Skjermfeilmelding i PS CS
http://www.adobeforums.com/cgi-bin/[email protected]
Videre en oppskrift:
Probably easiest thing is to rerun Adobe Gamma and make sure you tick the box which aske if you want to use it as your default profile.
Run Adobe Gamma from the Windows Control Panel and select sRGB as your starting profile. Change the text in the description box to something meaningful to you - Eiengen's Monitor? - and then follow the on-screen instructions. Finally save your new profile to a NEW filename - This is important or you will over-write your sRGB profile.
