box 5. Click 'OK' and close your browser window to complete the process Finally, close your browser window, and open another to log in to Gmail. If you are able to log in to your Gmail account, you can try raising the Privacy setting to 'Low' or 'Medium.' If you continue to experience problems logging in, please let us know by clicking 'contact us' below.
Vice Skrevet 30. august 2004 Skrevet 30. august 2004 (endret) Takk for mailen Zethyr. Har fått invites på kontoen min, men linken er rød og ingenting skjer når jeg trykker på den? (Må innrømme at jeg har ikke undersøkt problemet men hvis noen her vet hva det betyr så....) Må si jeg er skuffet over at gmail også ikke fungerer med Opera Endret 30. august 2004 av Vice
Gjest Slettet-p4PIYwb6 Skrevet 30. august 2004 Skrevet 30. august 2004 Må si jeg er skuffet over at gmail også ikke fungerer med Opera Det funker vel hvis du har den nyeste versionen?
Dogagon Skrevet 30. august 2004 Skrevet 30. august 2004 Visst ingenting skjer, så er det kanskje forde du har popupkiller på!
El-Hadji Skrevet 30. august 2004 Skrevet 30. august 2004 Det står "invite 6 friends to gmail" men det går ikke an å trykke på den. Hvordan funker det? Har prøvd i både mozilla og ie, i tilleg går det ikke an å trykke på contacts.. Er det noe med min pc eller?
Vice Skrevet 30. august 2004 Skrevet 30. august 2004 Visst ingenting skjer, så er det kanskje forde du har popupkiller på! Niks, har skrudd av alt som heter popupkiller+brannmur..
Eriond Skrevet 30. august 2004 Skrevet 30. august 2004 Må nesten takke trådstarter for et utrolig godt initativ. Lurer på hvor mange vi egentlig er som har fått Gmail konto her idag
striky Skrevet 30. august 2004 Skrevet 30. august 2004 Jeg har vært på utkikk etter en Gmail-konto lenge, men har fortsatt ikke vært så heldig at jeg har blitt tildelt invite... Mottar gjerne en dersom noen er i det gavmilde hjørnet
So|o Skrevet 30. august 2004 Skrevet 30. august 2004 ...Hvordan deler man ut invites? Når du får mulighet til å dele ut invites kommer det en link når du er inne på Gmail - "invite a friend"
pretensiøselns Skrevet 30. august 2004 Skrevet 30. august 2004 (endret) Ingen som har en ekstra invite? EDIT: [email protected] Endret 30. august 2004 av eMPea
MixMaster Skrevet 30. august 2004 Skrevet 30. august 2004 ...Hvordan deler man ut invites? Når du får mulighet til å dele ut invites kommer det en link når du er inne på Gmail - "invite a friend" takk!
bitte Skrevet 30. august 2004 Skrevet 30. august 2004 Har en invite tilovers. Førstemann til innboksen min med fullt navn og epost.
Froddo Skrevet 30. august 2004 Skrevet 30. august 2004 Har to invites første to på Pm får invite fra meg.
Christian_ Skrevet 30. august 2004 Skrevet 30. august 2004 finnes det noen måte å få automatisk videresending fra hotmail til gmail?? f.eks hvis man sender til: [email protected] så kommer mailen automatisk til [email protected]?? PS! Ingen komentarer på navtet på mailen.. er ikke det jeg bruker
Froddo Skrevet 30. august 2004 Skrevet 30. august 2004 Da har jeg ikke flere. Sparkz og kjeklulf fikk mine to siste.
SweetD Skrevet 30. august 2004 Skrevet 30. august 2004 Kan man tigge? Går ned på knær og trygler om Gmail......
