NikonD70 Skrevet 7. september 2004 Forfatter Del Skrevet 7. september 2004 MERE INFO: Yes indeed, the battery grip is in progress... I was planning to use 8 AA NiMH cells, which at 2400mA-h each would give the equivalent of 2.2x battery life. Well, through talks with Nikon, I've decided to change to using 2 of the EN-EL3's... it's more expensive than AA's, but you don't have to buy new batteries or chargers, and Nikon is much happier running the camera on the batteries it was designed to use. This change has of course slowed the development, but overall I think it'll improve a lot of things. Some teasers... Runs on 1 or 2 EN-EL3 batteries, or external power (new jack added). Remote shutter release via IR (removable fiber optic cable) or hardwired (camera modification). Remote shutter jack added, to allow remote cords, slaving cameras (i.e. stereo), etc. Hang in there... I'll get it done soon! [email protected] wwww.Harbortronics.com Home of the DigiSnap Lenke til kommentar
Magpal Skrevet 7. september 2004 Del Skrevet 7. september 2004 Dette høres jo dette kjempe bra ut! Ikke noe jallamekk fra en jallaprodusent. Virker som om produsenten har peiling på hva de driver med! Håper bare de lager grepet solid, billig og at Nikon godkjenner det for bruk på d70. At vi ikke mister garanti osv. Lenke til kommentar
NikonD70 Skrevet 10. september 2004 Forfatter Del Skrevet 10. september 2004 Vet ikke om folk er interessert eller følger med direkte på Nikonians, men her kommer det enda mer info: No camera modification needed to use the IR shutter release feature. This essentially emulates the ML-L1/3. This requires the camera to be set to using the IR remote, and used periodically to keep the camera from turning the IR remote feature off. The half-press feature will also not work via IR. A removable fiber optic cable will route up the front of the camera to the grip... very simple, cable stays out of the way. If the camera is modified to add a remote control jack, which will probably void the warrenty, then all limitations are removed... there's no need to set-up the camera for remote use, half-press works fine, etc. There would be a short cable jumper running from the camera to the grip to connect the two. The grip will work from one or two installed battery packs (En-EL3)... no NEED to buy an additional battery pack unless you wish. Also, an additional external DC input jack (industry standard plug) is provided. wwww.Harbortronics.com Home of the DigiSnap Lenke til kommentar
Magpal Skrevet 10. september 2004 Del Skrevet 10. september 2004 Da gjenstår det bare et spørsmål.. Vil det være lett å få tak i grept? Håper det blir masse grep på lager og enkel betaling/forsendelse.. Lenke til kommentar
NikonD70 Skrevet 22. september 2004 Forfatter Del Skrevet 22. september 2004 Nå nærmer det seg: http://harbortronics.com/news.htm Les og Last ned pdf.... Synes ting er litt uklare, mulig engelsken min ikke er helt rå. Noen som klarer å forklare det som blir sagt? Lenke til kommentar
medi8or Skrevet 22. september 2004 Del Skrevet 22. september 2004 Les og Last ned pdf....Synes ting er litt uklare, mulig engelsken min ikke er helt rå. Noen som klarer å forklare det som blir sagt? Kort sagt at IR har begrenset bruksområde og rekkevidde, så Harbortronics kan modifisere D70 for 185$. Modifiseringen består i å legge til en 2.5mm jack port, som kan brukes til snorutløser eller andre fjernutløsere. (Denne modifikasjonen gir og flere funksjoner til vertikalgrepet..) Lenke til kommentar
Magpal Skrevet 22. september 2004 Del Skrevet 22. september 2004 PDF filen sier jo ingenting om selve batterigrepet, men om modifisering av D70. Nå må det snart skje noe på batterigrep fronten! Hater å vente! Lenke til kommentar
medi8or Skrevet 22. september 2004 Del Skrevet 22. september 2004 Den sier ikke noe om batterigrepet, nei, men det sier hva som skal til for at batterigrepet skal virke skikkelig. F.eks. å holde knappen halvt ned virker ikke med IR overføring... Lenke til kommentar
Magpal Skrevet 23. september 2004 Del Skrevet 23. september 2004 Er jo klar over det, men selve pdf filen har jo vært ute på nettet i kanskje 2 uker nå. Lenke til kommentar
Magpal Skrevet 29. september 2004 Del Skrevet 29. september 2004 Ingen som har noen updates på dette? Sjekker harbortronics nesten hver dag, men aldri er det oppdateringer.. Noen som vet om andre forum der akkuratt dette har blitt diskutert? Vet om dette, men der skjer det også lite for tiden. Lenke til kommentar
NikonD70 Skrevet 30. september 2004 Forfatter Del Skrevet 30. september 2004 Sendte en mail til Mark i Harbortronics for en stund siden og han fortalte at han ikke ville gi ut mer info før ting var klart. Tipper han blir bomba med mails daglig og er lei de samme spørsmålene fra alle verdens kanter. Antageligvis dumper det inn et innlegg (en vakker dag) på Nikonians og Dprewiev om at grepet er ferdig og til salgs på www.harbortronics.com. Han har i hvertfall "fått" sinnsykt mye reklame for prosjektet sitt, noe som kan være bra dersom produktet står i stil med forventningene (som på en måte er skrudd litt opp i været har jeg en følelse av). Lenke til kommentar
larstroels Skrevet 2. oktober 2004 Del Skrevet 2. oktober 2004 Se lige her: http://www.hkjenis.com/English/Esbxl3.html Hilsen Lars T. www.sitecenter.dk/larstroels Lenke til kommentar
Magpal Skrevet 2. oktober 2004 Del Skrevet 2. oktober 2004 Hmm. Dårlig forklart hvordan grepet fungerer! Står jo ikke hvordan utløserknappen fungerer. Er det med IR, USB eller modifisering? Lenke til kommentar
NikonD70 Skrevet 3. oktober 2004 Forfatter Del Skrevet 3. oktober 2004 Send en mail og sjekk ut....... Lenke til kommentar
Magpal Skrevet 14. oktober 2004 Del Skrevet 14. oktober 2004 Sendte mail til Mark i harbotronics i går. Spurte om det var fremgang i prosjektet og når det ville komme ut. Fikk raskt svar og her er det: Thanks for the interest! We are in the process of getting production quotes for various pieces of the grip, and don't yet have any firm date or price for release. Hopefully sometime in Nov. Please keep watching our website for more info, as it becomes available! Så for de interesserte er det ikke så altfor lenge å vente selv om vi nok må regne med 1,5 - 2 mnd. Lenke til kommentar
NikonD70 Skrevet 27. januar 2005 Forfatter Del Skrevet 27. januar 2005 Da er faktisk produskjonen i gang: http://www.harbortronics.com/news.htm Lenke til kommentar
Bjarnoy Skrevet 27. januar 2005 Del Skrevet 27. januar 2005 Har du funnet ut hvordan bestille, pris etc. Eller er det for tidlig? Kanskje is i magen er best? Lenke til kommentar
Åkken Bom Skrevet 28. januar 2005 Del Skrevet 28. januar 2005 :!: Ser unektelig noe problemfylt ut å bruke den saken der (les hvordan det fungerer). Men en ting skal de ha: Batterigrepet til D70 er avbildet med trådutløseren til Canon på det nederste bildet De har skjønt at det er Canon som er løsningen Lenke til kommentar
tomviktor Skrevet 28. januar 2005 Del Skrevet 28. januar 2005 Glad jeg har 10D Der MÅ du jo ha enten ett ekstra batteri eller 2stk i ett batterigrep.Den drikker jo batteri som f...! Der er D70 myyyye bedre,org batteri holder nesten dobbelt så lenge som 10D sitt... Dette stemmer ikke helt! Litt bedre batterikapasitet på Nikon, ikke MYYYYYYE... I testen til akam.no tar nikon dobbelt så mange bilder, men det er ikke dermed sagt at det er i virkeligheten. Ute i virkeligheten, tar man ca like mange bilder med Canon 10D som med et Nikon D70! (Nikon tar 1-200 flere) men det er ikke MYYYYYYYYYYYYYYE bedre det er litt bedre... Lenke til kommentar
NikonD70 Skrevet 28. januar 2005 Forfatter Del Skrevet 28. januar 2005 Bjarnoy: Greetings, The VG-D70 is in final production. The designs are all complete, materials have been approved, and we have several vendors making various parts of the grip for us. They will trickle in slowly at first as everything gets ramped up, but we anticipate being able to start shipping on the week of Feb 14.... sorry it's taken so much time, it's been a long process! In the meantime, there is a manual for the VG-D70 posted online at http://www.Harbortronics.com/news.htm . The price is $165, and we will accept orders for the VG-D70 immediately by check. We will ship in the order checks are received. We anticipate a large demand, so there may be a wait for some customers. In the future, we will accept orders over the internet. Shipping will be offered as follows: Individual grips will be shipped via Priority mail within the US for $10. Additional grips in shipment add $5. Global Express mail will be used to ship to Canada and overseas. Canada $20 and other countries range from $20 to $35 per grip. Additional grips in an order add $5. Please e-mail [email protected] for a shipping quote. Please send check with shipping address to: Harbortronics P O Box 2663 Gig Harbor, WA 98335 Lenke til kommentar
