dynamisk disk
Her er en liten definisjon på dynamisk disk :smile:
Dynamic disk storage supports volume-oriented disks. A dynamic disk is a physical disk that contains dynamic volumes. With dynamic disks, you have the ability to create simple volumes, volumes that span multiple disks (spanned and striped volumes), and fault-tolerant volumes (mirrored and RAID-5 volumes). Dynamic disks can contain an unlimited number of volumes.
When you move a dynamic disk to a computer that has no dynamic disks, the dynamic disk retains its disk group name and ID from the original computer and uses them on the local computer.
