FLuAA Skrevet 28. juni 2004 Del Skrevet 28. juni 2004 Har endra på XF86Config og får fint æøå i KDE, men i Fluxbox og i Gnome får jeg ikke æøå. Noen som vet hva som er galt? Lenke til kommentar
FLuAA Skrevet 28. juni 2004 Forfatter Del Skrevet 28. juni 2004 Tastaturdelen av configen ser slik ut Identifier "Keyboard" Option "XkbModel" "pc104" Option "XkbLayout" "no" Driver "keyboard" EndSection Lenke til kommentar
kyrsjo Skrevet 28. juni 2004 Del Skrevet 28. juni 2004 Poster min (hele, fra FC2), som jeg VET fungerer finfint: [root@kyrre root]# cat /etc/X11/xorg.conf # Xorg configuration created by system-config-display Section "ServerLayout" Identifier "single head configuration" Screen 0 "Screen0" 0 0 InputDevice "Mouse0" "CorePointer" InputDevice "Keyboard0" "CoreKeyboard" EndSection Section "Files" # RgbPath is the location of the RGB database. Note, this is the name of the # file minus the extension (like ".txt" or ".db"). There is normally # no need to change the default. # Multiple FontPath entries are allowed (they are concatenated together) # By default, Red Hat 6.0 and later now use a font server independent of # the X server to render fonts. RgbPath "/usr/X11R6/lib/X11/rgb" FontPath "unix/:7100" EndSection Section "Module" Load "dbe" Load "extmod" Load "fbdevhw" Load "glx" Load "record" Load "freetype" Load "type1" Load "dri" EndSection Section "InputDevice" # Specify which keyboard LEDs can be user-controlled (eg, with xset(1)) # Option "Xleds" "1 2 3" # To disable the XKEYBOARD extension, uncomment XkbDisable. # Option "XkbDisable" # To customise the XKB settings to suit your keyboard, modify the # lines below (which are the defaults). For example, for a non-U.S. # keyboard, you will probably want to use: # Option "XkbModel" "pc102" # If you have a US Microsoft Natural keyboard, you can use: # Option "XkbModel" "microsoft" # # Then to change the language, change the Layout setting. # For example, a german layout can be obtained with: # Option "XkbLayout" "de" # or: # Option "XkbLayout" "de" # Option "XkbVariant" "nodeadkeys" # # If you'd like to switch the positions of your capslock and # control keys, use: # Option "XkbOptions" "ctrl:swapcaps" # Or if you just want both to be control, use: # Option "XkbOptions" "ctrl:nocaps" # Identifier "Keyboard0" Driver "keyboard" Option "XkbModel" "pc105" Option "XkbLayout" "no" EndSection Section "InputDevice" Identifier "Mouse0" Driver "mouse" Option "Protocol" "IMPS/2" Option "Device" "/dev/input/mice" Option "ZAxisMapping" "4 5" Option "Emulate3Buttons" "yes" EndSection Section "Monitor" Identifier "Monitor0" VendorName "Monitor Vendor" ModelName "Compaq V900 Color Monitor" DisplaySize 350 270 HorizSync 30.0 - 96.0 VertRefresh 48.0 - 160.0 Option "dpms" EndSection Section "Device" Identifier "Videocard0" # Driver "nv" Driver "nvidia" Option "IgnoreDisplayDevices" "DFP, TV" VendorName "Videocard vendor" BoardName "NVIDIA GeForce 2 MX (generic)" EndSection Section "Screen" Identifier "Screen0" Device "Videocard0" Monitor "Monitor0" DefaultDepth 24 SubSection "Display" Viewport 0 0 Depth 24 Modes "1280x1024" "1280x960" "1152x864" "1024x768" "800x600" "640x480" EndSubSection EndSection Section "DRI" Group 0 Mode 0666 EndSection Lenke til kommentar
EinarEriksen Skrevet 2. juli 2004 Del Skrevet 2. juli 2004 Har endra på XF86Config og får fint æøå i KDE, men i Fluxbox og i Gnome får jeg ikke æøå. Noen som vet hva som er galt? Er bare å endre til no_NO.ISO8859-1 i i18n. Skal vel ligge i /etc/sysconfig/ ? --- Hvis /etc/sysconfig/i18n ser for eksempel slik ut fungerer det perfekt. LANG="no_NO.ISO8859-1"SUPPORTED="en_US.UTF-8:en_US:en:no_NO.ISO8859-1:no_NO:no" SYSFONT="latarcyrheb-sun16" --- Logg deg inn som root, og for eksempel 'vi /etc/sysconfig/i18n' og legg til no_NO.ISO8850-1. Lenke til kommentar
FLuAA Skrevet 2. juli 2004 Forfatter Del Skrevet 2. juli 2004 Er bare å endre til no_NO.ISO8859-1 i i18n. Skal vel ligge i /etc/sysconfig/ ? --- Hvis /etc/sysconfig/i18n ser for eksempel slik ut fungerer det perfekt. LANG="no_NO.ISO8859-1"SUPPORTED="en_US.UTF-8:en_US:en:no_NO.ISO8859-1:no_NO:no" SYSFONT="latarcyrheb-sun16" --- Logg deg inn som root, og for eksempel 'vi /etc/sysconfig/i18n' og legg til no_NO.ISO8850-1. /etc/sysconfig eksisterer ikke, ii18n eksisterer heller ikke Lenke til kommentar
EinarEriksen Skrevet 3. juli 2004 Del Skrevet 3. juli 2004 Rart, men det er vel ikke alle distribusjoner som har sysconfig. i18n finnes mange plasser, og alle unntatt én er crap som ikke har noe med akkurat det å gjøre. Hvilken distro har du egentlig? Prøv å se om du finner en fornuftig i18n. locate i18n Se bare igjennom til du eventuelt finner en som har "lang=" Lenke til kommentar
