Raptor36 og oppstart
noClue
chkntfs /d
Chkntfs
Displays or specifies whether automatic system checking is scheduled to be run on a FAT, FAT32, or NTFS volume when the computer is started.
/d : Restores all chkntfs default settings, except the countdown time for automatic file checking. Default behavior is to check all volumes when the computer is started.
/t[:time] : Changes the Autochk.exe initiation countdown time to the specified amount of time entered in seconds. If you do not specify :time, /t displays the current countdown time.
/x volume: [...] : Excludes the specified volume from being checked when the computer starts, even if the volume is marked as requiring chkdsk.
/c volume: [...] : Schedules the specified volume to be checked when the computer starts.
/? : Displays help at the command prompt.
Sjekk også om stasjonen har fått "dirty" bittet satt :
Remarks
If a volume's dirty bit is set, this indicates that the file system may be in an inconsistent state. The dirty bit can be set because the volume is online and has outstanding changes, because changes were made to the volume and the computer shutdown before the changes were committed to disk, or because corruption was detected on the volume. If the dirty bit is set when the computer restarts, chkdsk runs to verify the consistency of the volume.
Every time Windows XP starts, Autochk.exe is called by the Kernel to scan all volumes to check if the volume dirty bit is set. If the dirty bit is set, autochk performs an immediate chkdsk /f on that volume. Chkdsk /f verifies file system integrity and attempts to fix any problems with the volume.
Examples
To query the dirty bit on drive C, type:
cmd prompt type :
fsutil dirty query C:
Sample output:
Volume C: is dirty
or
Volume C: is not dirty
Endret av syar2003
ok...da prøver jeg det ,tak for hjelpen så langt.Håper det er nok :ermm:
:w00t: det gjorde susen, chkdsk f: /r så var alt i orden tusen takk for hjelpen.
men det tok ikke så lang tid da...kun 12 minutt men så var d bare 4-5 G på den partisjonen.
igjen takk så mycket! :thumbup:
Endret av noClue
