Hvilken distro bør jeg prøve?
Jeg har testet Red Hat for en god stund siden, husker ikke lengre så mye fra den..
Jeg navigerer "greit" via Putty på FreeBSD.
Nå skal jeg formatere opp en AMD 1,4 Ghz med 512 minne, Radeon AllInWonder 32MB, 3Com nettverkskort.
Jeg skal kjøre GUI basert distro for vanlig office/multimedia app.
Jeg må også ha Apache, MySQL, FTP.
Hvilken distro bør jeg prøve meg på?
(er ganske noob på *nix)
:cry:
Gentoo bør du teste visst du vil gå inn for å kjøre linux som desktop.
Debian er vel mer passende for server hvis det er det du skal ha.
Men det er jo nesten evig mange tråder om distro valg her. Så det er ikke vanskligere enn å bare søke.
Denne er verdt å teste. PCLinuxOS.
PCLinuxOS is one of the worlds up and coming providers of a Linux Desktop Solution. With a small but dedicated development team, PClinuxOS delivers Desktop Ready Software that harnesses the power of the Open Source Community.
PCLinuxOS Preview 7 is an English only Knoppix style live cd initially based on Mandrake Linux that runs entirely from a bootable CD without installing anything on your computer. Data on the CD is uncompressed on the fly allowing up to 2 GB of programs on one CD including a complete Xserver, KDE Desktop, Open Office, Nvidia 3D graphic drivers and Java all preconfigured and ready to use.
In addition to the livecd, you can also install PCLinuxOS to your hard drive with our easy to use livecd-installer provided you like it and it runs well on your computer. Additional applications can be added or removed from your hard drive using our friendly apt-get frontend via The Synaptic Software Manager.
PCLinuxOS is currently under heavy development and should be considered beta software. PCLinuxOS should work on most modern hardware and comes with advanced hardware detection. Recommended memory to use PCLinuxOS is 256mb or more and 5-6 gigs of free hard drive space for hard drive installations.
Mvh Meg.
jeg bruker gentoo til server.
Jeg takker så mye for mange varierte svar her.
Trodde det ikke var så mange distroer å veldge mellom.
Jeg lastet ned iso'n for suse nå og tester ut denne først. Fungerer det greit holder jeg meg til den...
Her er kanskje et teit spørsmål men:
Hvis alle distroene kjører KDE/Gnome, hva er da forskjellen på de forskjellige distroene?
Filsystem? Hastighet?
Den første forskjellen du støter på er gjerne innstallasjonsprogrammet, om installasjonsprogrammet finner hardwaren din automatisk eller om du må fikse det selv osv. Ellers går det mye på konfigurering og innstallasjon av programmer. Nyeste "stable" kjerne er vel 2.6.8.1, men distroene kan typisk bruke alt fra 2.4.20 og oppover.
Endret av fjotten
Så alle distroer bruker samme kjerne/kernel ? (bortsett fra Freebsd?)
