yojimbo Skrevet 7. august 2004 Del Skrevet 7. august 2004 Noen med litt peiling på final fantasy X som kan gi meg en detaljert og god beskrivelse på hvordan man får tak i aeonen anima? På forhånd takk. Lenke til kommentar
Erichsen Skrevet 7. august 2004 Del Skrevet 7. august 2004 Hvis du tar en titt på GameFaqs, så finner du nok ut av det . Lenke til kommentar
yojimbo Skrevet 7. august 2004 Forfatter Del Skrevet 7. august 2004 det har jeg allerede gjort , og jeg forsøkte å gjøre det som sto der , det gikk jo til helvete , så kanskje det er noen her som har noen tips? Lenke til kommentar
Erichsen Skrevet 7. august 2004 Del Skrevet 7. august 2004 Først må du finne "hidden treasure" i hvert av de fem templene, og så: [side Quest: Anima] [01] - After the Highbride event with Maester Mika, board the airship. Go to the "Search" option and enter: X: 11 to 16 Y: 57 to 63 Z: doesn't matter [02] - A new location entitled Baaj Temple appears on the list. Go there. - Before you continue, make sure you have collected the Destruction Sphere treasures from all of the temples. It doesn't matter if you got the one in Bevelle or not, so don't worry. [03] - If you haven't already, equip Tidus, Rikku, and Wakka with armor protecting against petrification. [04] - Go straight and dive in the water. [05] - Head towards the green dot on the mini-map, and you will encounter Geosgaeno. - BOSS: Geosgaeno - HP: 34,767 (?) - MP: ??? - Remember this guy? The one Tidus encountered in the beginning of the game. Anyway, I just had Rikku Mix 2 Door to Tomorrows and this fight went by like a breeze. If you don't have these, GO AND GET THEM. You can obtain 99 of them for catching all the monsters 6 areas. See CB's Monster Arena FAQ for more info. Right now, I don't have any other strategies for this guy. [06] - Dive underwater and continue into the temple. [07] - Follow the path into the main area. [08] - Activate all the statues by standing near them. Don't miss the great items near the closest 2, in chests. NOTE: If 5 statues do not light, you have missed one or more sphere treasures. However, you CAN NOT RETURN TO BEVELLE and there is no need to as that one is already lit - it is vital to the storyline (impossible to solve the puzzle without). The item is an HP Sphere. Lenke til kommentar
yojimbo Skrevet 7. august 2004 Forfatter Del Skrevet 7. august 2004 jeg har vært i alle templene , løst opgaven i cloyster of trials en gang til , kommet til chamber of the fayth , og deretter fått diverse kister med forskjellige spheres i , dog ingen destruction sphere. Deretter dro jeg til Baaj temple , men bare to statuer lyste....så nå skjønner jeg ingenting....men takk for hjelpen alikevel! er det noen her som har vært gjennom det samme greiene eller noe lignende mens de selv har spilt spillet? Lenke til kommentar
vegeto Skrevet 7. august 2004 Del Skrevet 7. august 2004 du må få tak i alle skattene.er et i vert tempel. bevelle lyser automatisk Lenke til kommentar
yojimbo Skrevet 7. august 2004 Forfatter Del Skrevet 7. august 2004 Jeg har vært i alle templene , og åpnet alle skattekistene i chamber of the fayth jo.... Lenke til kommentar
Erichsen Skrevet 7. august 2004 Del Skrevet 7. august 2004 Altså, hvis ikke alle statuene lyser, så har du ikke henta alle destruction sphere skattene... Lenke til kommentar
vegeto Skrevet 8. august 2004 Del Skrevet 8. august 2004 hvist du har brukt alle destruction spherene så er det noe galt med spillet ditt. Lenke til kommentar
Zarato Skrevet 8. august 2004 Del Skrevet 8. august 2004 Det er ikke kistene i chamber of the fayth som må åpnes, men kisten du bruker destruction sphere for å komme til (rød sphere) Lenke til kommentar
yojimbo Skrevet 8. august 2004 Forfatter Del Skrevet 8. august 2004 takk. endelig litt fornuft. Lenke til kommentar
vegeto Skrevet 8. august 2004 Del Skrevet 8. august 2004 Det er ikke kistene i chamber of the fayth som må åpnes, men kisten du bruker destruction sphere for å komme til (rød sphere) det er jo det vi har prøvd å fortelle hele tiden da. det er ikke noen andre kister i templene. Lenke til kommentar
Zarato Skrevet 8. august 2004 Del Skrevet 8. august 2004 Jo, det er kister i Chamber of the fayth. Du kan gå inn der hvis du vender tilbake etter å ha fått airship. Der får du og se Aeonene i menneskeform. Lenke til kommentar
yojimbo Skrevet 8. august 2004 Forfatter Del Skrevet 8. august 2004 det er jo det vi har prøvd å fortelle hele tiden da. det er ikke noen andre kister i templene. dette er det dummeste jeg har hørt. vegeto har sikkert ikke spilt spillet selv engang Lenke til kommentar
vegeto Skrevet 8. august 2004 Del Skrevet 8. august 2004 (endret) jeg har sikkert spillt spillet mere en deg. jeg kan bare ikke huske noen andre kister en de du må bruke destruction sphere for å få. nå mener jeg inne der du bruker sphere og sånt ikke rundt i tempelet. hmm får man se aeonene i menneskeform. jeg har aldri gådt tilbake til templene dog jeg har tatt med meg alle skattene hver gang. jeg tar en tur tilbake nå jeg. Endret 8. august 2004 av vegeto Lenke til kommentar
Zarato Skrevet 8. august 2004 Del Skrevet 8. august 2004 Kistene jeg snakker om er inne i rommene Yuna går alene inn i. Det er som regel 2-3 av dem. Lenke til kommentar
Nevnarion Skrevet 8. august 2004 Del Skrevet 8. august 2004 Hva er egentlig problemet? Du skal bare aktivere destruction sphere som åpner et lite hemmelig rom med en kiste i. Dette skal du gjøre i hvert tempel. Så enkelt er det. yojimbo, det er mye enklere å bare finne guiden på GameFAQs enn å sitte her å vente på hjelp fra fullt av folk som prater i kjeften på hverandre. Lenke til kommentar
Erichsen Skrevet 8. august 2004 Del Skrevet 8. august 2004 (endret) det er jo det vi har prøvd å fortelle hele tiden da. det er ikke noen andre kister i templene. dette er det dummeste jeg har hørt. Nei det har vi ikke nevnt... Altså, hvis ikke alle statuene lyser, så har du ikke henta alle destruction sphere skattene... hvist du har brukt alle destruction spherene så er det noe galt med spillet ditt. Endret 8. august 2004 av Erichsen Lenke til kommentar
vegeto Skrevet 8. august 2004 Del Skrevet 8. august 2004 (endret) jeg gjikk inn i rummet der yuna pleier å gå inn alene. nå skjønner offer han ikke skjønte noe det var jo et par skattekister der kansje litt dårli forklart fra min side. også men ingen vits i å prøve å drite meg ut erichsen. Endret 8. august 2004 av vegeto Lenke til kommentar
Erichsen Skrevet 9. august 2004 Del Skrevet 9. august 2004 Jeg har aldri gjort noe for å drite deg ut jeg. Min øvre post var rettet mot Yojimbo som faktisk ikke oppfatter at vi prøver å hjelpe han, og at vi måtte fortelle han tre ganger at han måtte bruke alle destruction spherene. Btw, de chamber of fayth kistene har jo ingenting med Anima å gjøre. Lenke til kommentar
