Manx Skrevet 2. juli 2006 Rapporter Del Skrevet 2. juli 2006 Jeg har da bestilt for mellom 1000 og 1500 kroner flere ganger og aldri fått en sånn mail. Kan du legge ut mailen, kan jo stryke de delen du ikke vil vi skal se Lenke til kommentar
Labraxas Skrevet 2. juli 2006 Rapporter Del Skrevet 2. juli 2006 (endret) Jeg har fått en slik mail jeg og, bestilte vell for rett over tusen kroner. Sånn så denn ut: Klikk for å se/fjerne innholdet nedenfor Thank you for your recent order with Play.com. At Play.com, we value your custom and take your online security very seriously. With this in mind we have an additional security check in place for high value orders. To perform this check we ask that you contact our Large Order Department on 0845 800 1020 ( UK only ) or +44 (0)1534 877 595 ( outside UK ). Please have the card registered on the account to hand so that we can process your order as quickly as possible. Please accept our apologies for any inconvenience this may have caused you and thank you for your patience and valued custom. Kind Regards Play ************************************************************************** **** This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. Any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company. Finally, the recipient should check this email and any attachments for the presence of viruses. The company accepts no liability for any damage caused by any virus transmitted by this email. Play.com, PO Box 192, St Helier, Jersey JE4 8RP www.PLAY.com ************************************************************************** **** Edit: Jeg ringte bare det nummeret å leste opp bankkortnummer og litt div. Endret 25. februar 2008 av Bruckiania Lenke til kommentar
Manx Skrevet 2. juli 2006 Rapporter Del Skrevet 2. juli 2006 Da synes jeg at de begynner å bli veldig vansklige, så lenge det er penger på kortet så skal det vel ikke være noe problem. Er jo ikke verre enn at man begynner å dele opp ordrene i flere bestillinger... Skal de begynne med det tullet og ha lang leveringstid så er ikke veien så veldig lang til andre sjapper, men det er vel bare meg. Lenke til kommentar
Labraxas Skrevet 2. juli 2006 Rapporter Del Skrevet 2. juli 2006 Leveringstidene er et problem ja, men det andre greiene var vist bare for å forsikre seg om at jeg var den jeg var, de skyldte på min sikkerhet som kunde. Lenke til kommentar
Manx Skrevet 2. juli 2006 Rapporter Del Skrevet 2. juli 2006 Sikkerhet som kunde, handler jeg over nettet så er det en viss risk, de er vel redd for kort svindel. Men skal jeg prate med de som jeg handler fra, så kjører jeg meg en tur inn til den faste sjappa mi i Oslo... Lenke til kommentar
Mala Skrevet 2. juli 2006 Rapporter Del Skrevet 2. juli 2006 Mailen såg slik ut ja! Men eg fikk ring det nummeret eg! Fikk beskjed om at det ikkje var gyldig. MUlig eg har ringt feil? Litt uklart det nr. syns eg. Men ja, dette er no forbannet tullball Lenke til kommentar
Manx Skrevet 2. juli 2006 Rapporter Del Skrevet 2. juli 2006 Får du slettet orderen og lagt den inn i flere bestillinger. kan jo gjøre det og sjekke om du får en mail? Lenke til kommentar
Mala Skrevet 2. juli 2006 Rapporter Del Skrevet 2. juli 2006 (endret) Får du slettet orderen og lagt den inn i flere bestillinger. kan jo gjøre det og sjekke om du får en mail? 6423540[/snapback] Skal prøve å fjerne noen bestillinger no, så ka som skjer! EDIT: Bruckiania,eksakt hvilket nummer ringte du inn? Endret 2. juli 2006 av Mala Lenke til kommentar
Manx Skrevet 2. juli 2006 Rapporter Del Skrevet 2. juli 2006 Han må vel nesten ha ringt dette nummeret +44 (0)1534 877 595 siden det står outside uk bak Lenke til kommentar
Mala Skrevet 2. juli 2006 Rapporter Del Skrevet 2. juli 2006 Han må vel nesten ha ringt dette nummeret +44 (0)1534 877 595 siden det står outside uk bak 6423565[/snapback] Det nummeret kommer eg ingen vei med for å si det slik Lenke til kommentar
Labraxas Skrevet 2. juli 2006 Rapporter Del Skrevet 2. juli 2006 (endret) EDIT: Bruckiania,eksakt hvilket nummer ringte du inn? 6423555[/snapback] Jeg tok vell utgangspunkt i det andre nummeret, det er noen måneder siden så jeg husker ikke helt, men når jeg tenker meg om så mins jeg at jeg kuka litt for å få det til jeg og, noe med den nullen i parantes eller noe. Edit: prøvd 0044? Endret 2. juli 2006 av Bruckiania Lenke til kommentar
Mala Skrevet 2. juli 2006 Rapporter Del Skrevet 2. juli 2006 EDIT: Bruckiania,eksakt hvilket nummer ringte du inn? 6423555[/snapback] Jeg tok vell utgangspunkt i det andre nummeret, det er noen måneder siden så jeg husker ikke helt, men når jeg tenker meg om så mins jeg at jeg kuka litt for å få det til jeg og, noe med den nullen i parantes eller noe. Edit: prøvd 0044? 6423601[/snapback] Herlig! Det fungerte det der Men det var jo stengt no då. Biir å ringe i morra Lenke til kommentar
Fredrik Skrevet 2. juli 2006 Rapporter Del Skrevet 2. juli 2006 Høres merkelig ut, siden man bare kan legge inn flere små ordre for å slippe sånt tull. Play har fortsatt ikke forbedret leveringstiden? Er det noen som har nevnt for de at de er misfornøyd med leveringstiden? Om du, Manx, hadde gjort det hadde de nok hostet opp et svar, siden du sikkert har en relativt lang ordreliste hos Play. Lenke til kommentar
Manx Skrevet 2. juli 2006 Rapporter Del Skrevet 2. juli 2006 40 sider bør vel ha litt å si :!: Jeg har vurdert det, man de to siste gangene jeg har bestilt så tok det 6-7 dager og da synes jeg ikke at jeg kan klage. Selv om jeg har fått pakker fra amazon uk 2-3 dager og ezydvd i Australia på fem dager, raskere en pakker fra play. Men hvis det fortsetter sånn så bør de gjøre om det inne på sidene sine der står det fremdeles 3-5 dager... Jeg har en bestilling inne nå som ble sendt 26.6 så jeg kan jo vente å se hvor lang tid det tar, eller så er det vel på tide snart å legge inn en klage og henvise til leveringstidene til amazon uk Lenke til kommentar
Fredrik Skrevet 2. juli 2006 Rapporter Del Skrevet 2. juli 2006 Den største grunnen jeg ser til å eventuelt klage er om de var mye bedre før. Da har de tydeligvis enten a) ikke fulgt opp en økning av ordrer med nyansettelser o.l., b) gjort om rutinene sine til noe mer ineffektivt. Og begge deler er jo kritikkverdig, egentlig. Lenke til kommentar
Ceaucescu Skrevet 2. juli 2006 Rapporter Del Skrevet 2. juli 2006 Kwaidan - MoC #29 - ~150,- CdWow. Lenke til kommentar
Gjest Slettet+9817234daf Skrevet 3. juli 2006 Rapporter Del Skrevet 3. juli 2006 Tigerland - 79,- The English Patient - 59,- Full Frontal - 59,- Alt på Rimi. Lenke til kommentar
Mala Skrevet 3. juli 2006 Rapporter Del Skrevet 3. juli 2006 Da har eg ringt inn og fått ordnet opp hos play.com. Gah! Blir alltid så i godt humør når eg prater med briter, de er så hyggelige Lenke til kommentar
edge Skrevet 3. juli 2006 Rapporter Del Skrevet 3. juli 2006 Da har eg ringt inn og fått ordnet opp hos play.com. Gah! Blir alltid så i godt humør når eg prater med briter, de er så hyggelige 6427004[/snapback] Skjønner du hva de sier da? De er veldig hyggelige, høflige. Lenke til kommentar
Mala Skrevet 3. juli 2006 Rapporter Del Skrevet 3. juli 2006 Nei eg bare gjettet meg til ka de sa Litt artig å sitte å gjenta F for Freddy and S for sugar over tlf Lenke til kommentar
