Andre88no Skrevet 26. august 2004 Forfatter Rapporter Del Skrevet 26. august 2004 Pipene du hører er signaler om hva som er feil. på MSI Computer fant jeg følgende : No Post - Diagnostic codes Verify POST beep codes Continues beeps or 1long 2short beeps = possible memory error • Try re-seating memory or test with different memory 1long 2short or 8short beeps = possible video card problem • Try re-seating video card, test system with known good video card High/Low tone (siren sound)= CPU is overheating. • Verify that CPU heatsink is properly installed and power connected Check diagnostic LED codes from D-Bracket Motherboards equipped with D-Bracket may provide useful diagnostic codes for common problems on the diagnostic LEDS. • Listing of diagnostic LED codes can be located in manual for your motherboard . AMI Beep Code Deep Code Description 1 short DRAMS refresh failure 2 short Parity circuit failure 3 short Base 64k RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed AWARD Beep Code Deep Code Description 1 Long, 2 Short A video error has occurred and the BIOS cannot intialize the video screen to display any additional information Any other beep(s) RAM problem Er det noen av de som virker kjent? Den lager bare lange bip, hvewrt bip vare i litt over 1 sek. Og den fortsetter hele tiden Lenke til kommentar
Andre88no Skrevet 26. august 2004 Forfatter Rapporter Del Skrevet 26. august 2004 Ikke prøv å sende i retur før du vet at det er den som bøger. Da koster det bare masse penger fordi webshopen ikke liker å bruke tid på å sjekke prosessorer som funker helt fint koster det peng for meg? Lenke til kommentar
voggers Skrevet 26. august 2004 Rapporter Del Skrevet 26. august 2004 Sitter med samme problem som topic-starter. Kjøpte nytt kabinett og ny skjerm....og plasserte alle gamle deler inn (CPU, minne, grafikk-kort). Da var plutselig pc'en ikke villig til å starte. Når jeg koblet på høytalere, fikk jeg meldingen "system failed cpu test" (har et Asus P4PE kort). Ok, tenkte jeg.....sikkert klart å ødelagt hovedkortet (selv om den klaga over feil på CPU)...og jeg kjøpte da nytt hovedkort. Dette funket heller ikke....ingen booting. Kjøpte da ny strømforsyning (NorthQ 400W) og ny CPU....fortsatt ingen booting. Nå idag kjøpte jeg nytt minne....men som vanlig, ingen booting! Kan jeg være så uheldig å ha fått enda ett ødelagt hovedkort? Noen som har noen tips.....lagt ut "fryktelig" mye penger nå.....og blir bare mer og mer oppgitt. Lenke til kommentar
Andre88no Skrevet 26. august 2004 Forfatter Rapporter Del Skrevet 26. august 2004 (endret) Jeg har nettop tatt ut alt sammen av pcen og begynnt helt fra begynnelsen igjenn. No kommer ikke pipelydene lengre men no slår hele greien seg av etter ca 5 -7 sek. Og det er fortsatt ikke liv i skjermen(den blir ståenede på standby). Noen som vet hvordan jeg blir kvitt dette da? Endret 26. august 2004 av Andre88no Lenke til kommentar
ToLi Skrevet 26. august 2004 Rapporter Del Skrevet 26. august 2004 Jeg hadde samme problemet den første gangen jeg bygde pc. Det var ikke vanskeligere enn at jeg hadde glemt og plugge inn den ene strømledningen med fire pinner på. pleier og være sort og gul de fire ledningene fra strømforskyninga. Husker ikke i farta hva denne pluggen gjør eller heter Men men... Det var nå mitt problem Lenke til kommentar
