Første gangs oppladning
Lithium-ion is a low maintenance battery, an advantage that most other chemistries cannot claim. There is no memory and no scheduled cycling is required to prolong the battery's life. In addition, the self-discharge is less than half compared to nickel-cadmium, making lithium-ion well suited for modern fuel gauge applications. lithium-ion cells cause little harm when disposed.
http://www.batteryuniversity.com/partone-5.htm
Simple Guidelines
Avoid frequent full discharges because this puts additional strain on the battery. Several partial discharges with frequent recharges are better for lithium-ion than one deep one. Recharging a partially charged lithium-ion does not cause harm because there is no memory. (In this respect, lithium-ion differs from nickel-based batteries.)
Short battery life in a laptop is mainly caused by heat rather than charge/discharge patterns.
Although memory-free, apply a deliberate full discharge once every 30 charges to calibrate batteries with fuel gauge. Running down the battery in the equipment does this. If ignored, the fuel gauge will become increasingly less accurate. The battery life will not be affected.
Keep the lithium-ion battery cool. Avoid a hot car. For prolonged storage, keep the battery at a 40% charge level.
Consider removing the battery from a laptop when running on fixed power. (Some laptop manufacturers are concerned about dust and moisture accumulating inside the battery casing.)
Avoid purchasing spare lithium-ion batteries for later use. Observe manufacturing date. Do not buy old stock, even if sold at clearance prices.
http://www.batteryuniversity.com/parttwo-34.htm
SE T630 har forresten et Liithium-ion-polymer batteri.
Endret av Lungemannen
På sonyericsson.no leste jeg om noen "tøffe karer" som hevdet at teleofnen skulle være avslått de første gangene man ladet, og at laderen skulle taes ut og settes inn igjen, slik at den kan lades videre. Dette for å utnytte batteriet mest mulig.
Men jeg stiller meg tvilende til den påstanden. Har aldri hørt den før, og alle kjennere, samt selgere og support sier noe helt annet.
