iCar Skrevet 19. august 2004 Forfatter Rapporter Del Skrevet 19. august 2004 Har oppgradert til R2E011 FW på min K700.Men merker fint lite til batterikapasiteten på mobilen. Batteriet er og vil uansett være dårlig på K700, dersom dem ikke lager ett større batteri til mobilen. R2E011 er den forrige versjonen, siste versjonen er R2L001 og har følegende fiks: R2L001 - 4/8/04 - One second delay before the person at the other end of the phone can hear you when answering a call bug fixed - At least 10% improvement in battery life (over and above R2E?) - Backlight timings have changed to improve battery life (20s, 26s, 40s to 15s, 20s, 60s - Fade, Backlight off, Display off) - Pressing either of the volume control buttons when in Standby mode displays the time for 3-4 seconds. - Use Now option appears when transfering pictures to the phone (previously just Ok). Options are View, Set as wallpaper, Set as screensaver, Set as starup screen, Add to contact - SE wap link removed from Application folder - Faster image browsing with selected images appearing full screen. - Improved Bluetooth stability - Bug where entering multiple names & numbers could delete the numbers for the first names entered has been fixed. - Snooze is now available on Recurrent alarms - Can now delete one contect from a group without deleting the whole group - Time of the last call now displayed in the missed calls list - The bug whereby the first call received after power up produces an "answer, reject, answer and continue" menu seems to have been fixed - The fonts of Operator logo, the command keys such as "Calls", "More" are a bit larger and the font of Date & time has been Slightly reduced. - The Globe icon that appears when using GRPS has been modified during initial connection (four silver ball circling around the globe) - Faster loading of JAVA games - Screen brightness increased - Performing a Sync does not cause the phone to reboot (some phones only?) - Playing sound and video after running Java applications now always works fine. - When in phonebook, it's now possible to change keyboard language by simply press the # key. - Transfer of files to the phone over IR or BT no longer causes the phone to output sound (some phones only!?!). - JBenchmark 1 - 2,313 - 2,326 - JBenchmark 2 - 118 - 127 - Software versions: LCD 200406041 Camera 3.9 ITP CXC 125 813 R1S or R1T - Bugs Bluetooth turns itself off if a paired bluetooth headset goes out of range. Hvilken verksted oppgraderte du fra, tror jeg venter litt til med å oppgradere sånn at de har den siste versjonen dvs R2L001. Lenke til kommentar
THacker Skrevet 19. august 2004 Rapporter Del Skrevet 19. august 2004 Me too... Mange bugs som har irritert meg som den oppdateringen fikser Lenke til kommentar
*Magnus* Skrevet 19. august 2004 Rapporter Del Skrevet 19. august 2004 Har oppgradert til R2E011 FW på min K700.Men merker fint lite til batterikapasiteten på mobilen. Batteriet er og vil uansett være dårlig på K700, dersom dem ikke lager ett større batteri til mobilen. R2E011 er den forrige versjonen, siste versjonen er R2L001 og har følegende fiks: R2L001 - 4/8/04 - One second delay before the person at the other end of the phone can hear you when answering a call bug fixed - At least 10% improvement in battery life (over and above R2E?) - Backlight timings have changed to improve battery life (20s, 26s, 40s to 15s, 20s, 60s - Fade, Backlight off, Display off) - Pressing either of the volume control buttons when in Standby mode displays the time for 3-4 seconds. - Use Now option appears when transfering pictures to the phone (previously just Ok). Options are View, Set as wallpaper, Set as screensaver, Set as starup screen, Add to contact - SE wap link removed from Application folder - Faster image browsing with selected images appearing full screen. - Improved Bluetooth stability - Bug where entering multiple names & numbers could delete the numbers for the first names entered has been fixed. - Snooze is now available on Recurrent alarms - Can now delete one contect from a group without deleting the whole group - Time of the last call now displayed in the missed calls list - The bug whereby the first call received after power up produces an "answer, reject, answer and continue" menu seems to have been fixed - The fonts of Operator logo, the command keys such as "Calls", "More" are a bit larger and the font of Date & time has been Slightly reduced. - The Globe icon that appears when using GRPS has been modified during initial connection (four silver ball circling around the globe) - Faster loading of JAVA games - Screen brightness increased - Performing a Sync does not cause the phone to reboot (some phones only?) - Playing sound and video after running Java applications now always works fine. - When in phonebook, it's now possible to change keyboard language by simply press the # key. - Transfer of files to the phone over IR or BT no longer causes the phone to output sound (some phones only!?!). - JBenchmark 1 - 2,313 - 2,326 - JBenchmark 2 - 118 - 127 - Software versions: LCD 200406041 Camera 3.9 ITP CXC 125 813 R1S or R1T - Bugs Bluetooth turns itself off if a paired bluetooth headset goes out of range. Hvilken verksted oppgraderte du fra, tror jeg venter litt til med å oppgradere sånn at de har den siste versjonen dvs R2L001. så, jeg skal gå til en plass å si at: jeg skulle ha oppdatert firmwaren min til R2L001 versonen ? Lenke til kommentar
Heineoen Skrevet 21. februar 2006 Rapporter Del Skrevet 21. februar 2006 (endret) For meg n00b som ikke kjenner Se.. Hvordan ser jeg vilken Firmware jeg har? Skjønner ikke høyre venstre greier... Hvor kan jeg laste ned nyeste versjon av firmware og kan jeg ta det over blåtann? Endret 21. februar 2006 av Heineoen Lenke til kommentar
