Flere kategorier i linkesystem
Jeg har laget meg et linke-system, men jeg skulle gjerne hatt mulighet til å gi linkene flere kategorier.
Hvordan kan dette gjøres?
Her er databsestruktur og PHP-kode:
listings.php
<?php
$connection = @mysql_connect(localhost, root) or die("Umulig å
få kontakt med database");
mysql_select_db(lenker);
$linkCount = mysql_query("SELECT * FROM links WHERE category = '$_GET[catID]'");
while ($links = @mysql_fetch_array($linkCount, MYSQL_ASSOC)) {
$linkTitle = $links["linkTitle"];
$linkID = $links["linkID"];
$linkURL = $links["linkURL"];
$linkDescription = $links["linkDescription"];
$linkDate = $links["linkDate"];
///////////////////////////////Pull existing rate avg////////////////////////////////////////////
$membersrated = mysql_query("SELECT * FROM ratings WHERE linkID = '$linkID' ");
$num_rates = mysql_num_rows($membersrated);
if ($num_rates != 0){
while ($ratings = mysql_fetch_array($membersrated)){
$xrating[] = $ratings['rating'];
$total = array_sum($xrating);
unset($xrating);
$totalavg =  $total / $num_rates;
}else{
$totalavg = 0;
///////////////////////////////////get ratings////////////////////////////////////////////////////
switch ($totalavg) {
      case 0:
             $rating = "Not rated yet.";
             break;
      case (($totalavg > .09) && ($totalavg < 1.5)):
             $rating = "<img src=\"infowizards/images/1star.gif\">";
             break;
      case (($totalavg > 1.4) && ($totalavg < 2)):
             $rating = "<img src=\"infowizards/images/1_5stars.gif\">";
             break;
      case (($totalavg > 1.9) && ($totalavg < 2.5)):
             $rating = "<img src=\"infowizards/images/2stars.gif\">";
             break;
      case (($totalavg > 2.4) && ($totalavg < 3)):
             $rating = "<img src=\"infowizards/images/2_5stars.gif\">";
             break;
      case (($totalavg > 2.9) && ($totalavg < 3.5)):
             $rating = "<img src=\"infowizards/images/3stars.gif\">";
             break;
      case (($totalavg > 3.4) && ($totalavg < 4)):
             $rating = "<img src=\"infowizards/images/3_5stars.gif\">";
             break;
      case (($totalavg > 3.9) && ($totalavg < 4.5)):
             $rating = "<img src=\"infowizards/images/4stars.gif\">";
             break;
      case (($totalavg > 4.4) && ($totalavg < 5)):
             $rating = "<img src=\"infowizards/images/4_5stars.gif\">";
             break;
      case ($totalavg > 4.5):
             $rating = "<img src=\"infowizards/images/5stars.gif\">";
             break;
    default:
             $rating = "Not rated yet";
echo "<table width=\"100%\"  border=\"0\" cellspacing=\"0\" cellpadding=\"0\">
 <tr height=\"20\" valign=\"middle\">
   <td colspan=\"3\"><img src=\"infowizards/images/listingsq.gif\"> <a href=\"go.php?id=".$linkID."\"><b>$linkTitle</b></a></td>
   <td align=\"right\"><font size=\"1\">Lagt til: $linkDate</font></td>
 </tr>
 <tr>
   <td colspan=\"4\"><span class=\"dottedbottom\">$linkDescription</span></td>
 </tr>
   <td width=\"10%\"><a href=\"http://www.alexa.com/data/details?url=".$linkURL."\" target=\"_blank\"><img src=\"infowizards/images/alexa.gif\" border =\"0\" alt=\"Vis Alexa-karakter\"></a></td>
   <td width=\"35%\"><a href=\"comments.php?linkID=".$linkID."\">Kommentér lenke</a> | <a href=\"viewcomments.php?linkID=".$linkID."&page=1\">Vis kommentarer</a></td>
   <td width=\"35%\">$rating $num_rates stemme(r)</td>
   <td width=\"20%\" align=\"right\"><a href=\"#\" onclick=\"window.open('rate.php?linkID=".$linkID."', '_rate', 'HEIGHT=340,resizable=yes,scrollbars=yes,WIDTH=360');return false;\" target=\"_rate\">Stem på denne lenken</a></td>
 </tr>
</table><hr>\n";
Tabell Categories
CREATE TABLE `categories` (
 `cat_id` int(10) NOT NULL auto_increment,
 `cat_name` varchar(255) NOT NULL default '',
 `sub_id` int(10) NOT NULL default '0',
 `hit` int(10) NOT NULL default '0',
 KEY `cat_id` (`cat_id`)
) TYPE=MyISAM AUTO_INCREMENT=31;
# Dumping data for table `categories`
INSERT INTO `categories` VALUES (1, 'Nettaviser', 0, 0);
INSERT INTO `categories` VALUES (2, 'Økonomi', 1, 27);
INSERT INTO `categories` VALUES (3, 'IT', 1, 0);
INSERT INTO `categories` VALUES (4, 'Søkemotorer', 0, 0);
INSERT INTO `categories` VALUES (5, 'Kataloger', 4, 0);
INSERT INTO `categories` VALUES (6, 'Registrering', 4, 0);
INSERT INTO `categories` VALUES (7, 'Startsider', 0, 0);
INSERT INTO `categories` VALUES (8, 'Utenlandske', 7, 0);
INSERT INTO `categories` VALUES (9, 'Regionalt', 7, 0);
INSERT INTO `categories` VALUES (10, 'Rogaland', 9, 0);
INSERT INTO `categories` VALUES (11, 'Webdesign', 0, 0);
INSERT INTO `categories` VALUES (12, 'PHP', 11, 1);
INSERT INTO `categories` VALUES (13, 'CSS', 11, 0);
INSERT INTO `categories` VALUES (14, 'HTML', 11, 0);
INSERT INTO `categories` VALUES (15, 'Barn', 0, 2);
INSERT INTO `categories` VALUES (16, 'Aktiviteter på nett', 15, 1);
INSERT INTO `categories` VALUES (17, 'Eventyr', 15, 0);
INSERT INTO `categories` VALUES (18, 'Dataspill', 15, 1);
INSERT INTO `categories` VALUES (19, 'Spill', 15, 0);
INSERT INTO `categories` VALUES (20, 'Nettbutikker', 0, 6);
INSERT INTO `categories` VALUES (21, 'Data', 20, 7);
INSERT INTO `categories` VALUES (22, 'Foto', 20, 0);
INSERT INTO `categories` VALUES (23, 'Elektro', 20, 0);
INSERT INTO `categories` VALUES (24, 'Musikk', 20, 0);
INSERT INTO `categories` VALUES (25, 'Bokhandlere', 20, 0);
INSERT INTO `categories` VALUES (26, 'Auksjoner', 20, 1);
INSERT INTO `categories` VALUES (27, 'DVD og video', 20, 0);
INSERT INTO `categories` VALUES (28, 'Dataspill', 21, 0);
INSERT INTO `categories` VALUES (29, 'Utenlandske butikker', 21, 0);
INSERT INTO `categories` VALUES (30, 'Informasjonssteder', 20, 8);
Tabell links
CREATE TABLE `links` (
 `linkID` int(10) NOT NULL auto_increment,
 `linkTitle` varchar(255) NOT NULL default '',
 `linkDescription` text NOT NULL,
 `linkURL` varchar(255) NOT NULL default '',
 `linkDate` date NOT NULL default '0000-00-00',
 `category` int(10) NOT NULL default '0',
 KEY `linkID` (`linkID`)
) TYPE=MyISAM AUTO_INCREMENT=15;
# Dumping data for table `links`
INSERT INTO `links` VALUES (1, 'Dagens Næringsliv', 'En av næringslivets hovedaviser. Daglige utgivelser med unntak for søndager.', 'http://www.dn.no', '2004-08-18', 2, 2);
INSERT INTO `links` VALUES (2, 'Google', 'Verdens største og beste søkemotor, med over 4 milliarder sider.', 'http://www.google.com', '2004-08-19', 4, 0);
INSERT INTO `links` VALUES (3, 'Hardware Forum: Programmering', 'Forum for diskusjon og hjelp med HTML, CSS, ASP, PHP og andre programmeringsspråk.', 'http://forum.hardware.no/index.php?c=8', '2004-08-19', 11, 0);
INSERT INTO `links` VALUES (4, 'Norsk Webforum', 'Webutviklingsforum hvor medlemmmer med ulik erfaring diskuterer alt innen webutvikling og design.', 'http://www.norskwebforum.no', '2004-08-19', 11, 0);
INSERT INTO `links` VALUES (5, 'Nettavisen', 'Online avis med daglige nyheter. Eies av TV2.', 'http://www.nettavisen.no', '2004-08-19', 1, 0);
INSERT INTO `links` VALUES (6, 'ITavisen', ' IT-nyheter fra Norge og utlandet.', 'http://www.itavisen.no', '2004-08-19', 3, 1);
INSERT INTO `links` VALUES (7, 'Clas Ohlson', 'Alt-mulig-forretningens nettbutikk, med hele sortimentet på over 12000 produkter tilgjengelig for kjøp via nett. Katalog kan lastes ned eller bestilles.', 'http://www.clasohlson.no', '2004-08-19', 20, 0);
INSERT INTO `links` VALUES (8, 'Prisguide.no', 'Her finner du beste priser, produktinformasjon og brukeres erfaringer med de\r\nulike produktene som er lagt inn i databasen.\r\n<br><br>\r\n<form name="form1" method="post" action="http://www.prisguide.no/fritekst_sok.php">\r\n<input type="text" name="pricefind" size="18">\r\n<input type="submit" value="Søk">\r\n</form>', 'http://www.prisguide.no', '2004-08-19', 30, 1);
INSERT INTO `links` VALUES (9, 'Kelkoo', 'Hjelper Europeiske forbrukere å finne den laveste prisen på noen av de mest populære produktene fra noen av de mest populære nettbutikkene.\r\n<br><br>\r\n<form method="get" action="http://no.kelkoo.com/ctl/do/search">\r\n<input type="text" name="siteSearchQuery" size="18">\r\n<input type="submit" value="Søk">\r\n</form>', 'http://www.kelkoo.no', '2004-08-19', 30, 1);
INSERT INTO `links` VALUES (10, 'Netthandelen', 'Nettauksjon hvor man kan by på produkter i ulike kategorier. Kun forhåndsbetaling.', 'http://www.netthandelen.no', '2004-08-19', 20, 0);
INSERT INTO `links` VALUES (11, 'eBay', 'Verdens største online-auksjon med flere tusen produkter.', 'http://www.ebay.com', '2004-08-19', 20, 0);
INSERT INTO `links` VALUES (12, 'Komplett', 'Skandinavias største Internett-butikk. God service, lave priser og godt utvalg. Kun datautstyr og datamaskiner.', 'http://www.komplett.no', '2004-08-19', 21, 0);
INSERT INTO `links` VALUES (13, 'MPX', 'Nettbutikk med data- og telecomutstyr. Oversiktlig og godt utvalg.', 'http://www.mpx.no', '2004-08-19', 21, 0);
INSERT INTO `links` VALUES (14, 'Dell', 'Norsk utgave av verdens største online databutikk. Selger skreddersydde PC-er. informasjon og oversikter over produktene, bedriftsinfo og support-tjeneste.', 'http://www.dell.no', '2004-08-19', 21, 0);
EDIT: PHP-koden er nå kraftig redusert.
EDIT: Category-kode var feil. Hadde lagt ut comments-tabell.
Endret av Sonymann
Ble litt sånn forvirra av at det stod "categories", mens tabellen ikke innehold noe som lignet på kategorier så jeg improviserser litt.
Uansett, legg til 2 tabeller:
kategori: kategoriID (PK), kategorinavn
linkKategori: kategoriID (PK), linkID (PK).
'kategori' inneholder alle kategorinavnene, mens 'linkkategori' knytter en link opp mot en eller flere kategorier.
