Vi har ikke merket noe til det, og har fått oppdatert det vi har av NOD32.
Du har ikke installert noen brannmur eller kanskje oppdatert en du allerede har?
Husk at NOD32 oppdaterer seg hver time som default, og det kan godt hende at man får failure noen ganger.
Time Module Event User
07.07.2004 12:26:46 Update Update attempt terminated with error (Server connection failure)
07.07.2004 11:26:46 Update Update attempt terminated with error (Server connection failure)
07.07.2004 10:26:46 Update Update attempt terminated with error (Server connection failure)
07.07.2004 09:26:46 Update Update attempt terminated with error (Server connection failure)
06.07.2004 21:27:00 Kernel The virus signature database has been updated successfully to version 1.805 (20040706).
06.07.2004 20:26:33 Update Update attempt terminated with error (Server connection failure)
06.07.2004 13:26:31 Update Update attempt terminated with error (Server connection failure)
06.07.2004 11:26:31 Update Update attempt terminated with error (Server connection failure)
06.07.2004 09:26:31 Update Update attempt terminated with error (Server connection failure)
06.07.2004 08:26:32 Update Update attempt terminated with error (Server connection failure)
06.07.2004 02:26:32 Update Update attempt terminated with error (Server connection failure)
05.07.2004 23:26:59 Kernel The virus signature database has been updated successfully to version 1.804 (20040705).
05.07.2004 17:28:13 Kernel The virus signature database has been updated successfully to version 1.803 (20040705).
05.07.2004 16:50:09 Update Update attempt terminated with error (Server connection failure) ESBEN\Lautsprecher
05.07.2004 16:26:31 Update Update attempt terminated with error (Server connection failure)
05.07.2004 16:00:35 Update Update attempt terminated with error (Server connection failure) ESBEN\Lautsprecher
05.07.2004 16:00:21 Update Update attempt terminated with error (Server connection failure) ESBEN\Lautsprecher
05.07.2004 15:28:03 Update Update attempt terminated with error (Server connection failure) ESBEN\Lautsprecher
05.07.2004 15:27:45 Update Update attempt terminated with error (Server connection failure) ESBEN\Lautsprecher
05.07.2004 15:26:04 Update Update attempt terminated with error (Server connection failure)
Får oppdaterten gang i blant, men som du ser klarer NOD32 sjelden å få kontakt med serverne. Ingen brannmur(Kun NAT).
Jøss, det var mange failures. Jeg sjekket min egen Nod32 event log, og hadde bare noen få failures over mange dager.
Har du satt opp Nod'en til å "Choose automatically" i Update setup?
Da velges det fra flere servere.
Har du merket generell ustabilitet på internett-linja di?
