Gentoo: Noen som gidder teste en ebuild for meg?
g++ -g -Wall -ansi -pedantic -fstrict-aliasing -DDEBUG -IlibMoaggGui/include -IlibMoaggGame/include -IlibMoaggObjects/include -I. -IlibMoaggCore/include -I/usr/include/SDL -D_REENTRANT -IlibMoaggSound/include -I. -IlibMoaggCore/include -I/usr/include/SDL -D_REENTRANT -I/usr/include/SDL -D_REENTRANT -IlibMoaggSound/include -I. -IlibMoaggCore/include -I/usr/include/SDL -D_REENTRANT -I/usr/include/SDL -D_REENTRANT -IlibMoaggSound/include -I. -IlibMoaggCore/include -I/usr/include/SDL -D_REENTRANT -I/usr/include/SDL -D_REENTRANT -I/usr/include/paragui -I/usr/lib/sigc++-1.2/include -I/usr/include/sigc++-1.2 -I/usr/include/freetype2 -I/usr/include/SDL -D_REENTRANT -I/usr/include/freetype2 -MD -MP -c libMoaggGui/src/CreditsMenu.cpp -o libMoaggGui/src/CreditsMenu.o
In file included from libMoaggGui/include/ControlMenu.h:4,
                from libMoaggGui/src/ControlMenu.cpp:4:
libMoaggGui/include/Menu.h:5:27: pgeventobject.h: Ingen slik fil eller filkatalog
libMoaggGui/include/Menu.h:13: error: parse error before `{' token
libMoaggGui/include/Menu.h: In function `void setPrevious(Menu*)':
libMoaggGui/include/Menu.h:18: error: `m_previous' undeclared (first use this
  function)
libMoaggGui/include/Menu.h:18: error: (Each undeclared identifier is reported
  only once for each function it appears in.)
libMoaggGui/include/Menu.h: At global scope:
libMoaggGui/include/Menu.h:25: error: parse error before `protected'
libMoaggGui/include/Menu.h:34: error: `Menu*m_previous' used prior to
  declaration
libMoaggGui/include/Menu.h:35: error: parse error before `}' token
In file included from libMoaggGui/include/ControlMenu.h:5,
libMoaggGui/include/KeyPressWidget.h:5:27: pgeventobject.h: Ingen slik fil eller filkatalog
libMoaggGui/include/KeyPressWidget.h:9: error: parse error before `{' token
libMoaggGui/include/KeyPressWidget.h:14: error: destructors must be member
  functions
libMoaggGui/include/KeyPressWidget.h:14: error: virtual outside class
  declaration
libMoaggGui/include/KeyPressWidget.h: In function `SDLKey getKey()':
libMoaggGui/include/KeyPressWidget.h:18: error: `m_key' undeclared (first use
  this function)
libMoaggGui/include/KeyPressWidget.h: At global scope:
libMoaggGui/include/KeyPressWidget.h:24: error: parse error before `protected'
libMoaggGui/include/KeyPressWidget.h:30: error: `SDLKey m_key' used prior to
  declaration
libMoaggGui/include/KeyPressWidget.h:34: error: parse error before `}' token
In file included from libMoaggGui/src/ControlMenu.cpp:4:
libMoaggGui/include/ControlMenu.h:9: error: base class `Menu' has incomplete
  type
libMoaggGui/include/ControlMenu.h:20: error: `onOk' was not declared in this
  scope
libMoaggGui/include/ControlMenu.h:20: error: invalid data member initialization
libMoaggGui/include/ControlMenu.h:20: error: (use `=' to initialize static data
  members)
libMoaggGui/include/ControlMenu.h:20: error: ISO C++ forbids declaration of `
  PARAGUI_CALLBACK' with no type
libMoaggGui/include/ControlMenu.h:21: error: `onCancel' was not declared in
  this scope
libMoaggGui/include/ControlMenu.h:21: error: invalid data member initialization
libMoaggGui/include/ControlMenu.h:21: error: ISO C++ forbids declaration of `
libMoaggGui/include/ControlMenu.h:21: error: declaration of `int
  ControlMenu::PARAGUI_CALLBACK'
libMoaggGui/include/ControlMenu.h:20: error: conflicts with previous
  declaration `int ControlMenu::PARAGUI_CALLBACK'
libMoaggGui/include/ControlMenu.h:23: error: syntax error before `*' token
libMoaggGui/include/ControlMenu.h:24: error: syntax error before `*' token
libMoaggGui/include/ControlMenu.h:25: error: syntax error before `*' token
libMoaggGui/include/ControlMenu.h:26: error: syntax error before `*' token
libMoaggGui/include/ControlMenu.h:27: error: syntax error before `*' token
libMoaggGui/include/ControlMenu.h:28: error: syntax error before `*' token
libMoaggGui/src/ControlMenu.cpp: In constructor `ControlMenu::ControlMenu()':
libMoaggGui/src/ControlMenu.cpp:13: error: `MSG_BUTTONCLICK' undeclared (first
  use this function)
libMoaggGui/src/ControlMenu.cpp:13: error: `MSG_CALLBACK_OBJ' undeclared (first
  use this function)
libMoaggGui/src/ControlMenu.cpp:13: error: `onOk' is not a member of type `
  ControlMenu'
libMoaggGui/src/ControlMenu.cpp:13: error: `SetEventObject' undeclared (first
  use this function)
libMoaggGui/src/ControlMenu.cpp:15: error: `onCancel' is not a member of type `
  ControlMenu'
libMoaggGui/src/ControlMenu.cpp:22: error: `m_thrustWidget' undeclared (first
  use this function)
libMoaggGui/src/ControlMenu.cpp:22: error: parse error before `(' token
libMoaggGui/src/ControlMenu.cpp:27: error: `m_alignWidget' undeclared (first
  use this function)
libMoaggGui/src/ControlMenu.cpp:27: error: parse error before `(' token
libMoaggGui/src/ControlMenu.cpp:32: error: `m_leftWidget' undeclared (first use
  this function)
libMoaggGui/src/ControlMenu.cpp:32: error: parse error before `(' token
libMoaggGui/src/ControlMenu.cpp:37: error: `m_rightWidget' undeclared (first
  use this function)
libMoaggGui/src/ControlMenu.cpp:37: error: parse error before `(' token
libMoaggGui/src/ControlMenu.cpp:42: error: `m_fireWidget' undeclared (first use
  this function)
libMoaggGui/src/ControlMenu.cpp:42: error: parse error before `(' token
libMoaggGui/src/ControlMenu.cpp:47: error: `m_pauseWidget' undeclared (first
  use this function)
libMoaggGui/src/ControlMenu.cpp:47: error: parse error before `(' token
libMoaggGui/src/ControlMenu.cpp:17: warning: unused variable `const
  PlayerConfiguration::Control::KeyConfig*kc'
libMoaggGui/src/ControlMenu.cpp: At global scope:
libMoaggGui/src/ControlMenu.cpp:75: error: `onOk' is not a member of type `
  ControlMenu'
libMoaggGui/src/ControlMenu.cpp:76: error: ISO C++ forbids declaration of `
libMoaggGui/src/ControlMenu.cpp:76: error: syntax error before `{' token
libMoaggGui/src/ControlMenu.cpp:79: error: syntax error before `->' token
libMoaggGui/src/ControlMenu.cpp:80: error: syntax error before `->' token
libMoaggGui/src/ControlMenu.cpp:81: error: syntax error before `->' token
libMoaggGui/src/ControlMenu.cpp:82: error: syntax error before `->' token
libMoaggGui/src/ControlMenu.cpp:83: error: syntax error before `->' token
libMoaggGui/src/ControlMenu.cpp:84: error: syntax error before `->' token
libMoaggGui/src/ControlMenu.cpp:86: error: syntax error before `->' token
libMoaggGui/src/ControlMenu.cpp:87: error: syntax error before `->' token
libMoaggGui/src/ControlMenu.cpp:88: error: syntax error before `->' token
libMoaggGui/src/ControlMenu.cpp:89: error: syntax error before `->' token
libMoaggGui/src/ControlMenu.cpp:90: error: syntax error before `->' token
libMoaggGui/src/ControlMenu.cpp:91: error: syntax error before `->' token
libMoaggGui/src/ControlMenu.cpp:93: error: ISO C++ forbids declaration of `
  getInstance' with no type
libMoaggGui/src/ControlMenu.cpp:93: error: prototype for `int
  PlayerConfiguration::getInstance()' does not match any in class `
  PlayerConfiguration'
libMoaggGame/include/PlayerConfiguration.h:584: error: candidate is: static
  PlayerConfiguration* PlayerConfiguration::getInstance()
libMoaggGui/src/ControlMenu.cpp:93: error: `int
  PlayerConfiguration::getInstance()' and `static PlayerConfiguration*
  PlayerConfiguration::getInstance()' cannot be overloaded
libMoaggGui/src/ControlMenu.cpp: In member function `int
  PlayerConfiguration::getInstance()':
libMoaggGui/src/ControlMenu.cpp:93: error: parse error before `->' token
libMoaggGui/src/ControlMenu.cpp:95: error: ISO C++ forbids declaration of `
libMoaggGui/src/ControlMenu.cpp:95: error: cannot declare member function `
  MenuManager::getInstance' within `PlayerConfiguration'
libMoaggGui/src/ControlMenu.cpp:95: error: syntax error before `->' token
libMoaggGui/src/ControlMenu.cpp:100: error: `onCancel' is not a member of type
  `ControlMenu'
libMoaggGui/src/ControlMenu.cpp:101: error: ISO C++ forbids declaration of `
libMoaggGui/src/ControlMenu.cpp:101: error: redefinition of `int
  PARAGUI_CALLBACK'
libMoaggGui/src/ControlMenu.cpp:76: error: `int PARAGUI_CALLBACK' previously
  defined here
libMoaggGui/src/ControlMenu.cpp:101: error: syntax error before `{' token
libMoaggGui/src/ControlMenu.cpp:103: error: syntax error before `->' token
libMoaggGui/src/ControlMenu.cpp:104: error: syntax error before `->' token
libMoaggGui/src/ControlMenu.cpp:105: error: syntax error before `->' token
libMoaggGui/src/ControlMenu.cpp:106: error: syntax error before `->' token
libMoaggGui/src/ControlMenu.cpp:107: error: syntax error before `->' token
libMoaggGui/src/ControlMenu.cpp:108: error: ISO C++ forbids declaration of `
libMoaggGui/src/ControlMenu.cpp:108: error: cannot declare member function `
libMoaggGui/src/ControlMenu.cpp:108: error: syntax error before `->' token
libMoaggGui/src/ControlMenu.cpp:114: error: cannot declare member function `
  ControlMenu::eventShow' within `PlayerConfiguration'
libMoaggGui/src/ControlMenu.cpp:114: error: syntax error before `{' token
libMoaggGui/src/ControlMenu.cpp:120: error: cannot declare member function `
  ControlMenu::eventHide' within `PlayerConfiguration'
libMoaggGui/src/ControlMenu.cpp:120: error: syntax error before `{' token
libMoaggGui/src/ControlMenu.cpp:126: error: cannot declare member function `
  ControlMenu::checkKeys' within `PlayerConfiguration'
libMoaggGui/src/ControlMenu.cpp:126: error: syntax error before `{' token
libMoaggGui/src/ControlMenu.cpp:128: error: `numKeys' undeclared (first use
  this function)
libMoaggGui/src/ControlMenu.cpp:129: error: ISO C++ forbids declaration of `
  keys' with no type
libMoaggGui/src/ControlMenu.cpp:129: error: ISO C++ forbids zero-size array `
  keys'
libMoaggGui/src/ControlMenu.cpp:129: error: conflicting types for `int keys[0]'
libMoaggGui/src/ControlMenu.cpp:128: error: previous declaration as `
  SDLKey*keys'
libMoaggGui/src/ControlMenu.cpp:130: error: ISO C++ forbids declaration of `
  keys' with no type
libMoaggGui/src/ControlMenu.cpp:130: error: conflicting types for `int keys[1]'
libMoaggGui/src/ControlMenu.cpp:129: error: previous declaration as `int
  keys[0]'
libMoaggGui/src/ControlMenu.cpp:131: error: ISO C++ forbids declaration of `
  keys' with no type
libMoaggGui/src/ControlMenu.cpp:131: error: conflicting types for `int keys[2]'
libMoaggGui/src/ControlMenu.cpp:130: error: previous declaration as `int
  keys[1]'
libMoaggGui/src/ControlMenu.cpp:132: error: ISO C++ forbids declaration of `
  keys' with no type
libMoaggGui/src/ControlMenu.cpp:132: error: conflicting types for `int keys[3]'
libMoaggGui/src/ControlMenu.cpp:131: error: previous declaration as `int
  keys[2]'
libMoaggGui/src/ControlMenu.cpp:133: error: ISO C++ forbids declaration of `
  keys' with no type
libMoaggGui/src/ControlMenu.cpp:133: error: conflicting types for `int keys[4]'
libMoaggGui/src/ControlMenu.cpp:132: error: previous declaration as `int
  keys[3]'
libMoaggGui/src/ControlMenu.cpp:134: error: ISO C++ forbids declaration of `
  keys' with no type
libMoaggGui/src/ControlMenu.cpp:134: error: conflicting types for `int keys[5]'
libMoaggGui/src/ControlMenu.cpp:133: error: previous declaration as `int
  keys[4]'
libMoaggGui/src/ControlMenu.cpp:137: error: parse error before `for'
libMoaggGui/src/ControlMenu.cpp:137: error: parse error before `;' token
libMoaggGui/src/ControlMenu.cpp:139: error: parse error before `;' token
make: *** [libMoaggGui/src/ControlMenu.o] Error 1
make: *** Waiting for unfinished jobs....
In file included from libMoaggGui/include/CreditsMenu.h:4,
                from libMoaggGui/src/CreditsMenu.cpp:1:
  function)
  declaration
In file included from libMoaggGui/src/CreditsMenu.cpp:1:
libMoaggGui/include/CreditsMenu.h:8: error: base class `Menu' has incomplete
  type
libMoaggGui/include/CreditsMenu.h:17: error: `onReturn' was not declared in
  this scope
libMoaggGui/include/CreditsMenu.h:17: error: invalid data member initialization
libMoaggGui/include/CreditsMenu.h:17: error: (use `=' to initialize static data
  members)
libMoaggGui/include/CreditsMenu.h:17: error: ISO C++ forbids declaration of `
libMoaggGui/src/CreditsMenu.cpp: In constructor `CreditsMenu::CreditsMenu()':
libMoaggGui/src/CreditsMenu.cpp:9: error: `MSG_BUTTONCLICK' undeclared (first
  use this function)
libMoaggGui/src/CreditsMenu.cpp:9: error: `MSG_CALLBACK_OBJ' undeclared (first
  use this function)
libMoaggGui/src/CreditsMenu.cpp:9: error: `onReturn' is not a member of type `
  CreditsMenu'
libMoaggGui/src/CreditsMenu.cpp:9: error: `SetEventObject' undeclared (first
  use this function)
libMoaggGui/src/CreditsMenu.cpp: At global scope:
libMoaggGui/src/CreditsMenu.cpp:28: error: `onReturn' is not a member of type `
  CreditsMenu'
libMoaggGui/src/CreditsMenu.cpp:29: error: ISO C++ forbids declaration of `
libMoaggGui/src/CreditsMenu.cpp:29: error: syntax error before `{' token
make: *** [libMoaggGui/src/CreditsMenu.o] Error 1
!!! ERROR: games-misc/moagg-0.12 failed.
!!! Function src_compile, Line 26, Exitcode 2
!!! (no error message)
Samme feil med CFLAGS/CXXFLAGS="" også.
bash-2.05b# emerge --info
Portage 2.0.50-r9 (default-x86-2004.0, gcc-3.3.4, glibc-2.3.4.20040619-r0, 2.6.7)
System uname: 2.6.7 i686 Intel(R) Pentium(R) 4 CPU 2.26GHz
Gentoo Base System version 1.5.1
Autoconf: sys-devel/autoconf-2.59-r4
Automake: sys-devel/automake-1.8.5-r1
ACCEPT_KEYWORDS="x86 ~x86"
AUTOCLEAN="yes"
CFLAGS="-march=pentium4 -O3 -pipe -fomit-frame-pointer -ffast-math"
CHOST="i686-pc-linux-gnu"
COMPILER="gcc3"
CONFIG_PROTECT="/etc /usr/X11R6/lib/X11/xkb /usr/kde/2/share/config /usr/kde/3.2/share/config /usr/kde/3/share/config /usr/lib/mozilla/defaults/pref /usr/share/config /var/qmail/control"
CONFIG_PROTECT_MASK="/etc/gconf /etc/terminfo /etc/env.d"
CXXFLAGS="-march=pentium4 -O3 -pipe -fomit-frame-pointer -ffast-math"
DISTDIR="/usr/portage/distfiles"
FEATURES="autoaddcvs ccache sandbox"
GENTOO_MIRRORS="ftp://ftp-stud.fht-esslingen.de/pub/Mirrors/gentoo ftp://mirrors.sec.informatik.tu-darmstadt.de/gentoo/ http://ftp.du.se/pub/os/gentoo http://mirror.gentoo.no/"
MAKEOPTS="-j2"
PKGDIR="/usr/portage/packages"
PORTAGE_TMPDIR="/var/tmp"
PORTDIR="/usr/portage"
PORTDIR_OVERLAY="/usr/local/portage"
SYNC="rsync://rsync.gentoo.org/gentoo-portage"
USE="X alsa arts avi berkdb cdr crypt cups dga encode foomaticdb gdbm gif gimpprint gphoto2 gpm gstreamer gtk gtk2 imlib java joystick jpeg kde libg++ libwww mad mikmod mmx motif mozilla moznocompose moznoirc moznomail mpeg ncurses nls nptl oggvorbis ooo-kde opengl pam pdflib perl pic png python qt quicktime readline samba sdl slang spell sse ssl svga tcpd truetype x86 xml2 xmms xv zlib"
Paragui-1.1.7-ebuilden har forøvrig et problem, da den ikke inkluderer libsigc++-1.2.5 som "dependency", og vil feile under configure om en ikke installerer libsigc++-1.2.5 først.
Endret av drall
