La datamaskinen gjette hva du tenker på.
sybbelybb
HAHAHA!! prøvde dildo. LES!
I am guessing that it is a bratwurst?
Yes , No , Close
19. Does it involve contact with other humans? No.
18. Do you clean it regularly? Yes.
17. Does it have a handle? No.
16. Does it get wet? Yes.
15. Is it straight? Yes.
14. Do you use it in your home? Yes.
13. Do you hold it when you use it? Yes.
12. Is it used in a sport? No.
11. Is it made of metal? Sometimes.
10. Is it considered valuable? No.
9. Was it used over 100 years ago? No.
8. Can you put something into it? No.
7. Is it larger than a microwave oven (or bread box)? No.
6. Can you hold it? Yes.
5. Is it smaller than a loaf of bread? No.
4. Can you find it in a church? No.
3. Was it invented? Yes.
2. Can it make a sound? Yes.
1. Can you control it? Yes.
It is classified as Unknown.
Denne var jo genial! Hadde aldri trodd den skulle klare vannpumpe :thumbup:
Tenkte da på en vannkjølingspumpe.
I am guessing that it is a water pump?
Yes , No , Close
19. Would you find it on a farm? Doubtful.
18. Can you switch it on and off? Yes.
Does it come in different colors? Unknown.
17. Does it contain a liquid? Yes.
16. Is it shiny? No.
15. Is it smaller than a loaf of bread? No.
14. Does it get wet? Yes.
13. Does it have a hole in it? Yes.
12. Is it made of metal? Yes.
Is it round? Unknown.
Do you use it in your home? Unknown.
11. Would you use it daily? Probably.
10. Is it larger than a microwave oven (or bread box)? No.
9. Would you find it in an office? No.
8. Can you use it with your friends? No.
7. Is it manufactured? Yes.
6. Was it used over 100 years ago? Yes.
5. Would you give it as a gift? Doubtful.
4. Do you hold it when you use it? No.
3. Can it bend without breaking? No.
2. Do you know any songs about it? No.
1. It is classified as Other.
hva faen er en manx cat... jeg tenkte på en siameser Ffs :p
hehe :ermm:
Edit : Aegd... ^^
You were thinking of a siamese cat.
Would you find it on a farm? You said Sometimes, I say No.
Can it swim? You said Yes, I say No.
Would you give it as a gift? You said No, I say Yes.
Can it be used more than once? You said No, I say Yes.
Can it bend without breaking? You said Doubtful, I say Probably.
Is it heavier than a pound of butter? You said Unknown, I say Yes.
Can it be dried? You said Probably, I say No.
Does it usually hunt for food at night? You said Yes, I say No.
Can you put something into it? You said Yes, I say No.
Do you hold it when you use it? You said Irrelevant, I say Yes.
Is it ferocious? You said Maybe, I say No.
Edit 2 : den sa det kanskje var en Torsk... hva fean
Edit 3 : fun fact:
Uncommon Knowledge about a siamese cat
Is it a synthetic material? I say Probably.
Is it made of metal? I say Probably.
Is it electronic? I say Probably.
Does it photosynthesize? I say Probably.
Does it beep? I say Yes.
Does it have bumpy skin? I say Probably.
Can you switch it on and off? I say Probably.
Is it usually green? I say Probably.
Do you make pie from it? I say Yes.
Does it smell good? I say Probably.
Is it found on a desk? I say Yes.
Is it originally from the Mediterranian? I say Yes.
Is it round? I say Probably.
Can it be used to season foods? I say Yes.
Can you open it? I say Probably.
Is it originally from Canada? I say Probably.
Endret av AmmO
You were thinking of a pint of beer.
Is it small? You said No, I say Yes. :p
Would you use it daily? You said Unknown, I say No. Neiok :) (visste ikke hva jeg skulle svar)
Would you give it as a gift? You said Yes, I say No. Neivel?
Do you use it at night? You said No, I say Yes. Ikke mens jeg sover nei...
Can it bend without breaking? You said Unknown, I say No. Hva det for et spørsmål?
Does it go inside other things? You said No, I say Yes. Huh?
Can you open it? You said No, I say Yes Kan jo ikke åpne en vel halvliter (pint).
You were thinking of a bottle of beer.
Does it have writing on it? You said No, I say Yes.
Is it something you bring along? You said Irrelevant, I say Yes.
Is it combustible? You said Unknown, I say No.
You were thinking of a driver's license. <-- denne var faktisk utrolig imponerende
Does it come in different colors? You said No, I say Yes.
Does it get wet? You said Yes, I say No.
Was it used over 100 years ago? You said Yes, I say No.
Can you walk on it? You said Yes, I say Doubtful.
You were thinking of a poop. <-- det er bæsj sant? :blush:
Does it bring joy to people? You said Yes, I say No.
Do you use it in your home? You said Yes, I say No.
Does it come in different colors? You said Rarely, I say Yes.
Endret av RolfOve
I am guessing that it is a puffin?
Yes ,  No , Close
28.    Can you buy it at a store? No.
27.    Can it fit in an envelope? No.
26.    Is it a scavenger? No.
25.    Is it something you can purchase? Yes.
24.    Does it live in groups (gregarious)? Yes.
23.    Is it smaller than a loaf of bread? Yes.
22.    Does it live in water? Yes.
21.    Is it black? Yes.
20.    I guess it a blue-footed booby? No.
19.    Can it affect you (cause an effect to you)? No.
18.    Does it have feathers? Yes.
17.    Is it colorful? Yes.
16.    Is it a vegetarian? No.
15.    Does it have four legs? No.
14.    Does it swim? Yes.
13.    Does it have teeth? No.
12.    Can it live out of water? Yes.
11.    Is it brown? No.
10.    Does it have short fur? Irrelevant.
9.    Would you find it on a farm? No.
8.    Can it swim? Yes.
7.    Is it warm blooded? Yes.
6.    Can you buy it? Yes.
5.    Can you see it in a zoo? Sometimes.
4.    Does it have a tail? Yes.
3.    Can it jump? Doubtful.
2.    Is it small? Yes.
1.    It is classified as Animal.
tok 28 spørsmål men fortsatt imponerendes..
og btw, den siden/tingen lærer av feilene sine, så selv om den bommer på f. eks skrutrekker nå greier den det senere når den har fått mer informasjon om hva en skrutrekker er osv.
(mulig noen har sagt dette før, orker ikke lese alle postene ;)
I am guessing that it is a tram?
Yes , No , Close
19. Can it be used for recreation? No.
18. Can it be washed? Yes.
17. Was it used over 100 years ago? Yes.
16. I guess it a limousine (chauffeur-driven sedan)? No.
15. Is it a specific color? No.
14. Is it smooth? Yes.
13. Does it roll? Yes.
12. Is it pleasurable? Yes.
11. Can you walk on it? No.
10. Can you buy it at a store? No.
9. Can you control it? Yes.
8. Would you find it on a farm? No.
7. Can you put something into it? Yes.
6. Does it contain a liquid? No.
5. Is it comforting? Yes.
4. Can you hold it? No.
3. Does it display information? No.
2. Does it usually have four corners? Yes.
1. Does it grow over time? No.
Glup den saken der, hadde til og med rett!
