Freevo og feilmelding
Hei. Når jeg prøver å skrive kommandoen "python setup.py install" Så får jeg feilmeldingen:
inux:/home/qwseyvnd/Documents/freevo-1.5-rc4 # python setup.py runtime
Traceback (most recent call last):
File "setup.py", line 15, in ?
from util.distribution import setup, Extension, check_libs, docbook_finder
File "./src/util/distribution.py", line 128, in ?
fp, pathname, description = imp.find_module('distutils' , sys.path[1:])
ImportError: No module named distutils
linux:/home/qwseyvnd/Documents/freevo-1.5-rc4 #
Hva er feil?
runtime hjalp ikke, nå har jeg nytt problem om Imaging-1.1.4
linux:~/Imaging-1.1.4 # python setup.py install
running install
running build
running build_py
creating build
creating build/lib.linux-i686-2.3
copying PIL/XbmImagePlugin.py -> build/lib.linux-i686-2.3
copying PIL/MpegImagePlugin.py -> build/lib.linux-i686-2.3
copying PIL/ImageFont.py -> build/lib.linux-i686-2.3
copying PIL/ImageTransform.py -> build/lib.linux-i686-2.3
copying PIL/PaletteFile.py -> build/lib.linux-i686-2.3
copying PIL/ContainerIO.py -> build/lib.linux-i686-2.3
copying PIL/GdImageFile.py -> build/lib.linux-i686-2.3
copying PIL/MspImagePlugin.py -> build/lib.linux-i686-2.3
copying PIL/ImageFilter.py -> build/lib.linux-i686-2.3
copying PIL/DcxImagePlugin.py -> build/lib.linux-i686-2.3
copying PIL/ExifTags.py -> build/lib.linux-i686-2.3
copying PIL/ImageGrab.py -> build/lib.linux-i686-2.3
copying PIL/ImageSequence.py -> build/lib.linux-i686-2.3
copying PIL/Image.py -> build/lib.linux-i686-2.3
copying PIL/PsdImagePlugin.py -> build/lib.linux-i686-2.3
copying PIL/ImagePath.py -> build/lib.linux-i686-2.3
copying PIL/SunImagePlugin.py -> build/lib.linux-i686-2.3
copying PIL/ImagePalette.py -> build/lib.linux-i686-2.3
copying PIL/MicImagePlugin.py -> build/lib.linux-i686-2.3
copying PIL/GbrImagePlugin.py -> build/lib.linux-i686-2.3
copying PIL/ImImagePlugin.py -> build/lib.linux-i686-2.3
copying PIL/FliImagePlugin.py -> build/lib.linux-i686-2.3
copying PIL/TarIO.py -> build/lib.linux-i686-2.3
copying PIL/ArgImagePlugin.py -> build/lib.linux-i686-2.3
copying PIL/PalmImagePlugin.py -> build/lib.linux-i686-2.3
copying PIL/IptcImagePlugin.py -> build/lib.linux-i686-2.3
copying PIL/PpmImagePlugin.py -> build/lib.linux-i686-2.3
copying PIL/IcoImagePlugin.py -> build/lib.linux-i686-2.3
copying PIL/PcfFontFile.py -> build/lib.linux-i686-2.3
copying PIL/PSDraw.py -> build/lib.linux-i686-2.3
copying PIL/TiffTags.py -> build/lib.linux-i686-2.3
copying PIL/ImageOps.py -> build/lib.linux-i686-2.3
copying PIL/BdfFontFile.py -> build/lib.linux-i686-2.3
copying PIL/ImtImagePlugin.py -> build/lib.linux-i686-2.3
copying PIL/SgiImagePlugin.py -> build/lib.linux-i686-2.3
copying PIL/TgaImagePlugin.py -> build/lib.linux-i686-2.3
copying PIL/WalImageFile.py -> build/lib.linux-i686-2.3
copying PIL/PngImagePlugin.py -> build/lib.linux-i686-2.3
copying PIL/PixarImagePlugin.py -> build/lib.linux-i686-2.3
copying PIL/ImageWin.py -> build/lib.linux-i686-2.3
copying PIL/GimpGradientFile.py -> build/lib.linux-i686-2.3
copying PIL/ImageColor.py -> build/lib.linux-i686-2.3
copying PIL/ImageChops.py -> build/lib.linux-i686-2.3
copying PIL/ImageDraw.py -> build/lib.linux-i686-2.3
copying PIL/OleFileIO.py -> build/lib.linux-i686-2.3
copying PIL/BmpImagePlugin.py -> build/lib.linux-i686-2.3
copying PIL/PcxImagePlugin.py -> build/lib.linux-i686-2.3
copying PIL/JpegImagePlugin.py -> build/lib.linux-i686-2.3
copying PIL/XVThumbImagePlugin.py -> build/lib.linux-i686-2.3
copying PIL/CurImagePlugin.py -> build/lib.linux-i686-2.3
copying PIL/EpsImagePlugin.py -> build/lib.linux-i686-2.3
copying PIL/ImageEnhance.py -> build/lib.linux-i686-2.3
copying PIL/PcdImagePlugin.py -> build/lib.linux-i686-2.3
copying PIL/__init__.py -> build/lib.linux-i686-2.3
copying PIL/TiffImagePlugin.py -> build/lib.linux-i686-2.3
copying PIL/ImageFileIO.py -> build/lib.linux-i686-2.3
copying PIL/WmfImagePlugin.py -> build/lib.linux-i686-2.3
copying PIL/PdfImagePlugin.py -> build/lib.linux-i686-2.3
copying PIL/FontFile.py -> build/lib.linux-i686-2.3
copying PIL/FpxImagePlugin.py -> build/lib.linux-i686-2.3
copying PIL/GimpPaletteFile.py -> build/lib.linux-i686-2.3
copying PIL/XpmImagePlugin.py -> build/lib.linux-i686-2.3
copying PIL/GifImagePlugin.py -> build/lib.linux-i686-2.3
copying PIL/ImageFile.py -> build/lib.linux-i686-2.3
copying PIL/ImageTk.py -> build/lib.linux-i686-2.3
copying PIL/McIdasImagePlugin.py -> build/lib.linux-i686-2.3
copying PIL/ImageStat.py -> build/lib.linux-i686-2.3
running build_ext
building '_imaging' extension
creating build/temp.linux-i686-2.3
gcc -pthread -fno-strict-aliasing -DNDEBUG -g -O3 -Wall -Wstrict-prototypes -fPIC -IlibImaging -I/usr/local/include/python2.3 -c outline.c -o build/temp.linux-i686-2.3/outline.o
In file included from libImaging/Imaging.h:21,
from outline.c:27:
libImaging/ImPlatform.h:14:2: #error Sorry, this library requires support for ANSI prototypes.
libImaging/ImPlatform.h:17:2: #error Sorry, this library requires ANSI header files.
libImaging/ImPlatform.h:35:2: #error Cannot find required 32-bit integer type
libImaging/ImPlatform.h:47:2: #error Cannot find required 32-bit floating point type
In file included from outline.c:27:
libImaging/Imaging.h:86: error: parse error before "INT32"
libImaging/Imaging.h:86: warning: no semicolon at end of struct or union
libImaging/Imaging.h:98: error: parse error before '}' token
libImaging/Imaging.h:239: warning: type defaults to `int' in declaration of `FLOAT32'
libImaging/Imaging.h:239: error: parse error before '*' token
libImaging/Imaging.h:240: warning: function declaration isn't a prototype
libImaging/Imaging.h:365: error: parse error before "ImagingCRC32"
libImaging/Imaging.h:365: error: parse error before "crc"
libImaging/Imaging.h:365: warning: type defaults to `int' in declaration of `ImagingCRC32'
libImaging/Imaging.h:365: warning: function declaration isn't a prototype
libImaging/Imaging.h:365: warning: data definition has no type or storage class
error: command 'gcc' failed with exit status 1
Dette er feilmeldingen.
Runtime funket ikke? Den funker ikke på 2.6 kjerne vet jeg. Men da kan du bruke
denne guiden:
http://freevo.sourceforge.net/cgi-bin/moin...e_2fInstallDeps
Følger du den SKAL det virke. Følg den til punkt og prikke. Jeg anbefaler deg riktignok og sjekke om det finnes nyere versjoner av de enkelte programmene der. Spesielt er det viktig at du velger en nyere utgave av MMPython siden Freevo 1.5.0 krever det. Ellers går det faktisk greit og bruke de versjonene som det er linket til på WIKIen.
Og ja, det tar tid og compile alle den softwaren der.
Hvilken distro benytter du ?
Endret av neonX
En ny problem med Imaging-1.1.4
linux:~/Imaging-1.1.4 # python setup.py build && python setup.py install
running build
running build_py
running build_ext
gcc -pthread -shared build/temp.linux-i686-2.3/_imaging.o build/temp.linux-i686-2.3/decode.o build/temp.linux-i686-2.3/encode.o build/temp.linux-i686-2.3/map.o build/temp.linux-i686-2.3/display.o build/temp.linux-i686-2.3/outline.o build/temp.linux-i686-2.3/path.o -LlibImaging -lImaging -ljpeg -lz -o build/lib.linux-i686-2.3/_imaging.so
building '_imagingtk' extension
creating build/temp.linux-i686-2.3/Tk
gcc -pthread -fno-strict-aliasing -DNDEBUG -D_FILE_OFFSET_BITS=64 -DHAVE_LARGEFILE_SUPPORT -O2 -march=i586 -mcpu=i686 -fmessage-length=0 -Wall -fPIC -IlibImaging -I/usr/include/python2.3 -c Tk/tkImaging.c -o build/temp.linux-i686-2.3/Tk/tkImaging.o
Tk/tkImaging.c:49:16: tk.h: Ingen slik fil eller filkatalog
Tk/tkImaging.c:69: error: parse error before "clientdata"
Tk/tkImaging.c: In function `PyImagingPhoto':
Tk/tkImaging.c:73: error: `Tk_PhotoHandle' undeclared (first use in this function)
Tk/tkImaging.c:73: error: (Each undeclared identifier is reported only once
Tk/tkImaging.c:73: error: for each function it appears in.)
Tk/tkImaging.c:73: error: parse error before "photo"
Tk/tkImaging.c:74: error: `Tk_PhotoImageBlock' undeclared (first use in this function)
Tk/tkImaging.c:76: error: `argc' undeclared (first use in this function)
Tk/tkImaging.c:77: warning: implicit declaration of function `Tcl_AppendResult'
Tk/tkImaging.c:77: error: `interp' undeclared (first use in this function)
Tk/tkImaging.c:77: error: `argv' undeclared (first use in this function)
Tk/tkImaging.c:79: error: `TCL_ERROR' undeclared (first use in this function)
Tk/tkImaging.c:83: error: `photo' undeclared (first use in this function)
Tk/tkImaging.c:83: warning: implicit declaration of function `Tk_FindPhoto'
Tk/tkImaging.c:115: error: `block' undeclared (first use in this function)
Tk/tkImaging.c:141: error: parse error before "run"
Tk/tkImaging.c:144: warning: implicit declaration of function `Tk_PhotoBlank'
Tk/tkImaging.c:147: error: `run' undeclared (first use in this function)
Tk/tkImaging.c:171: warning: implicit declaration of function `Tk_PhotoPutBlock'
Tk/tkImaging.c:190: error: `TCL_OK' undeclared (first use in this function)
Tk/tkImaging.c: At top level:
Tk/tkImaging.c:195: error: parse error before '*' token
Tk/tkImaging.c: In function `TkImaging_Init':
Tk/tkImaging.c:197: warning: implicit declaration of function `Tcl_CreateCommand'
Tk/tkImaging.c:197: error: `interp' undeclared (first use in this function)
Tk/tkImaging.c:198: error: `ClientData' undeclared (first use in this function)
Tk/tkImaging.c:198: error: parse error before numeric constant
