ROFLcopter ! !
AssKicR
Sikkert OLD, men det var skamløye :p
You are an elite ROFLER. Your ROFLcopter has strayed into LOLLERskater territory and they have sent wave after wave of LOLLERskaters and LMAOplanes to destroy you and your ROFLcopter.
The aim of the game is to kill as many LOLLERskaters and LMAOplanes before they kill you. Use the WASD keys ( default ) to control your ROFLcopter, use THE MOUSE and RIGHT CLICK to aim and shoot your ROFLing gun. Press SPACE ( default ) to drop a WTFbomb, press "Q" or "E" to launch an OMGmissile. Combo kills with WTFbombs and OMGmissiles will result in multiplied score advances.
Also at your disposal is the BBLshield, press and HOLD SHIFT ( default ) to activate the shield, DEPRESS SHIFT to deactivate.
Clickie
Gjest Slettet-p4PIYwb6
85780! :D Ganske moro
