CS:Source BETA 1 - Litt info
  • When will Counter-Strike: Source beta 1 be released?
    Starting later this summer, Valve will be conducting a limited-time beta of Counter-Strike: Source via Steam.
  • How can I get Counter-Strike: Source beta 1?
    The beta will first be open to subscribers of the Valve Cyber Café Program, and then extended to owners of Counter-Strike: Condition Zero.
  • I am a member of the Valve Cyber Café Program, or I own Condition Zero. How will I know when Counter-Strike: Source beta 1 is available?
    When the Counter-Strike: Source beta begins, it will appear in your Steam My Games list.
  • Can I get access to the beta if I am not part of the Valve Cyber Café Program, and do not own Condition Zero?
    No.
  • How will Counter-Strike: Source be different from the Half-Life 1 based Counter-Strike?
    CS: Source blends the intense teamplay of Counter-Strike with the advance technology of Valve’s Source engine.
  • What will the system requirements be for Counter-Strike: Source?
    Min:
      1.2 GHz Processor
      256MB RAM
      DirectX 7 graphics card
      Windows 2000/XP/ME/98
      Mouse
      Keyboard
    Preferred:
      2.4 GHz ProcessorB  512MB RAM
      DirectX 9 graphics card
      Windows 2000/XP
      Mouse
      Keyboard
  • Do I get to keep Counter-Strike: Source after the beta period has ended?
    No.
Kilde: Steampowered.com
http://www.halflife2.net/forums/showthread.php?t=27293
Thx to Seaofp of Naircs.net and Stylenetwork, the spec of the PCs they used has been informed...welll only 3 core parts....I mean...-.-)a
CPU : Intel 2.4c
RAM : 1Gigabytes
GPU : ATI x800 pro 256
The fps was between 60 to 80 on de_aztec when it's played with 4 vs 4 format.
Merk at de bruke en celeron-prosessor.. Ikke pentium.
Uansett synes jeg dette var lavt, de må da ha aktivert AA og AF her..
CPU : Intel 2.4c
RAM : 1Gigabytes
Hvor får du at de brukte en Celeron fra? Meg bekjent er 2.4C P4 med C-stepping. Noen som vet åssen oppløsning de spiller i? Det her lovde ikke bra... Skal liksom mitt 9800XT være gammelt og ubrukelig nå da :(
Gjest Slettet-80wCWpIM
pentium 2,4c er 800mhz fsb p4 ja.
a=400 (??)
b=533
c=800
nestemann på lista er prescott.
disse tallene kan UMULIG representere tilstanden i f.eks half life 2,det høres mye ut at man må ha 2,4c,1gb ram + x800pro 256mb for å få mellom 60-80fps..det ser isåfall stygt ut hvis det ikke eksisterer skikkelige forklaringer på dette, for hl2 skal være visuelt bedre + flere småting i forhold til cs på source engine.
2,4a eksisterer(eller, ikke nå lenger).
i "gamle dager" hadde jeg valget mellom å kjøpe en 2,4a eller 2,4b.
Får håpe mitt oppsett klarer CS:Source greit da..
Abit NF7 V2.0 nForce2 Ultra400
AMD Athlon XP2500+ Barton @ XP3200+ @ 2.2ghz
TwinMOS 1024MB PC3200 DDR-minne
WD Caviar 160GB HDD 8MB Cache
Sapphire Radeon 9800PRO @ 9800XT
Endret av razh0r
Så hvor mange kan man spille XvsX?
16v16 blir litt for mye tipper jeg.
CPU : Intel 2.4c
RAM : 1Gigabytes
Det var 4vs4, tenk hvis man har fler da og litt dårligere oppsett.
Eller kanskje jeg som er dum her :blush:
