Gigabyte K8VNXP + bh5/6 = 210mhz max ?
Syar-2003
Nå har jeg ikke personlig kikket i biosen til disse kortene
men stemmer dette vil jeg påstå at det ikke
kan kalles et "overclockers mobo" .
Det vil antagelig bremse andre typer minne også som må ha 2.8v for å presse
de høyeste hastighetene ut av.
Ref:
have a K8VNXP and in the bios, it reads the same. Auto is 2.5v, so you can only go to 2.7. This is a big problem for BH-6 I can only get about 208 out of my gig of Mushkin, and yes I tried with 1 stick as well. It made it to 210.
I put the same gig in my NF7-S with 2.9 v @2.96 in bios, went to 228 stable no problems. I have talked to gigabyte about the 2.7 max because even the manual that came with mobo said 2.8v max, but all the responses I get are, we are not currently supporting 2.8 vdimm. The board is made to run at 2.5 v stable, so we will NOT add the option of 2.8 vdimm.
http://www.xtremesystems.org/forums/showth...4769#post524769
