fdisk i bashscript
Ønsker meg et script som lager partisjoner og filsystem automatisk.
Altså, lager en 30MB boot partisjon med ext2, 1GB swap, 3GB / reiserfs, resten av disken med reiserfs for /home.
Er det mulig å lage et script som gjør dette?
Fdisk ser ikke ut til å være egna for bruk i script.
acona:/usr/src# sfdisk
sfdisk version 3.07 ([email protected], 990908)
Usage: sfdisk [options] device ...
device: something like /dev/hda or /dev/sda
useful options:
   -s [or --show-size]: list size of a partition
   -c [or --id]:        print or change partition Id
   -l [or --list]:      list partitions of each device
   -d [or --dump]:      idem, but in a format suitable for later input
   -i [or --increment]: number cylinders etc. from 1 instead of from 0
   -uS, -uB, -uC, -uM:  accept/report in units of sectors/blocks/cylinders/MB
   -T [or --list-types]:list the known partition types
   -D [or --DOS]:       for DOS-compatibility: waste a little space
   -R [or --re-read]:   make kernel reread partition table
   -N# :                change only the partition with number #
   -n :                 do not actually write to disk
   -O file :            save the sectors that will be overwritten to file
   -I file :            restore these sectors again
   -v [or --version]:   print version
   -? [or --help]:      print this message
dangerous options:
   -g [or --show-geometry]: print the kernel's idea of the geometry
   -x [or --show-extended]: also list extended partitions on output
                            or expect descriptors for them on input
   -L  [or --Linux]:      do not complain about things irrelevant for Linux
   -q  [or --quiet]:      suppress warning messages
   You can override the detected geometry using:
   -C# [or --cylinders #]:set the number of cylinders to use
   -H# [or --heads #]:    set the number of heads to use
   -S# [or --sectors #]:  set the number of sectors to use
You can disable all consistency checking with:
   -f  [or --force]:      do what I say, even if it is stupid
Skulle gå an å lage et script med dette programmet :)
Ikke om det er 20 maskiner....
- Men Laaknor, trenger jo ikke kjøre noen partisjon! Det finnes nemlig, CD'er osv som du kan kjøre fra......
Eller så kan du ha flere harddisker! ;) Tenke litt lengre enn din egen pc med distro installert vettu ;]
Den vil jo gjøre endringene på systemet som er aktivt akkurat nå....
Om det skal være til å formatere flere maskiner ville jeg hatt større tro på imaging eller kixstart i anaconda (noen flere distroer som har støtte for det?)
Booting vha PXE er et godt alternativ om man vil installere linux på mange maskiner. Men det er sikkert litt mer fiklete å sette opp en redhats kickstart-konfigurasjon... Men som vi alle vet er "fikling" ofte halve moroa ;)
http://www.kegel.com/linux/pxe.html
*warning* kickstart er fucka (i alle fall i FC2, med den confen jeg gav den, sum BURDE være i orden - se bugzilla for anaconda/kickstart-generator)
Forøvrig er installering over NFS en veldig fin ting: Du legger ut ISO-ene på NFS-server, booter med cd1/bootcd/bootdisketter. Så velger du "linux et-eller-annet-mediaselect" - og taster inn ip og path på NFS-serveren. Så laster den anaconda og du kan ta ut cd'n og gå videre til neste boks :D.
Nyttig å ha instalasjons script på en server, som man bare laster over, så gjøres alt av install av seg selv. Spess nyttig bilr det når man skal ha alt kompilert fra kildekode.
Om scriptet feiler og sletter diskene er det ikke større skade skjedd enn at disken er like blank som den var før scriptet ble kjørt.
Sliter litt med å scripte kjerne config siden det er litt forskjell på hardware på de forskjellige maskinene. Men det kan jeg leve med.
