Spørsmål om Slackware 10
Slackware 10.0 Installation ISO disc 1
Slackware 10.0 Installation ISO disc 2 (GNOME/KDE/KDEI, /testing, live rescue disc)
Slackware 10.0 ISO disc 3 (Sources part 1, /extra , Slackware book)
Slackware 10.0 ISO disc 4 (Sources part 2, ZipSlack, /pasture)
Hvis man ikke bruker gnome eller kde holder det med cd1. Denne inneholder bl.a xfce, blackbox og fluxbox
hva er zip slack? noen som kan forklare det?
Jeg fant dette på google:
ZipSlack is a special edition of Slackware Linux that can be installed onto any FAT (or FAT32) filesystem with about 100 MB of free space. It uses the UMSDOS filesystem and contains most of the programs you will need. This means that you do not need to repartition your hard disk if you already have DOS or Windows installed. ZipSlack installs into a directory on your DOS filesystem. It can also be installed to and booted from a Zip disk.
