nVidia-driveren slutett plutselig bare å virke!
La inn kernel-2.6.7-1.494.2.2, og installerte NVIDIA-Linux-x86-1.0-6111-pkg1.run nå nylig. Alt var fryd og gammen, intill Men så en dag jeg skulle spille bzflag, hadde den bestemt seg for å bruke mesa indirect insteden. Resultatet kan du gjette på selv...
nVidia-modulen er lastet, og i bruk:
[root@kyrre root]# lsmod | grep nvidia
nvidia               4823380  8
Legger ved xorg.conf for referanse:
# Xorg configuration created by system-config-display
Section "ServerLayout"
       Identifier     "single head configuration"
       Screen      0  "Screen0" 0 0
       InputDevice    "Mouse0" "CorePointer"
       InputDevice    "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
# RgbPath is the location of the RGB database.  Note, this is the name of the
# file minus the extension (like ".txt" or ".db").  There is normally
# no need to change the default.
# Multiple FontPath entries are allowed (they are concatenated together)
# By default, Red Hat 6.0 and later now use a font server independent of
# the X server to render fonts.
       RgbPath      "/usr/X11R6/lib/X11/rgb"
       FontPath     "unix/:7100"
EndSection
Section "Module"
       Load  "dbe"
       Load  "extmod"
       Load  "fbdevhw"
       Load  "glx"
       Load  "record"
       Load  "freetype"
       Load  "type1"
#       Load  "dri"
EndSection
Section "InputDevice"
# Specify which keyboard LEDs can be user-controlled (eg, with xset(1))
#       Option  "Xleds"         "1 2 3"
# To disable the XKEYBOARD extension, uncomment XkbDisable.
#       Option  "XkbDisable"
# To customise the XKB settings to suit your keyboard, modify the
# lines below (which are the defaults).  For example, for a non-U.S.
# keyboard, you will probably want to use:
#       Option  "XkbModel"      "pc102"
# If you have a US Microsoft Natural keyboard, you can use:
#       Option  "XkbModel"      "microsoft"
# Then to change the language, change the Layout setting.
# For example, a german layout can be obtained with:
#       Option  "XkbLayout"     "de"
# or:
#       Option  "XkbVariant"    "nodeadkeys"
# If you'd like to switch the positions of your capslock and
# control keys, use:
#       Option  "XkbOptions"    "ctrl:swapcaps"
# Or if you just want both to be control, use:
#       Option  "XkbOptions"    "ctrl:nocaps"
       Identifier  "Keyboard0"
       Driver      "keyboard"
       Option      "XkbModel" "pc105"
       Option      "XkbLayout" "no"
EndSection
       Identifier  "Mouse0"
       Driver      "mouse"
       Option      "Protocol" "IMPS/2"
       Option      "Device" "/dev/input/mice"
       Option      "ZAxisMapping" "4 5"
       Option      "Emulate3Buttons" "yes"
EndSection
Section "Monitor"
       Identifier   "Monitor0"
       VendorName   "Monitor Vendor"
       ModelName    "Compaq V900 Color Monitor"
       DisplaySize  350        270
       HorizSync    30.0 - 96.0
       VertRefresh  48.0 - 160.0
       Option      "dpms"
EndSection
Section "Device"
       Identifier  "Videocard0"
#       Driver      "nv"
       Driver      "nvidia"
#       Option      "IgnoreDisplayDevices" "DFP, TV"
       VendorName  "nVidia"
       BoardName   "NVIDIA GeForce 2 MX (generic)"
EndSection
Section "Screen"
       Identifier "Screen0"
       Device     "Videocard0"
       Monitor    "Monitor0"
       DefaultDepth     24
       SubSection "Display"
               Viewport   0 0
               Depth     24
               Modes    "1280x1024" "1280x960" "1152x864" "1024x768" "800x600" "640x480"
       EndSubSection
EndSection
#Section "DRI"
#       Group        0
#       Mode         0666
#EndSection
Noen som aner hva som kan være galt?
Kan høres ut som en bug, ser ikke noe feil med oppsettet ditt. Jeg kjører 2.6.3 kjernen med nvidia driver og har aldri hatt problemet. Jeg vet det ikke er noen god løsning, men har du prøvd å kjøre installasjonsscriptet til nvidia på nytt (kunne jo vært at du har oppdatert header filene eller lignende som trigger problemet).
