kan noen hjelpe mg og få en L-bot til CS clanen mi
da har du ikke gjort alt, du trenger en auth så qnet vet hvem du er.
Creates a new user account in the bot. Note that there are *NO HOSTMASKS* on this bot. Other bots allow you to ident if you just know the password, so this one just uses the password and scraps the hostmask as pointless.
Usage: /MSG Q HELLO <[email protected]> <[email protected]>
You need to specify your email address TWICE (to prevent typing mistakes) as parameters, a generated password will then be sent to the address mentioned, allowing you to AUTH to Q (see the AUTH command description for more details).
This will identify you on the bot as until you quit from IRC.
Usage: /MSG [email protected] AUTH <username> <password>
eg. /MSG [email protected] AUTH John 4321John
