Får ikke Public Hubs på DC++
embark
Hei, jeg får ikke lenger opp public hubs på dc++! Jeg har prøvd å installere programmet på nytt men det gjorde ikke saken bedre. Det står "Downloading hub list" eller noe sånt når jeg trykker på Public Hubs knappen og så "Hub list downloaded", men så skjer det ingenting. Noen som vet hva problemet er?
n00b asso
n00b asso
:roll:
Primary list:
>http://www.netconnexions.co.uk/dc/publichublist.config.txt.bz2<
^^^^--- Ultimate Hub Search Engine list. Many doubles and outdated stuff. *Extremely unstable* - not recommended. (9000+ hubs)
>http://www.imperialnet.org/PublicHubList.config.bz2<
^^^^--- ImperialNet. Seem VERY unstable atm., try twice! Very strict on which chars gets through. (2500+ hubs)
>http://www.1stleg.com/PublicHubList.config<
^^^^--- Sid's. Stable, rather fast. Cool list!  (2000+ hubs)
>http://www.mds.mdh.se/~dtv01jbd/PublicHubList.config.bz2<
^^^^--- Sandos DreamLand. Stable. Extensive list.  (1100+ hubs)
>http://www.team-ppm.com/~dawson/PublicHubList.config<
^^^^--- Spykie. Stable. Extensive list.  (1100+ hubs)
>http://freespace.morat.net/WUKY/PublicHubList.config<
^^^^--- FreeSpace (Wuky?). (600+ hubs)
>http://www.neo-modus.com/PublicHubList.config<
^^^^--- The "original" Neo-Modus DC list. Stable.
>http://finhublist.no-ip.org/PublicHubList.config<
^^^^--- The Finnish Hub List. Stable, small(ish), very nice. (110+ hubs).
>http://hublist.no-ip.com/hublist<
^^^^--- The German Hublist v2. Stable, small (50+ hubs).
>http://cdinfo.org/PublicHubList.config<
^^^^--- Russian HUB's list. Stable, quite small (15+ hubs).
-----SEARCH ENGINES-----
The Ultimate Hub Search Engine: http://www.dchubs.co.uk/ (1/3/03: 10000 hubs, still needs a cleanup!!)
Use above searchengine to find your national servers too!!
Do it with brains, 4600 hubs in DB, brilliant hublist filter linksystem: http://www.dchub.org (Under development, static!)
Another under development (hopefully): http://www.clones.tk/ or http://clones.no-ip.com/hubs.htm (1/3/03: 3507 hubs, long-time static!)--------------------
Gå inn på settings i DC++ og til Downloads. Der står det nederst "Public Hub List" Så har du ei av dei adressene eg posta over og putter inn i staden for den eksisterande "Public Hubs List URL"
Endret av zeph
