får ikke til å brenne cd-er...
Hei!
Jeg installerte xcdtoaster (debian), og forsøkte å brenne en cd direkte...
dette gikk ikke, så jeg søkte litt rundt på nettet i div diskusjonsgrupper + noen tutorials. Desverre er disse litt utdatert, og det er annerledes med 2.6.x-kernelen, er det ikke?
Ihvertfall så er cd-brenneren en gammel Sony CRX-120E (4x, 4x, 24x).
Jeg får ingenting fornuftig ut av loggen, men her er den i alle fall:
Calling: /usr/lib/xcdroast/bin/xcdrwrap CDRECORD dev= "ATAPI:0,0,0" gracetime=2 fs=4096k -v   speed=4 -dao -eject -pad -waiti tsize=722s -
scsidev: 'ATAPI:0,0,0'
devname: 'ATAPI'
scsibus: 0 target: 0 lun: 0
Warning: Using ATA Packet interface.
Warning: The related Linux kernel interface code seems to be unmaintained.
Warning: There is absolutely NO DMA, operations thus are slow.
SCSI buffer size: 64512
Cdrecord-Clone 2.01a34 (i686-pc-linux-gnu) Copyright (C) 1995-2004 Jörg Schilling
NOTE: this version of cdrecord is an inofficial (modified) release of cdrecord
and thus may have bugs that are not present in the original version.
Please send bug reports and support requests to <[email protected]>.
The original author should not be bothered with problems of this version.
TOC Type: 1 = CD-ROM
Waiting for data on stdin...
Using libscg version 'schily-0.8'.
atapi: 1
Device type    : Removable CD-ROM
Version        : 0
Response Format: 1
Vendor_info    : 'SONY    '
Identifikation : 'CD-RW  CRX120E  '
Revision       : '1.0j'
Device seems to be: Generic mmc CD-RW.
Using generic SCSI-3/mmc   CD-R/CD-RW driver (mmc_cdr).
Driver flags   : MMC SWABAUDIO
Supported modes: TAO PACKET SAO SAO/R96R RAW/R96R
Drive buf size : 2086656 = 2037 KB
Drive DMA Speed: 3677 kB/s 20x CD 2x DVD
FIFO size      : 4194304 = 4096 KB
Track 01: data     1 MB         padsize:   30 KB
Total size:        1 MB (00:09.82) = 737 sectors
Lout start:        1 MB (00:11/62) = 737 sectors
Current Secsize: 2048
ATIP info from disk:
Indicated writing power: 5
Reference speed: 2
Is not unrestricted
Is erasable
ATIP start of lead in:  -11625 (97:27/00)
ATIP start of lead out: 333750 (74:12/00)
1T speed low:  0 (reserved val  0) 1T speed high:  4
2T speed low:  0 (reserved val  5) 2T speed high:  0 (reserved val 10)
power mult factor: 4 6
recommended erase/write power: 3
A1 values: 02 4C B0
A2 values: 5A C8 06
Disk type:    Phase change
Manuf. index: 0
Manufacturer: Illegal Manufacturer code
Blocks total: 333750 Blocks current: 333750 Blocks remaining: 333013
RBlocks total: 336246 RBlocks current: 336246 RBlocks remaining: 335509
Starting to write CD/DVD at speed 4 in real SAO mode for single session.
Waiting for reader process to fill input buffer ...
input buffer ready.
Performing OPC...
Sending CUE sheet...
cdrecord: WARNING: Drive returns wrong startsec (0) using -150
Writing pregap for track 1 at -150
Starting new track at sector: 0
Track 01: writing  30 KB of pad data.
Track 01: Total bytes read/written: 1478656/1509376 (737 sectors).
cdrecord: Input/output error. flush cache: scsi sendcmd: no error
Writing  time:    4.999s
CDB:  35 00 00 00 00 00 00 00 00 00
Average write speed   7.4x.
status: 0x2 (CHECK CONDITION)
Total of 1 possible drive buffer underrus predicted.
Sense Bytes: 70 00 05 00 00 00 00 12 00 00 00 00 2C 00 00 00 00 00 00 00 00 00 00 00 00 00
Fixating...
Sense Key: 0x5 Illegal Request, Segment 0
Trouble flushing the cache
Sense Code: 0x2C Qual 0x00 (command sequence error) Fru 0x0
Fixating time:    0.005s
Sense flags: Blk 0 (not valid)
cmd finished after 0.002s timeout 200s
cdrecord: Input/output error. start/stop unit: scsi sendcmd: no error
CDB:  1B 00 00 00 02 00
Sense Bytes: 70 00 05 00 00 00 00 12 00 00 00 00 24 00 00 00 00 00 00 00 00 00 00 00 00 00
Sense Code: 0x24 Qual 0x00 (invalid field in cdb) Fru 0x0
cmd finished after 0.003s timeout 200s
cdrecord: Cannot eject media.
cdrecord: fifo had 24 puts and 24 gets.
cdrecord: fifo was 0 times empty and 0 times full, min fill was 100%.
Hvilke instillinger er viktige i kernelen? (2.6.7)
Noen som kan hjelpe meg med dette, evt. peke til en oppdatert tutorial/guide?
Med 2.6* kjernene bør du ikke bruke dev=ATAPI:0,0,0, men heller bare sette dev til å peke til brenner'n, for eksempel, dev=/dev/hda.
Det er mulig du må appende noe ala "hda=ide-cd" til kjernen til boot hvis det ikke virker uten. Med lilo er det bare å legge til linjen append="hda=ide-cd" i lilo.conf, for så å kjøre lilo som root.
Erstatt selvfølgelig hda med hva cd-brenner'n din er :)
Er det noe annet jeg kan forsøke før jeg legger til nevnte linjer i lilo.conf?
Kommersiell programvare(Ja, at du har "gratis" kommersiell programvare gjør det ikke bedre.
Men at du har fri/åpen kommersiell programvare (Red Hat, Sendmail, JBoss osv) gjør vel saken bedre? Hint: du mener "lukket", "ufri", "proprietær" eller lignende. :)
Endret av slime mold
Hint: piratkopiert.
meastp: Du trenger ikke kde for k3b, bare Qt.
