Nyttig Firefox Tweak.
b-real
Firefox Tweaks
Type "about :config" in the adress field.
Set the value of network.http.pipelining boolean "true"
Set the value of network.http.pipelining.maxrequests integer 100
Set the value of network.http.proxy.pipelining boolean "true"
network.http.max-connections integer 60
network.http.max-connections-per-server integer 32
network.http.max-persistent-connections-per-proxy integer 16
network.http.max-persistent-connections-per-server integer 8
Now watch as the loading times that already beat IE's go into overkill mode.
Skal vist fungere meget bra.
