skifte standard nettverkskort
jeg prøver å installere samba i et NT domene, prøver da å joine samba'en i domene. men når jeg kjører kommandoen "net rpc join domain -U brukernavn%'passord'" sier den bare unable to find a suitable server. grett nokk, prøver å finne feilen
prøver da emd kommandoen net rap domain, som skal liste opp domenekontrollerene i nettverket, og der får jeg bare meldingen "could not connect to server 127.0.0.1". ipadressen på eth0 er 172.16.3.39 og ipadressen til ene domene kontrolleren er 172.16.0.117. klarer fint å pinge serveren...
virker som net kommandoen prøver å koble til nettverket gjennom lo'en.
noen som kan hjelpe???
Usage:
Usage:
  net time              to view or set time information
  net lookup            to lookup host name or ip address
  net user              to manage users
  net group            to manage groups
  net groupmap          to manage group mappings
  net join              to join a domain
  net cache            to operate on cache tdb file
  net getlocalsid [NAME]        to get the SID for local name
  net setlocalsid SID  to set the local domain SID
  net changesecretpw    to change the machine password in the local secrets database only
                        this requires the -f flag as a safety barrier
  net status            Show server status
  net ads <command>    to run ADS commands
  net rap <command>    to run RAP (pre-RPC) commands
  net rpc <command>    to run RPC commands
Type "net help <option>" to get more information on that option
Valid targets: choose one (none defaults to localhost)
        -S or --server=<server>        server name
        -I or --ipaddress=<ipaddr>      address of target server
        -w or --workgroup=<wg>          target workgroup or domain
Valid miscellaneous options are:
        -p or --port=<port>            connection port on target
        -W or --myworkgroup=<wg>        client workgroup
        -d or --debuglevel=<level>      debug level (0-10)
        -n or --myname=<name>          client name
        -U or --user=<name>            user name
        -s or --configfile=<path>      pathname of smb.conf file
        -l or --long                    Display full information
        -V or --version                Print samba version information
        -P or --machine-pass            Authenticate as machine account
for den har jeg jo ikke sett før...
Hvorfor har du ikke brukt den informasjonen som jeg har uthevet i fet skrift der i kommandoen du viste oss da? Der etter at det står at hvis du ikke fyller inn den informasjonen vil den hente informasjon fra 127.0.0.1 som du hevder er akkurat det som er problemet....
problemet er at jeg har prøvd alle de forskjellige komandoene som står der uten hell...
og det er en ting til jeg er litt forundret over, det er at jeg har brukt den komandoen som jeg skriev helt først, med hell...
faktisk på samme maksin også, men bare en annen harddisk...
har lest gjennom man sidene til net komandoen, fant ikke ut så mye der heller... :(
