Hvordan legger jeg inn musikk til ingame chat?
Jeg har lastet ned noen lyder fra den genial cs filmen : www.pwned.nl
som jeg tenkte skulle spille av i inngame voice chat!
Noen som vet hvor jeg skal legge den in , og hvilke kommandoer jeg må skrive i console??
"There is no spoon"- The Matricks
Nevermind...fant det ut :D
Endret av Sarion
Dere må laste ned en config fra disse små idiotene
INSTALL/USE
1. Extract the files to your cstrike directoy (For most people this is loacated at: C:\Program Files\Steam\SteamApps\[email protected]\counter-strike\cstrike)
2. Join a Counter-Strike server
3. Open up your console ~
4. Type in: exec voiceannoy.cfg
5. Hit Enter and then close your console ~
6. Use your number 3 button on your keypad to start or stop playing the voiceannoy.
If you want to replace the default voice annoy with a new one, you must download what you want to use and it must be renamed to voice_input.wav and put in the directory listed in step 1. You can also add the voiceannoy.cfg to your autoexec.cfg which makes it so you do not have to run the cfg each time you enter a new game.
[myg0t]
Endret av Sarion
