brenne firmware til hd på boot cd problem
har et firmware jeg skulle brenne på boot cd, brukte nero->boot cd og dro filene over til den.
maskinen startet på cden, men skjønner ikke helt hvordan en får startet firmwaren
det er 3 foldere:
data
dft
dos
og filene
AUTOEXEC.BAT
MOUSE.COM
MOUSE.INI
i readme står det:
Please copy the contents of this Release to your root directory of your bootable media.
An "autoexec.bat" has been added to automate the firmware upgrade.
men jeg har gjort det der, tror jeg
noen forslag?
takker for forslag, har prøvd alt nå.
ikke noe problem å lage bootcd, men programmet vil ikke starte av seg selv.
så i dos gikk jeg til folderen og skrev autoexec.bat som resulterte i at maskina kun rebooted.
jaja
1. The files contained in (R82021.EXE) should be extracted to bootable media. (ie. Floppy, CD, Zip drive, USB Flash Memory). The default extraction directory is C:\DELL\DRIVERS\R82021.
2. Once the files are extracted, copy the contents of C:\DELL\DRIVERS\R82021 directory to bootable source. Boot to that source.
3. Close all applications, and re-boot from the floppy image just created.
4. The Drive Fitness Test Utility will start automatically.
5. You MUST accept the license agreement to continue!
6. Once accepted the utility will scan the bus for appropriate hard drives.
7. The model number supported will be list as HTS726060M9AT00.
8. Highlight the hard drive then select the "UPDATE MICROCODE" button.
9. Click "Continue", then select "Start"
10. Once completed exit the utility. You will be instructed to reboot your
system. Remove the media and reboot.
