Kjøp av forsterker
heisann.
Det er en kammerat fatter kjenner som skal selge en forsterker Elder Pro Audio System T-3000 Power Amplifier
2000 Watt RMS!
Jeg har da ikke så mye peiling på forsterke såjeg tenkte jeg skulle spørre noen av dere...
Her er noen spec
Stereo (RMS): 2x550W/8 0hm, 2x900W/4 0hm
- Stereo (Peak power): 2x780W/8 0hm, 2x1270W/4 0hm
- Bridged mono (RMS): 1800W/8 0hm, 2000w/4 0hm
- Bridged mono (Peak power): 2550W/8 0hm, 2830w/4 0hm
- 3U rack mounting
- Overheat, overload and short circuit protection
- Innovative heatsink structure
- Accurate signal amplifier, high S/N ratio
- Frequency response: 20Hz-50kHz (0.1dB)
- Sensitivity: line 0.775V
- Distortion: <0.03%
- Input impedance: 10k ohm/20k ohm
- S/N ratio: >105dB
- Slew rate: >25V/us
- Damping factor: >400
- Dimensions (W x D x H): 485 x 445 x 130mm
- Packing dimensions (W x D x H): 550 x 540 x 230mm
- Net weight: 31kg
- Gross weight: 32kg
Technical parameters
  Stereo (RMS)  2x550W/8 0hm  2x900W/4 0hm
Bridged mono (RMS)  1800W/8 0hm    2000w/4 0hm
Stereo (Peak power)  2x780W/8 0hm  2x1270W/4 0hm
Bridged mono (Peak power)  2550W/8 0hm    2830w/4 0hm
Frequency response  20Hz~50KHz(±0.1dB)
Sensitivity  Line 0.775V
Distortion  <0.03%
Input Impedance  10KOhm/20K0hm
S/N ratio  >105dB
Slew Rate  >25V/us
Damping factor  >400
Dimension(WXDXHmm/Pcs)  485X445X130mm
Packaging Dimension(WXDXHmm/Pcs)  550X540X230mm
Net weight(kg/Pcs)  31kg
Gross weight(Kg/Pcs)  32kg
ca pris er 1500kr bør je slå till...
