Er dette en grei oppgradering?
Joda, bra det. Men hva koster Radeon x800PRO?
EDIT: Aj, trodde det sto 9800XT. Bra oppsett. Men hvilken ram er det der? (Sjekker selv forresten...)
Sjekket. Fant ikke noe særlig. Hvorfor koster den så mye?
Endret av surbz00r
surbz00r:
fant litt info om denne ram'en..
GeIL Golden Dragon DDR Series' high speed is achieved from GeIL industry-leading engineering technology: Wafer Level Chip Scale Package (WLCSP). Each chip is directly mounted to the module PCB in its original wafer format and die size without any type of conventional packaging. Thus, there are no soldering legs as with the conventional method. This breakthrough technology would not only dramatically reduce the electro-magnetic noise, but the module also produces very little heat under stressed operation. The end result is high bus clock speed and low operational temperature. No heat spreader is required. And because of its low electro-magnetic noise (EMC), when equipped, the computer receives higher system-wide stability and greater over-clocking potential.
Du trenger også nytt HK ! socket 754 eller 939 ??
foreslår 754 p.g.a. at 939 er nettop kommet ut og kan ha "barenesykdommer"
Hvis du ser EKSTRA nøye etter så ser du at jeg faktisk hadde HK med på oppsettet... Det heter MSI K8N Neo Platinum.
Var du trøtt eller bare bakfull når du skrev innlegget? :p
Neida bare tuller...
