Hvor mye volt bør max gis til OCZ EB3700?
GRendal
hei hvor mye volt bør jeg gi den med tanke på å ikke brenne noe, samtidig som
jeg ikke ønsker å holde den på 2,8v. må vel gå ann å gi litt mer?
noen med reele kunnskaper om emnet?
edit: Hvor mye på standard og hvor mye eventuellt med OCZ Vram boostern som du får kjøpt på netshop?
Endret av GRendal
fikk svar fra OCZ:
The memory will take up to 3.4v with no problems. I do not recommend that. I
have found that 3.0v to 3.1v will give the best performance without errors.
You must have a nice 80mm fan blowing on the memory, or the voltage will
cause then to get very hot and produce errors.
Overall the EB memory responds very well to the booster. Adjust the booster
very slowly. The power smoothing circuit causes a delay in the voltage
change.
Thanks,
Andy Talamantez
Product Marketing Specialist
OCZ Technology, USA
www.ocztechnology.com
det store spørsmålet ( som jeg da sendte tilbake ofc) blir da.
kan Hovedkortet ( MSI K8N neo platinium socket 939)
levere nok volt ( det vil si 3.0 - 3.1 ) , eller MÅ jeg ha OCZ Vdimm boostern.
skal ta høyde for at de ønsker å promotere produktene sine når jeg leser svaret
Mine spørsmål:
ok, thanks. couple of more questions.
1. Will a MSI K8N-Neo platinium 54G-939 give 3.0 - 3.1 or would I need a
Vdimm booster to provide ample volt without stability issues
2. Will the Vdimm booster provide additional performance in terms of
reaching higher FSB`s?
3. How high is recommended in terms of DDR speed? 550? or would I benefit
from torturing it up to DDR 600?
greatly appreciate your help!
svar fra OCZ:
Sent : Saturday, August 28, 2004 2:31:21 AM
To : "'Axel Kobbeltvedt'" <[email protected]>
Subject : RE: OCZ for 939
| | | Inbox
HI,
The K8N Neo allows 2.85v maximum. The DDR booster will help, but I don't see
it as being tested for board compatibility. Here is our list:
http://www.ocztechnology.com/displaypage.p...obocompatibilit
y
This shows that is has been tested with good results. I would say it is safe
to try based on this.
http://www.xtremesystems.org/forums/showth...&threadid=39907
The booster providing additional voltage and smoother power should help with
overclocking the EB memory judging from my testing.
Don't get too excited about 275fsb (DDR550). With the timings that the
3700EB will run (3-3-2-10) it usually tops at 245-255fsb or so. The
bandwidth is great at these settings. You may go faster, you may get
3-2-2-10 timings, but I can't insure that as I have not used that
motherboard/CPU combination.
You will have a very nice system.
Thanks,
Imponerende av OCZ å gi så konkrete svar såpass kjapt. Som nevnt over hadde jeg også regnet med "consult you user manual" eller "please read our FAQ".
Har et sett med EB 3700 på vei i posten. Tenkte jeg skulle kjøpe dem før de forsvinner fra markedet :)
ja. men spørsmålet er om jeg trenger den Vdimm boostern.
altså, jeg må vel kunne kjøre på 3.0v med MSI K8N NEO platinium socket 939 uten den Vdimm boostern?
edit: sendte avgårde spørsmål om jeg fremdeles hadde plass til 2 rambrikker hvis jeg puttet Vdimm boostern på.
Endret av GRendal
