notarget Skrevet 30. juni 2004 Del Skrevet 30. juni 2004 (endret) Grafikk motoren til HL2 klarer å takle 256 spillere i multiplayer! Det var 'bare' 64 i HL1. Obs: Det vil ikke si at HL2 sin multiplayer vil ha støtte for det, men tallet viser hva man kan modde source motoren til. Sitat fra Rick i Valve While the engine is setup to handle 256 players (was only 64 in HL1), I don't think you'd be successful running that many, you might be fine running 128, you'd have to test it. The reason is CPU and bandwidth. With a single server handling all of the transactions at the speed at which they need to happen, there may just simply not be enough horsepower to handle that many players. Rick Valve Just a NOTE PEOPLE! This information has nothing to do with the ammount of players that valve will have supported in what ever multiplayer they make. These numbers are what the source engine could be modded too. Det er mange spillere! Så til dere som lager mods til HL2, da veit dere hva dere kan gjøre mer EDIT: Endret topic! Endret 30. juni 2004 av notarget Lenke til kommentar
Döden Skrevet 30. juni 2004 Del Skrevet 30. juni 2004 Holy shait! *Useless respond* Sykt da! Lenke til kommentar
