har et proplem her. koden som fulgte med boken har enten en feil eller så er det devc++. kan noen si meg om det er boken eller ikke.
#define WIN32_LEAN_AND_MEAN  // trim the excess fat from Windows
////// Defines
#define BITMAP_ID 0x4D42  // the universal bitmap ID
#define MAP_X	32    // size of map along x-axis
#define MAP_Z	32    // size of map along z-axis
#define MAP_SCALE	20.0f  // the scale of the terrain map
#define PI  3.14159
////// Includes
#include <windows.h>  	// standard Windows app include
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#include <gl/gl.h>    // standard OpenGL include
#include <gl/glu.h>    // OpenGL utilties
////// Global Variables
HDC g_HDC;      // global device context
bool fullScreen = false;  // true = fullscreen; false = windowed
bool keyPressed[256];  	// holds true for keys that are pressed
float angle = 0.0f;    // camera angle
float radians = 0.0f;  	// camera angle in radians
float waterHeight = 154.0f;  // height of water
bool waterDir = true;  	// used to animate water; true = up, false = down
////// Mouse/Camera Variables
int mouseX, mouseY;      // mouse coordinates
float cameraX, cameraY, cameraZ;	// camera coordinates
float lookX, lookY, lookZ;  	// camera look-at coordinates
////// Texture Information
BITMAPINFOHEADER	bitmapInfoHeader;	// temp bitmap info header
BITMAPINFOHEADER	landInfo;  	// land texture info header
BITMAPINFOHEADER	waterInfo;  	// water texture info header
unsigned char*  imageData;  // the map image data
unsigned char*      landTexture;	// land texture data
unsigned char*  waterTexture;	// water texture data
unsigned int  land;  	// the land texture object
unsigned int  water;  	// the water texture object
////// Terrain Data
float terrain[MAP_X][MAP_Z][3];  // heightfield terrain data (0-255); 256x256
// LoadBitmapFile
// desc: Returns a pointer to the bitmap image of the bitmap specified
//       by filename. Also returns the bitmap header information.
//   No support for 8-bit bitmaps.
unsigned char *LoadBitmapFile(char *filename, BITMAPINFOHEADER *bitmapInfoHeader)
FILE *filePtr;      	// the file pointer
BITMAPFILEHEADER	bitmapFileHeader;  // bitmap file header
unsigned char  *bitmapImage;  	// bitmap image data
int    	imageIdx = 0;  // image index counter
unsigned char  tempRGB;    // swap variable
// open filename in "read binary" mode
filePtr = fopen(filename, "rb");
if (filePtr == NULL)
 return NULL;
// read the bitmap file header
fread(&bitmapFileHeader, sizeof(BITMAPFILEHEADER), 1, filePtr);
// verify that this is a bitmap by checking for the universal bitmap id
if (bitmapFileHeader.bfType != BITMAP_ID)
 fclose(filePtr);
 return NULL;
// read the bitmap information header
fread(bitmapInfoHeader, sizeof(BITMAPINFOHEADER), 1, filePtr);
// move file pointer to beginning of bitmap data
fseek(filePtr, bitmapFileHeader.bfOffBits, SEEK_SET);
// allocate enough memory for the bitmap image data
bitmapImage = (unsigned char*)malloc(bitmapInfoHeader->biSizeImage);
// verify memory allocation
if (!bitmapImage)
 free(bitmapImage);
 fclose(filePtr);
 return NULL;
// read in the bitmap image data
fread(bitmapImage, 1, bitmapInfoHeader->biSizeImage, filePtr);
// make sure bitmap image data was read
if (bitmapImage == NULL)
 fclose(filePtr);
 return NULL;
// swap the R and B values to get RGB since the bitmap color format is in BGR
for (imageIdx = 0; imageIdx < bitmapInfoHeader->biSizeImage; imageIdx+=3)
 tempRGB = bitmapImage[imageIdx];
 bitmapImage[imageIdx] = bitmapImage[imageIdx + 2];
 bitmapImage[imageIdx + 2] = tempRGB;
// close the file and return the bitmap image data
fclose(filePtr);
return bitmapImage;
// InitializeTerrain()
// desc: initializes the heightfield terrain data
void InitializeTerrain()
// loop through all of the heightfield points, calculating
// the coordinates for each point
for (int z = 0; z < MAP_Z; z++)
 for (int x = 0; x < MAP_X; x++)
 	terrain[x][z][0] = float(x)*MAP_SCALE;
 	terrain[x][z][1] = (float)imageData[(z*MAP_Z+x)*3];
 	terrain[x][z][2] = -float(z)*MAP_SCALE;
bool LoadTextures()
// load the land texture data
landTexture = LoadBitmapFile("green.bmp", &landInfo);
if (!landTexture)
 return false;
// load the water texture data
waterTexture = LoadBitmapFile("water.bmp", &waterInfo);
if (!waterTexture)
 return false;
// generate the land texture as a mipmap
glGenTextures(1, &land);
glBindTexture(GL_TEXTURE_2D, land);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_NEAREST);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_NEAREST);
gluBuild2DMipmaps(GL_TEXTURE_2D, GL_RGB, landInfo.biWidth, landInfo.biHeight, GL_RGB, GL_UNSIGNED_BYTE, landTexture);
// generate the water texture as a mipmap
glGenTextures(1, &water);
glBindTexture(GL_TEXTURE_2D, water);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_REPEAT);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, GL_REPEAT);
gluBuild2DMipmaps(GL_TEXTURE_2D, GL_RGB, waterInfo.biWidth, waterInfo.biHeight, GL_RGB, GL_UNSIGNED_BYTE, waterTexture);
return true;
void CleanUp()
free(imageData);
free(landTexture);
free(waterTexture);
// Initialize
// desc: initializes OpenGL
void Initialize()
glClearColor(0.0f, 0.0f, 0.0f, 0.0f);  // clear to black
glShadeModel(GL_SMOOTH);    	// use smooth shading
glEnable(GL_DEPTH_TEST);    	// hidden surface removal
glEnable(GL_CULL_FACE);      // do not calculate inside of poly's
glFrontFace(GL_CCW);      // counter clock-wise polygons are out
glEnable(GL_TEXTURE_2D);    	// enable 2D texturing
imageData = LoadBitmapFile("terrain2.bmp", &bitmapInfoHeader);
// initialize the terrain data and load the textures
InitializeTerrain();
LoadTextures();
// Render
// desc: handles drawing of scene
void Render()
radians =  float(PI*(angle-90.0f)/180.0f);
// calculate the camera's position
cameraX = lookX + sin(radians)*mouseY;	// multiplying by mouseY makes the
cameraZ = lookZ + cos(radians)*mouseY;  // camera get closer/farther away with mouseY
cameraY = lookY + mouseY / 2.0f;
// calculate the camera look-at coordinates as the center of the terrain map
lookX = (MAP_X*MAP_SCALE)/2.0f;
lookY = 150.0f;
lookZ = -(MAP_Z*MAP_SCALE)/2.0f;
// clear screen and depth buffer
glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT);
glLoadIdentity();
// set the camera position
gluLookAt(cameraX, cameraY, cameraZ, lookX, lookY, lookZ, 0.0, 1.0, 0.0);
// set the current texture to the land texture
// we are going to loop through all of our terrain's data points,
// but we only want to draw one triangle strip for each set along the x-axis.
for (int z = 0; z < MAP_Z-1; z++)
 glBegin(GL_TRIANGLE_STRIP);
 //glBegin(GL_POINTS);
 for (int x = 0; x < MAP_X-1; x++)
 	// for each vertex, we calculate the grayscale shade color,
 	// we set the texture coordinate, and we draw the vertex.
     the vertices are drawn in this order:
     0  ---> 1
     2  ---> 3
 	// draw vertex 0
 	glColor3f(terrain[x][z][1]/255.0f, terrain[x][z][1]/255.0f, terrain[x][z][1]/255.0f);
 	glTexCoord2f(0.0f, 0.0f);
 	glVertex3f(terrain[x][z][0], terrain[x][z][1], terrain[x][z][2]);
 	// draw vertex 1
 	glTexCoord2f(1.0f, 0.0f);
 	glColor3f(terrain[x+1][z][1]/255.0f, terrain[x+1][z][1]/255.0f, terrain[x+1][z][1]/255.0f);
 	glVertex3f(terrain[x+1][z][0], terrain[x+1][z][1], terrain[x+1][z][2]);
 	// draw vertex 2
 	glTexCoord2f(0.0f, 1.0f);
 	glColor3f(terrain[x][z+1][1]/255.0f, terrain[x][z+1][1]/255.0f, terrain[x][z+1][1]/255.0f);
 	glVertex3f(terrain[x][z+1][0], terrain[x][z+1][1], terrain[x][z+1][2]);
 	// draw vertex 3
 	glColor3f(terrain[x+1][z+1][1]/255.0f, terrain[x+1][z+1][1]/255.0f, terrain[x+1][z+1][1]/255.0f);
 	glTexCoord2f(1.0f, 1.0f);
 	glVertex3f(terrain[x+1][z+1][0], terrain[x+1][z+1][1], terrain[x+1][z+1][2]);
 glEnd();
// enable blending
glEnable(GL_BLEND);
// enable read-only depth buffer
glDepthMask(GL_FALSE);
// set the blend function to what we use for transparency
glBlendFunc(GL_SRC_ALPHA, GL_ONE);
glColor4f(0.5f, 0.5f, 1.0f, 0.7f);  	// set color to a transparent blue
glBindTexture(GL_TEXTURE_2D, water);  // set texture to the water texture
// draw water as one large quad surface
glBegin(GL_QUADS);
 glTexCoord2f(0.0f, 0.0f);    // lower left corner
 glVertex3f(terrain[0][0][0], waterHeight, terrain[0][0][2]);
 glTexCoord2f(10.0f, 0.0f);    // lower right corner
 glVertex3f(terrain[MAP_X-1][0][0], waterHeight, terrain[MAP_X-1][0][2]);
 glTexCoord2f(10.0f, 10.0f);    // upper right corner
 glVertex3f(terrain[MAP_X-1][MAP_Z-1][0], waterHeight, terrain[MAP_X-1][MAP_Z-1][2]);
 glTexCoord2f(0.0f, 10.0f);    // upper left corner
 glVertex3f(terrain[0][MAP_Z-1][0],waterHeight, terrain[0][MAP_Z-1][2]);
glEnd();
// set back to normal depth buffer mode (writable)
glDepthMask(GL_TRUE);
// disable blending
glDisable(GL_BLEND);
// animate the water
if (waterHeight > 155.0f)
 waterDir = false;
else if (waterHeight < 154.0f)
 waterDir = true;
if (waterDir)
 waterHeight += 0.01f;
else
 waterHeight -= 0.01f;
glFlush();
SwapBuffers(g_HDC);  	// bring backbuffer to foreground
// function to set the pixel format for the device context
void SetupPixelFormat(HDC hDC)
int nPixelFormat;    	// our pixel format index
static PIXELFORMATDESCRIPTOR pfd = {
 sizeof(PIXELFORMATDESCRIPTOR),	// size of structure
 1,        // default version
 PFD_DRAW_TO_WINDOW |  	// window drawing support
 PFD_SUPPORT_OPENGL |  	// OpenGL support
 PFD_DOUBLEBUFFER,    // double buffering support
 PFD_TYPE_RGBA,    	// RGBA color mode
 32,        // 32 bit color mode
 0, 0, 0, 0, 0, 0,    // ignore color bits, non-palettized mode
 0,        // no alpha buffer
 0,        // ignore shift bit
 0,        // no accumulation buffer
 0, 0, 0, 0,      // ignore accumulation bits
 16,        // 16 bit z-buffer size
 0,        // no stencil buffer
 0,        // no auxiliary buffer
 PFD_MAIN_PLANE,    	// main drawing plane
 0,        // reserved
 0, 0, 0 };      // layer masks ignored
nPixelFormat = ChoosePixelFormat(hDC, &pfd);	// choose best matching pixel format
SetPixelFormat(hDC, nPixelFormat, &pfd);  // set pixel format to device context
// the Windows Procedure event handler
LRESULT CALLBACK WndProc(HWND hwnd, UINT message, WPARAM wParam, LPARAM lParam)
static HGLRC hRC;    	// rendering context
static HDC hDC;      // device context
int width, height;    	// window width and height
int oldMouseX, oldMouseY;
switch(message)
 case WM_CREATE:    	// window is being created
 	hDC = GetDC(hwnd);  	// get current window's device context
 	g_HDC = hDC;
 	SetupPixelFormat(hDC);  // call our pixel format setup function
 	// create rendering context and make it current
 	hRC = wglCreateContext(hDC);
 	wglMakeCurrent(hDC, hRC);
 	return 0;
 	break;
 case WM_CLOSE:    	// windows is closing
 	// deselect rendering context and delete it
 	wglMakeCurrent(hDC, NULL);
 	wglDeleteContext(hRC);
 	// send WM_QUIT to message queue
 	PostQuitMessage(0);
 	return 0;
 	break;
 case WM_SIZE:
 	height = HIWORD(lParam);  // retrieve width and height
 	width = LOWORD(lParam);
 	if (height==0)    	// don't want a divide by zero
   height=1;
 	glViewport(0, 0, width, height);	// reset the viewport to new dimensions
 	glMatrixMode(GL_PROJECTION);  // set projection matrix current matrix
 	glLoadIdentity();    	// reset projection matrix
 	// calculate aspect ratio of window
 	gluPerspective(54.0f,(GLfloat)width/(GLfloat)height,1.0f,1000.0f);
 	glMatrixMode(GL_MODELVIEW);  	// set modelview matrix
 	glLoadIdentity();    	// reset modelview matrix
 	return 0;
 	break;
 case WM_KEYDOWN:    	// is a key pressed?
 	keyPressed[wParam] = true;
 	return 0;
 	break;
 case WM_KEYUP:
 	keyPressed[wParam] = false;
 	return 0;
 	break;
 case WM_MOUSEMOVE:
 	// save old mouse coordinates
 	oldMouseX = mouseX;
 	oldMouseY = mouseY;
 	// get mouse coordinates from Windows
 	mouseX = LOWORD(lParam);
 	mouseY = HIWORD(lParam);
 	// these lines limit the camera's range
 	if (mouseY < 200)
   mouseY = 200;
 	if (mouseY > 450)
   mouseY = 450;
 	if ((mouseX - oldMouseX) > 0)  // mouse moved to the right
   angle += 3.0f;
 	else if ((mouseX - oldMouseX) < 0)	// mouse moved to the left
   angle -= 3.0f;
 	return 0;
 	break;
 default:
 	break;
return (DefWindowProc(hwnd, message, wParam, lParam));
// the main windows entry point
int WINAPI WinMain(HINSTANCE hInstance, HINSTANCE hPrevInstance, LPSTR lpCmdLine, int nShowCmd)
WNDCLASSEX windowClass;  // window class
HWND    hwnd;  	// window handle
MSG     msg;    // message
bool    done;  	// flag saying when our app is complete
DWORD    dwExStyle;  // Window Extended Style
DWORD    dwStyle;  	// Window Style
RECT    windowRect;
// temp var's
int width = 800;
int height = 600;
int bits = 32;
//fullScreen = TRUE;
windowRect.left=(long)0;      // Set Left Value To 0
windowRect.right=(long)width;    	// Set Right Value To Requested Width
windowRect.top=(long)0;      	// Set Top Value To 0
windowRect.bottom=(long)height;    	// Set Bottom Value To Requested Height
// fill out the window class structure
windowClass.cbSize  	= sizeof(WNDCLASSEX);
windowClass.style  	= CS_HREDRAW | CS_VREDRAW;
windowClass.lpfnWndProc  = WndProc;
windowClass.cbClsExtra  = 0;
windowClass.cbWndExtra  = 0;
windowClass.hInstance  = hInstance;
windowClass.hIcon  	= LoadIcon(NULL, IDI_APPLICATION);	// default icon
windowClass.hCursor  	= LoadCursor(NULL, IDC_ARROW);  // default arrow
windowClass.hbrBackground	= NULL;        // don't need background
windowClass.lpszMenuName	= NULL;        // no menu
windowClass.lpszClassName	= "MyClass";
windowClass.hIconSm  	= LoadIcon(NULL, IDI_WINLOGO);  // windows logo small icon
// register the windows class
if (!RegisterClassEx(&windowClass))
 return 0;
if (fullScreen)        // fullscreen?
 DEVMODE dmScreenSettings;    	// device mode
 memset(&dmScreenSettings,0,sizeof(dmScreenSettings));
 dmScreenSettings.dmSize = sizeof(dmScreenSettings);
 dmScreenSettings.dmPelsWidth = width;  // screen width
 dmScreenSettings.dmPelsHeight = height;  // screen height
 dmScreenSettings.dmBitsPerPel = bits;  // bits per pixel
 dmScreenSettings.dmFields=DM_BITSPERPEL|DM_PELSWIDTH|DM_PELSHEIGHT;
 if (ChangeDisplaySettings(&dmScreenSettings, CDS_FULLSCREEN) != DISP_CHANGE_SUCCESSFUL)
 	// setting display mode failed, switch to windowed
 	MessageBox(NULL, "Display mode failed", NULL, MB_OK);
 	fullScreen=FALSE;
if (fullScreen)        // Are We Still In Fullscreen Mode?
 dwExStyle=WS_EX_APPWINDOW;    // Window Extended Style
 dwStyle=WS_POPUP;      // Windows Style
 ShowCursor(FALSE);      // Hide Mouse Pointer
else
 dwExStyle=WS_EX_APPWINDOW | WS_EX_WINDOWEDGE;	// Window Extended Style
 dwStyle=WS_OVERLAPPEDWINDOW;    	// Windows Style
AdjustWindowRectEx(&windowRect, dwStyle, FALSE, dwExStyle);  // Adjust Window To True Requested Size
// class registered, so now create our window
hwnd = CreateWindowEx(NULL,        	// extended style
       "MyClass",      	// class name
       "Texture Example 3: The Heightfield Terrain Example",  // app name
       dwStyle | WS_CLIPCHILDREN |
       WS_CLIPSIBLINGS,
       0, 0,        	// x,y coordinate
       windowRect.right - windowRect.left,
       windowRect.bottom - windowRect.top,	// width, height
       NULL,        	// handle to parent
       NULL,        	// handle to menu
       hInstance,      	// application instance
       NULL);        // no extra params
// check if window creation failed (hwnd would equal NULL)
if (!hwnd)
 return 0;
ShowWindow(hwnd, SW_SHOW);  	// display the window
UpdateWindow(hwnd);    	// update the window
done = false;      // intialize the loop condition variable
Initialize();      // initialize OpenGL
// main message loop
while (!done)
 PeekMessage(&msg, hwnd, NULL, NULL, PM_REMOVE);
 if (msg.message == WM_QUIT)  // do we receive a WM_QUIT message?
 	done = true;    // if so, time to quit the application
 else
 	if (keyPressed[VK_ESCAPE])
   done = true;
 	else
   Render();
   TranslateMessage(&msg);  // translate and dispatch to event queue
   DispatchMessage(&msg);
CleanUp();
if (fullScreen)
 ChangeDisplaySettings(NULL,0);  // If So Switch Back To The Desktop
 ShowCursor(TRUE);    	// Show Mouse Pointer
return msg.wParam;
jeg vill bare vite dette sånn at jeg skriver riktig kode.
edit: det er bare linking feil. så jeg tror det mangler en fil hos devc++.
Endret av Fredrik90
Du må linke med OpenGL-bibliotekene, dette er -ikke- det samme som #include <gl/gl.h> o.s.v.
Slik kompilerer du OpenGL-programmer v.h.a. MinGW:
g++ program.cpp -l opengl32 -l glu32 -mwindows -o program
MinGW er kompileren Dev-Cpp bruker.
Altid ta med feilmelding, -og- spesifiser hvordan du kompilerer og linker når du beskriver et problem.
Det må da stå mer?
(Dev-Cpp har (hatt?) en bug med parsing av GCC's output .. så noen ganger blir ikke den fulstendige feilmeldingen tatt med.)
Edit:
Men sett sånn i isolasjon så betyr feilmeldingen at Make feilet, om jeg ikke tar helt feil. Grunnen til at Make feilet her er sansynligvis fordi kompileren (som Make kaller) feilet.
Endret av søppel
