Får ikke endret e-post.
Takk, da fikk jeg endret den og logget inn på nytt. Men en liten bug at dette vises på skjermen:
QUOTE
Warning: Undefined index: signature in /home/forum/sources/lib/emailer.php on line 306
Warning: Use of undefined constant NAME - assumed 'NAME' in /home/forum/sources/lib/emailer.php(310) : regexp code on line 1
Warning: Use of undefined constant BOARD_ADDRESS - assumed 'BOARD_ADDRESS' in /home/forum/sources/lib/emailer.php(310) : regexp code on line 1
Warning: Use of undefined constant THE_LINK - assumed 'THE_LINK' in /home/forum/sources/lib/emailer.php(310) : regexp code on line 1
Warning: Use of undefined constant MAN_LINK - assumed 'MAN_LINK' in /home/forum/sources/lib/emailer.php(310) : regexp code on line 1
Warning: Use of undefined constant ID - assumed 'ID' in /home/forum/sources/lib/emailer.php(310) : regexp code on line 1
Warning: Use of undefined constant CODE - assumed 'CODE' in /home/forum/sources/lib/emailer.php(310) : regexp code on line 1
Warning: Use of undefined constant BOARD_NAME - assumed 'BOARD_NAME' in /home/forum/sources/lib/emailer.php(310) : regexp code on line 1
Warning: Undefined property: lang_subject in /home/forum/sources/lib/emailer.php on line 196
Warning: Undefined index: debug in /home/forum/sources/functions.php on line 2161
Warning: Undefined variable: start in /home/forum/sources/functions.php on line 2171
Warning: Undefined variable: htm in /home/forum/sources/functions.php on line
