Hjelp til å tyde feil
Unhandled Exception: System.NullReferenceException: Object reference not set to
an instance of an object.
  at std.ios_base._Init(ios_base* )
  at std.basic_ios<char,std::char_traits<char> >.init(basic_ios<char,std::char_
traits<char> >* , basic_streambuf<char,std::char_traits<char> >* _Strbuf, Boolea
n _Isstd) in e:\installed\visual studio.net architect edition enterprise\vc7\inc
lude\ios:line 130
  at std.basic_ostream<char,std::char_traits<char> >.__ctor(basic_ostream<char,
std::char_traits<char> >* , basic_streambuf<char,std::char_traits<char> >* _Strb
uf, Boolean _Isstd, Int32 _Isstd) in e:\installed\visual studio.net architect ed
ition enterprise\vc7\include\ostream:line 45
  at std.basic_iostream<char,std::char_traits<char> >.__ctor(basic_iostream<cha
r,std::char_traits<char> >* , basic_streambuf<char,std::char_traits<char> >* _St
rbuf, Int32 _Strbuf) in e:\installed\visual studio.net architect edition enterpr
ise\vc7\include\istream:line 806
  at std.basic_fstream<char,std::char_traits<char> >.__ctor(basic_fstream<char,
std::char_traits<char> >* , SByte* _Filename, Int32 _Mode, Int32 _Mode) in e:\in
stalled\visual studio.net architect edition enterprise\vc7\include\fstream:line
623
  at main(Int32 argc, SByte** argv) in c:\documents and settings\magnus\mine do
kumenter\visual studio projects\geek5_aa\geeky.cpp:line 63
Tror feilen ligger her:
(Det er en 'systemNullReferenceException')
  fstream foo("hoho.jpg", ios::out|ios::binary|ios::app);
foo.write(buffer, strlen(buffer));
foo.close();
'buffer' har fått en del binærdata lagret i seg tidligere i programmet. kanskje jeg må bruke en 'reinterpret_cast<char &>(buffer)' eller noe??
bufferhar fungert tidligere i programmet, og er deklarert slik:
char* buffer = new char[];
Kompileres ikke v.h.a. GCC-3.4.0: error: expected primary-expression before ']' token
Noe slikt:
char* buffer = new char[10];
delete[](buffer);
Men lurt å ta en titt i boka ja. :]
Endret av søppel
[qutoe]'buffer' har fått en del binærdata lagret i seg tidligere i programmet.
jeg vet ikke størrelsen på den, så jeg har ikke noe tall å oppgi
Hvis du fortsatt holder på med den oppgaven du hadde i tidligere post, trenger du ikke lese inn hele fila. Uansett må du lagre størrelsen på dataene du leser inn i buffer samtidig som du leser inn.
struct Data {
 char* data;
 unsigned int size;
Hoho, den forrige oppgaven var en lure-oppgave, men jeg driver med noe liknende: les inn ei fil, xor decrypt, bytt ut noen verdier og lagre som noe.jpg
jeg gjør dette for å lese inn, hvordan kan jeg modifisere det til å lagre størrelsen samtidig som jeg leser inn ??
ifstream in("data.bin", fstream::binary);
while(!in.eof()){
in.get(reinterpret_cast<char &>(buffer));
edit: bare legge inn i loopen at den øker 'size' med én hver gang?? slik:
struct Data {
       char* data;
       unsigned int size;
while(!in.eof()){
       size += 1;
Endret av Zethyr
ja, det får programmet mitt til å fungere :)
neida, det endrer datatypen midlertidig, right ? (typecast ?)
ps: det er jeg selv som har skrevet den biten, ikke noe jeg hentet fra noe sted... Jeg har lest en stor bok om c++, men har glemt ca. 40 %... derfor spør jeg her for å friske opp kunnskapen, ikke for å få beskjed om å lese alt på nytt ;) Husker mest av det jeg leste sist, så det grunnlegende er borte. Husker mer om f.eks. multiple inheritance osv... :blush:
Endret av Zethyr
heh.
Det får programmet ditt til å kompilere. Så supert.
Kompilatoren din sier "nei jeg vil ikke ta imot en char*, jeg vil ha en char&"
Når du da caster sier du "det driter jeg i. jeg vet bedre enn deg din dumme kompilator."
Hva med å f.eks gjøre in.get(buffer); eller in.get(*buffer); istedetfor å caste? casting er stygt og det fører til feil når du ikke vet hvordan det funker
