xbitlabs: p4 og A64 jevnsterke i Doom3
zeitgeist
The older Athlon XP CPU family cannot compete with the new Pentium 4 and Athlon 64 models anymore. In real tests we encountered situations when the fps rate got below the comfortable value of 30 with Athlon XPs. By the way, the same can be seen with Athlon 64 3000+ and 3200+ CPUs. That’s why we recommend you to use Pentium 4 models with frequencies from 3GHz up and Athlon 64 models with ratings from 3200+ up, if you want to be absolutely warranted against any accidental slowdowns.
Er vel ingen overraskelse at Athlon xp ikke holder følge med nyere P4 og amd64, og faktum er at om du har en cpu på 3ghz (eller 3000+ rating) er umulig å merke faktisk forskjell i spillet. (Er kun en ego/mental ting.. aka amd er bedre enn Intel osv.. fiksjon i hode ditt.)
