Microsoft blows it again.
Roamer
Microsoft has been caught out in its Australian market once again.
It seems that its HDTV pack, designed to enable game-playing on high-definition TV sets, is in fact incompatable with Australian television standards and has been withdrawn for shortfalls in performance.
X-Box spokesperson Simon Balderstone said, "The HDTV pack does not enable HDTV in Australia since the highest resolution in Australia is 480i". "The progressive scan modes aren't enabled on the Australian system, so you can't get to the level of expected benefit here", he added.
Mr Balderstone insisted, however, that Microsoft' HDTV pack was not to blame for the performance problems, but rather the existing, local HDTV standard was at fault because it capped resolution at a much lower level than the resolution level enabled by the HDTV pack overseas.
However, Professor Duane Varan, from Murdoch University's Interactive Television Research Institute, stated that there should be no problems with achieving higher resolution levels on Australian HDTV. While 480i is the standard PAL resolution, he said, "Australian HD televisions can handle 1080i, which is the Cadillac of high-definition".
Professor Varan suggested that Microsoft probably tried to release an HDTV pack designed to Advanced Television Systems Committee (ATSC) standards, which set television standards for the US. By contrast, Australia used the the Digital Video Broadcasting (DVB) standard.
"The monitor shouldn't be an issue, but it might be an issue to modify the Australian pack to accept DVB standards," Professor Varan said
_______________
Microsoft, in other words, are blaming the problem on Australia's supposedly lower resolution standards. While the 480i named by the X-Box spokesperson is a PAL stadard, however, it does not mark the limit to Australian HDTV capacity, since HDTV monitors can be set to handle multiple resolutions. The problem, it seems, is that Microsoft tried to release an HDTV pack set to US standards, without modifying it to Australia's Digital Video Broadcasting (DVB) standard.
Source: The Australian
Nei nei, for all del. Men, det begynner å balle på seg litt nå da. Med riper i spillene i Japan, en del feil ved noen Xbox'er ved lansering i USA hvor folk ikke fikk en ny xbox før en måned etterpå og nå Australia. Blir spennede å se hva slags tabbe som vil ramme Europa, kanskje et eller annet med online tjenesten.
Antageligvis er det bare Microsoft som har vært uheldige.
Det er faktiskt ganske vanelig at ny hardware har problemer. Men vi hører ikke så mye om de, siden de fleste firmaer ikke har hetsing kampanje mot seg som MS har. Som PS2 f.eks. Kjenner i hvert fall 2 som har problemer med sin PS2 og måtte levere inn flere ganger.. De har også fått ødelagte spill. Men feilen MS gjorde var at de ikke erstatett det med en gang, det de burde gjort. Også siden de har en hetsing kampanje mot seg, så må man være kritisk til det man leser om de også. Ikke alt er sant...
PS2, som PSone, er ikke akkurat av ypperste kvalitet den heller nei. Kjenner nesten ingen som ikke har hatt problemer med PSone, og har lest mye på nettet om problemer med PS2. Men, så lenge folk fortsetter å kjøpe PS2 så er det ikke noe problem for Sony.
Noen som har en anelse om hvor lang garantien er på de nyeste konsollene?
