Stort problem. Hijacked
Har fått ett stort problem. Når jeg skal inn på google og hotbot så får jeg opp en blå side med følgende tekst:
Detected SPYware! System error #384
__________________________________________________________________________
Your IP address is "tatt vekk". Using this address a remote computer has gained anaccess to your computer and probably is collecting the information about the sites you've visited and the files contained in the folder Temporary Internet Files. Attention! Ask for help or install the software for deleting secret information about the sites you visited.
Your computer is full of evidences!
ISP of transmission: 154
Your IP address: tatt vekk
They know you're using: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; .NET CLR 1.1.4322)
Your computer is: Windows XP
Risk status for further investigation: VERY HIGH RISK
To protect from the Spyware - click here
To prevent information transmission  - click here
To delete the history of your activity, click here
Er linken til http://www.e-shredder.com/enter.phtml?wm=wwwilly
Har også en fil i c:\windows som heter secure.html som linker videre til pornosider.
Hostfila mi endres også. Får ikke endret den tilbake til det orginale.
Den ser sånn ut:
127.0.0.1 thehun.com
127.0.0.1 www.thehun.com
127.0.0.1 thehun.net
127.0.0.1 www.thehun.net
127.0.0.1 www.yahoo.com
127.0.0.1 yahoo.com
127.0.0.1 www.google.com
127.0.0.1 google.com
127.0.0.1 www.altavista.com
127.0.0.1 altavista.com
127.0.0.1 search.microsoft.com
127.0.0.1 search.msn.com
127.0.0.1 www.msn.com
127.0.0.1 msn.com
127.0.0.1 www.search.com
127.0.0.1 search.com
127.0.0.1 www.teoma.com
127.0.0.1 teoma.com
127.0.0.1 www.alltheweb.com
127.0.0.1 alltheweb.com
127.0.0.1 www.wisenut.com
127.0.0.1 wisenut.com
127.0.0.1 www.dmoz.org
127.0.0.1 dmoz.org
127.0.0.1 www.excite.com
127.0.0.1 excite.com
127.0.0.1 www.lycos.com
127.0.0.1 lycos.com
127.0.0.1 www.hotbot.com
127.0.0.1 hotbot.com
127.0.0.1 www.casino.com
127.0.0.1 casino.com
Er det noen som vet hvordan jeg skal bli kvitt dette shitet.Har kjørt både adaware og spybot + diverse andre.
Endret av Moony
CWShredder
A small utility for removing CoolWebSearch (aka CoolWwwSearch, YouFindAll, White-Pages.ws and a dozen other names). Spybot S&D tends to forget essential parts of the hijack, so until it updates, you can just this to completely remove the hijack. Updated to remove the new variants once they come out.
Any known information regarding CoolWebSearch can be found in the CoolWebSearch Chronicles.
If you find a system scan by SpybotS&D indicates CoolWebSearch present but does not effectively remove it download and run CWShredder.
cwshredder_big.gifDownload CWShredder Now
