Bios-Chip
Hei.
Er det noen som har et defekt Asus a7v333Raid- HK?
Eller kontakter som kan skaffe en bios-chip til mitt asus kort.
Har F**ka bios`en min.
Har hørt at det går an å ta en form for Back-flash, hvis bios-oppdateringen går til hel*e*e .Noen som kan tastene for å gjøre det?
(har helt svart skjerm når jeg slår på)
Athlon XP1800+
Asus a7v333RAID
chieftec DX-01 blått
33gb fujitsu
Sakser inn en fremgangsmåte som har funket på tidligere a7v kort.
Er hentet fra forumet på a7vtroubleshooting.com
Quote:
Here we go:
1. Create a boot floppy and copy awdflash.exe and the bios file you wish to try to load.
2. Create an autoexec.bat file in notepad (save the notepad file with a .bat extention) with the following text:
awdflash.exe [name of the BIOS file.extention] /py /sn
For instance awdflash.exe a7v1005c.awd /py /sn.
3. ASUS's flasher doesn't support command switches AFAIK so download the more general awdflash.exe (as opposed to aflash.exe)
4. Copy this autoexec.bat file on the floppy.
files you should have on the floppy:
BIOS file.
awdflash.exe
autoexec.bat
command.com
drvspaace.bin
io.sys
msdos.sys
5. Disconnect all your devices except the floppy, CPU, RAM, Keyboard. (no Sound, Modem, NIC, HDDs or whatever)
6. Boot up. You should be able to see some activity on the Floppy Drive's LED. If it just stays there doing nothing it may mean bad news. Nonetheless If you notice activity get on your knees and start praying. Let it finish and the FDD's light must be off for a few good minutes just to be sure before you reboot. Clear the CMOS and thank God.
