"Ctrl+v"-tråden - hva ligger på klippbordet ditt?
g...............................................g
o./.....\.............\............/....\.......o
a|.......|.............\..........|......|......a
t|.......`..............|.........|.......:.....t
s`........|.............|........\|.......|.....s
e.\.......|./......./..\\\...--__.\\.......:....e
x..\......\/..._--~~..........~--__|.\.....|....x
*...\......\_-~....................~-_\....|....*
g....\_.....\........_.--------.______\|...|....g
o......\.....\______//._.___._.(_(__;..\...|....o
a.......\......C.___)..______.(_(____;..|../....a
t......./\.|...C.____)/......\.(_____;..|_/.....t
s.....././\|...C______)..()....(___;...|...\....s
e.....|...(..._C_____)\______/..//._/./.....\...e
x.....|....\..|__...\\_________//.(__/.......|..x
*....|.\....\____)...`----...--'.............|..*
g....|..\_..........___\......./_.........._/.|.g
o...|............../....|.....|..\............|.o
a...|.............|..../.......\..\...........|.a
t...|.........././....|.........|..\...........|t
s...|........././......\__/\___/....|..........|s
e..|........././........|....|.......|.........|e
x..|..........|.........|....|.......|.........|x
_____________________________________
Hi :)
'Since there are quite a bunch of oldschool synth users on this
forum I can't think of a better place to ask this..
I'm on the verge of buying another synth, I have two candidates. A
Roland Juno106, and JX-8P.
They cost exactly the same (about $500), but are in different stores
in town.
I've wanted a juno for ages, as it's a really straight forward synth
where everything is cleverly laid
out in front of you, sounds wonderful even though it's only a single
DCO + suboscillator.
Kinda the opposite of the massive Ion that I already have. Juno
would be a great learning tool and great sound..it's the real deal.
I spent an hour with it in the store today. It has no aftertouch of
velocity sens.
Then there's the other candidate. Roland JX-8P. 2xDCO's, but no
knobs on the front. Only the boring
"Edit parameter" stuff and a Data slider. Kinda cripples your
creativity when you have to wade through
parameters to edit Filter freq etc. Although they're all printed on
the front case.
so this one is basically twice the sonic power, has aftertouch
(assignable to brilliance, vibrato or volume) but was much less
commonly used. And you can detune the oscillators, which you of
course cannot on the Juno. The aftertouch was awesome, but I had to
use LOTS of force on the keys to activate it, so not exactly
practical unless I play leads with one hand.
I can't decide, go for the best interface, or the best sound? Some
say the Juno has fantastic sound, same about JX8P. it sells without
the PG-800 controller which is more or less essential. They have it
in the store, but it was reserved for someone else.
There was also a problem with the JX-8P in that it went into a kind
of crash after about 20 minutes (The display reset to show "Roland
JX-8P 12") and nothing would work, and I had to turn it off and on,
then it'd do the countdown from 12-0 (warmup?). The clerk thought it
could be the backup battery that was bad. Is something like that
easily fixed? It probably needs to be changed. Is it worth that much
hassle?
Gjest
