Zonealarm & smb
Når jeg har på Zonealarm får jeg ikke surfet via samba på linux-boksen min, men når jeg slår av Zonealarm funker det bra. Noen som vet hvilket program/noe jeg må endre instillingene for i Zonealarm for å få fikset dette?
En rask Google gav dette:
To all:
I have been fighting with a problem for quite sometime using Samba, a
Firewall, and Win2K boxes.  I finally found an answer to the problem and I
hope I can make some people's lives a little easier by telling everyone
about it.
Problem:
Trusted Network computers wish to talk to our webserver which is located in
our DMZ through the use of SAMBA.  Appropriate firewall rules were created
that allow only certain IPs to communicate with this one IP in the DMZ using
traditional SMB ports (137-139).  SAMBA was configured for these people and
everything else was setup appropriately.
All users could communicate fine with OS of Win95, Win98, Win NT, Linux,
Mac, and other *nixes.  Win2K would not talk to the Samba box at all.
Analysis:
After viewing the Firewall logs, it was noticed that when Win2K attempts to
establish a netbios session it sends out both a port 139 request and a port
445 request.  Port 445 is Microsoft's new implementation of "NetBios-less"
SMB traffic (or Direct hosted).  Win2K will communicate using either of
these methods depending upon which one produces a return first. (Q204279,
www.microsoft.com)
The port 139 request travelled through the firewall to the DMZ, established
a connection with the SAMBA server, and responded to the request.  The port
445 request travelled to the Firewall, failed any pass thru rules, and was
rejected as a Connection Refused message.  The refused connection always
took less time to send then the pass thru of the 139 to the SAMBA box.
Since the connection refused message was sent back to the host first, Win2K
elected to go into the Direct-Hosting mode and disregarded the port 139
traffic; thereby, creating a block of all SMB traffic between the Win2K box
and the SAMBA server.
Solution:
Create a firewall rule for port 445 that makes it look like a stealth port
to outgoing traffic.  That way NOTHING is ever broadcast back to the client
when using port 445.  With this configuration port 139 wins the election
because it has enough time to be sent back to the host computer and
establish the SMB connection.
