hanszpett Skrevet 8. august 2004 Del Skrevet 8. august 2004 (endret) Noen som har noen forslag til hvilken prosessor jeg bør kjøpe? Den jeg har nå er ganske så "HOT". Bruker pcen til det meste...F.eks Spill, DV, 3D, Photo. etc... Bør jeg kjøpe nytt hovedkort eller holder det med det jeg har??? ______________________________________________________ Processor Model : AMD Athlon XP 2100+ Speed : 1.73GHz Model Number : 2100 (estimated) Performance Rating : PR2513 (estimated) Type : Standard L2 On-board Cache : 256kB ECC Synchronous Write-Back (16-way, 64 byte line size) CPU Temperature : 73.5°C / 164.3°F Auto Fan Speed Control : No CPU Fan Speed : 2428rpm CPU Voltage : 1.76V Mainboard Bus(es) : ISA AGP PCI IMB USB FireWire/1394 i2c/SMBus MP Support : 1 CPU(s) MP APIC : Yes System BIOS : American Megatrends Inc. Version 07.00T System : MSI MS-6712 Mainboard : MSI MS-6712 Total Memory : 511MB DDR-SDRAM Chipset 1 Model : VIA Technologies Inc VT8377 Apollo KT400/A/600 CPU to PCI Bridge Front Side Bus Speed : 2x 133MHz (266MHz data rate) Total Memory : 512MB DDR-SDRAM Memory Bus Speed : 2x 199MHz (398MHz data rate) Video System Desktop Monitors/Panels : 2 Monitor/Panel : Default Monitor Monitor/Panel : Default Monitor Monitor/Panel : Plug and Play Monitor Monitor/Panel : IBM 6541 G51 Adapter : NVIDIA GeForce4 Ti 4800 SE Physical Storage Devices Hard Disk : SAMSUNG SP1614N Hard Disk : ST380023A CD-ROM/DVD : SAMSUNG CD-R/RW SW-248B CD-ROM/DVD : _NEC DVD+RW ND-1100A CD-ROM/DVD : Generic DVD-ROM SCSI CdRom Device Logical Storage Devices System (C:) : 149.0GB (15.9GB, 11% Free) (NTFS) CD-ROM/DVD (D:) : N/A 30. jul 2004 (E:) : 26MB (0MB, 0% Free) (CDFS) Extra (F:) : 74.5GB (3.9GB, 5% Free) (NTFS) Sc2_cd1 (G:) : 696MB (0MB, 0% Free) (CDFS) Peripherals Serial/Parallel Port(s) : 3 COM / 1 LPT USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : VIA Rev 5 or later USB Universal Host Controller USB Controller/Hub : Standard Enhanced PCI to USB Host Controller USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub FireWire/1394 Controller/Hub : VIA OHCI Compliant IEEE 1394 Host Controller Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard Mouse : HID-compliant mouse Human Interface : USB Human Interface Device MultiMedia Device(s) Device : Standard Game Port Device : CMI8738/C3DX PCI Audio Device Printers and Faxes Model : HP DeskJet 840C/841C/842C/843C Operating System(s) Windows System : Microsoft Windows XP/2002 Professional (Win32 x86) 5.01.2600 (Service Pack 1) Network Services Adapter : VIA Compatable Fast Ethernet Adapter Endret 10. august 2004 av Opus Lenke til kommentar
torsvb Skrevet 8. august 2004 Del Skrevet 8. august 2004 Hva trenger du professoren til? Lenke til kommentar
Windoge Skrevet 8. august 2004 Del Skrevet 8. august 2004 Hva trenger du professoren til? Undervisning på universitet Men fra spøk til side, bare edit emne ditt så slipper du sikkert en del spøkefuler Lenke til kommentar
torsvb Skrevet 8. august 2004 Del Skrevet 8. august 2004 Hihi Hvordan minne og skjermkort har du? Hvis det er ganske bra kunne det kanskje vært en ide å oppgradert hk også, for eksempel til 754. Lenke til kommentar
Falcon_ Skrevet 8. august 2004 Del Skrevet 8. august 2004 AMD XP 2500+ skulle funke fint og den er ganske kjølig også. Lenke til kommentar
Shotherra Skrevet 8. august 2004 Del Skrevet 8. august 2004 Jeg har MSI MS 6712 V1.0 (eller va det 1.2...!), Med 511 DDR-Ram Apacer, XP 2800+, FX 5700U og kjører på 333Fsb noe som er en veldig god gamer pc, samt kontormaskin... Lenke til kommentar
anon12234 Skrevet 8. august 2004 Del Skrevet 8. august 2004 Jeg har MSI MS 6712 V1.0 (eller va det 1.2...!), Med 511 DDR-Ram Apacer, XP 2800+, FX 5700U og kjører på 333Fsb noe som er en veldig god gamer pc, samt kontormaskin... veldig god er vell litt å ta i? Lenke til kommentar
cremaster Skrevet 8. august 2004 Del Skrevet 8. august 2004 Jeg har MSI MS 6712 V1.0 (eller va det 1.2...!), Med 511 DDR-Ram Apacer, XP 2800+, FX 5700U og kjører på 333Fsb noe som er en veldig god gamer pc, samt kontormaskin... Men enormt imponerende FSB da!!! Lenke til kommentar
anon12234 Skrevet 8. august 2004 Del Skrevet 8. august 2004 (endret) Jeg har MSI MS 6712 V1.0 (eller va det 1.2...!), Med 511 DDR-Ram Apacer, XP 2800+, FX 5700U og kjører på 333Fsb noe som er en veldig god gamer pc, samt kontormaskin... Men enormt imponerende FSB da!!! nei?!, jeg kjører 400mhz fsb..... Endret 8. august 2004 av Henrik2k Lenke til kommentar
cremaster Skrevet 8. august 2004 Del Skrevet 8. august 2004 nei?!, jeg kjører 400mhz fsb..... Så du kjører minnet på 800mhz????? Lenke til kommentar
anon12234 Skrevet 8. august 2004 Del Skrevet 8. august 2004 nei?!, jeg kjører 400mhz fsb..... Så du kjører minnet på 800mhz????? tror ikke helt du har shønnt dette jeg............. giddr ikke forklare, sry Lenke til kommentar
Evleos Skrevet 8. august 2004 Del Skrevet 8. august 2004 Man skriver hastigheten dobbelt... ie, i dine øyne har han 166mhz FSB...Mens Henrik har 200... Lenke til kommentar
cremaster Skrevet 8. august 2004 Del Skrevet 8. august 2004 166 FSB med minnet "by spd" som det heter så fint gir en minne frekvens på 333mhz. 200 FSB gir 400 mhz og 400 fsb gir 800mhz. Det finnes ingen cpu som takler 400 FSB. Lenke til kommentar
cremaster Skrevet 8. august 2004 Del Skrevet 8. august 2004 Man skriver hastigheten dobbelt... ie, i dine øyne har han 166mhz FSB...Mens Henrik har 200... Litt sent ute med svar her, akkurat det jeg mente. Var ingen fantastisk spøk fra min side, men rett skal være rett. Lenke til kommentar
Playmofetish Skrevet 8. august 2004 Del Skrevet 8. august 2004 Eller XP 2800,..... Akkurat XP2800+ er jo et ganske dumt kjøp nå, IOM at prisen på denne har økt til over 1000,- Mens XP2500+ er fortsatt er god bankers! Lenke til kommentar
HjalmarJalla Skrevet 8. august 2004 Del Skrevet 8. august 2004 (endret) Tja, hva med å kjøpe en Athlon 64 2800 og et Asus K8N-E hk? Ligger på rundt 35 grader med en Thermaltake Silent boost vifte, og det med den medfølgende Arctic Silver pastaen Hjemme hos meg vel og merke... Endret 8. august 2004 av HjalmarJalla Lenke til kommentar
larskrru Skrevet 8. august 2004 Del Skrevet 8. august 2004 Fikk en XP Mobile 2400+ i posten her om dagen. Grommeste Athlon'en jeg har hatt uten tvil. OC'er voldsomt. Anbefales! Lenke til kommentar
hanszpett Skrevet 9. august 2004 Forfatter Del Skrevet 9. august 2004 Hva med en av disse da??? AMD Athlon XP3000+ 2.167 GHz Socket A 333MHz, 512KB Barton, OEM 1.450,- AMD Athlon XP3200+ 2.2 GHz Socket A 400MHz, 512KB Barton, BOXED 1.885,- Lenke til kommentar
sub1343 Skrevet 9. august 2004 Del Skrevet 9. august 2004 Hva med en av disse da??? AMD Athlon XP3000+ 2.167 GHz Socket A 333MHz, 512KB Barton, OEM 1.450,- AMD Athlon XP3200+ 2.2 GHz Socket A 400MHz, 512KB Barton, BOXED 1.885,- en socket 754 3000+ koster ca samme og er betraktelig kjappere Lenke til kommentar
