Anandtech tester Soltek nForce3 250GB
Les testen her
Final Words
After thorough stress testing and general usage, we have come to several conclusions. The first conclusion is that the vast majority of users who have any interest at all in a fast 64-bit system should seriously consider the Soltek EQ3801. Users interested in a quiet system will be delighted to hear that the EQ3801 is quite silent, while using all the stock settings and hardware that comes with this SFF. Normally, you'd have to sacrifice performance and/or low temperatures for a silent SFF; yet the EQ3801 is both a high performance and low temperature system. Soltek's patented STF (System Tunnel Fan) does an excellent job of pushing hot air over the CPU HSF and out of the side of the case. And when tuning the BIOS properly, the EQ3801 is only a step behind the fastest equivalent Athlon 64 desktop systems on the market.
The EQ3801 literally contains the whole package: quiet, cool, small, and fast. At its current price of just $270 shipped online, it's also a bargain too. In fact, the Soltek EQ3801 is significantly cheaper than Athlon 64 SFFs from most other manufacturers, including the industry leader, Shuttle. All in all, the EQ3801 is an impressive feat of smart engineering and we see no reason why you shouldn't be seriously exploring this satisfying barebones system.
:yes::w00t::yes:
Kan kjøpes her: http://www.databutikken.com/no/default.php?artId=SOLEQ3801A
Endret av JEG76
Å, jeg vil ha! Hvis jeg ikke går for s939, så gjett om jeg skal ha den der! Den er nydelig, i tillegg til at det er nforce 3 250gb :D
Lurer på om shuttle følger etter med en enda bedre? :hmm:
Herr Brun
Fikk bra anmeldelse, ja!
Såg en annen anm. der de mente den ble varm, men denne siten er "mindre merritert" enn Anandtech.
EDIT: Mp nevnes at du får cpu vifte og bære bag med (stod det på Solteks hp).
Endret av JEG76
  • 3 uker senere...
Jeg har tenkt å bestille en sånn!
SFFtech.com har for øvrig et eget forum for SOLTEK Qbic-serien. Der finner man mange personlige erfaringer med denne.
Stort dett bra. Noen sier de har problem med temparaturmålingene i bios, men en update fra soltek fikset visstnok dette. (håper det stemmer, jeg venter spent på min egen barebone fra soltek nå..)
