Port problemer og C&C Generals
Command & Conquer: Generals
TCP: 80, 6667, 28910, 29900, 29920 UDP: 4321, 27900
Firewall/NAT Port Number Info:
The game will need to talk to external servers that use the following port numbers.
These ports need to be open in your firewall in order to play on Generals Online:
TCP ports:
UDP ports:
4321, 27900
If your firewall does not allow outgoing packets to open ports to incoming traffic,
or you experience problems connecting to other players, you will have to specify
which port you want Command & Conquer Generals to use for communicating with other
players. To do this, perform the following steps.
Go to your "My Documents" directory, and go to the "Command and Conquer Generals
Data" directory. Right click on the options.ini file and choose "Edit."
Look for the "FirewallPortOverride" entry. If you don't see this entry, add it as a
new line. Then assign the port you want to use to the port override entry. After
making this change, this entry should look like:
FirewallPortOverride = XXXX
Where XXXX is the port number you have chosen. You will need to open the chosen
port in your firewall for communication with players external to your firewall or
NAT device. If you use the port override feature, the port you have chosen can not
be masqueraded by a NAT device.
hentet fra Relativt.net
Har internett fra NGT med netopia 3351 ruter.
Brukte telnet å la in (i følge relativt.net sine anvisninger) port nr.
TCP ports:
80, 6667, 28910, 29900, 29920, 9590(FirewallPortOverride)
UDP ports:
4321, 27900
Til ip adresse 10.0.0.2, som er min ip.
Jeg la også til FirewallPortOverride = 9550 til i ini filen.
Inne på options i spillet står det "online ip: 10.0.0.2" det stemmer jo ikke... Men jeg finner ikke ut hva som er galt. Noen som vet?
