kan noen hjelpe meg med å pinge
D:\>ping 69.56.170.199
Pinger 69.56.170.199 med 32 byte data:
Svar fra 69.56.170.199: byte=32 tid=203ms TTL=48
Svar fra 69.56.170.199: byte=32 tid=202ms TTL=48
Ping-statistikker for 69.56.170.199:
Pakker: sendt = 4, mottatt = 4, tapt = 0 (0% tap),
Gjennomsnittlig tid for tur-retur i millisekunder:
minimum = 202ms, maksimum = 203ms, gjennomsnittlig = 202ms
D:\>ping 69.93.113.69
Pinger 69.93.113.69 med 32 byte data:
Svar fra 69.93.113.69: byte=32 tid=203ms TTL=48
Svar fra 69.93.113.69: byte=32 tid=202ms TTL=48
Ping-statistikker for 69.93.113.69:
D:\>
pinger fra isdn her lykke til :w00t:
Edit: Tele2 ISDN, Bergensområde
Endret av Angelboy
[root@Tallulah /]# ping 69.93.113.69
PING 69.93.113.69 (69.93.113.69) 56(84) bytes of data.
64 bytes from 69.93.113.69: icmp_seq=0 ttl=44 time=466 ms
64 bytes from 69.93.113.69: icmp_seq=1 ttl=44 time=441 ms
64 bytes from 69.93.113.69: icmp_seq=2 ttl=44 time=449 ms
64 bytes from 69.93.113.69: icmp_seq=3 ttl=44 time=443 ms
--- 69.93.113.69 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3031ms
rtt min/avg/max/mdev = 441.712/450.415/466.045/9.541 ms, pipe 2
[root@Tallulah /]# ping 69.56.170.199
PING 69.56.170.199 (69.56.170.199) 56(84) bytes of data.
64 bytes from 69.56.170.199: icmp_seq=0 ttl=44 time=379 ms
64 bytes from 69.56.170.199: icmp_seq=1 ttl=44 time=396 ms
64 bytes from 69.56.170.199: icmp_seq=2 ttl=44 time=395 ms
64 bytes from 69.56.170.199: icmp_seq=3 ttl=44 time=387 ms
--- 69.56.170.199 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3034ms
rtt min/avg/max/mdev = 379.308/389.683/396.539/7.080 ms, pipe 2
Telenor ADSL Ekstra 2048/256 Kb/s, Lillehammer
edit: hører med til historien at det blir spilt ET over samme linjene samtidig som jeg pinget
Endret av thelittlewitch
{sim@snorkel:~}$ ping -c 4 69.93.113.69
64 bytes from 69.93.113.69: icmp_seq=1 ttl=44 time=445 ms
64 bytes from 69.93.113.69: icmp_seq=2 ttl=44 time=539 ms
64 bytes from 69.93.113.69: icmp_seq=3 ttl=44 time=410 ms
64 bytes from 69.93.113.69: icmp_seq=4 ttl=44 time=402 ms
4 packets transmitted, 4 received, 0% packet loss, time 2999ms
rtt min/avg/max/mdev = 402.338/449.282/539.442/54.473 ms
{sim@snorkel:~}$ ping -c 4 69.56.170.199
64 bytes from 69.56.170.199: icmp_seq=1 ttl=44 time=383 ms
64 bytes from 69.56.170.199: icmp_seq=2 ttl=44 time=407 ms
64 bytes from 69.56.170.199: icmp_seq=3 ttl=44 time=431 ms
64 bytes from 69.56.170.199: icmp_seq=4 ttl=44 time=430 ms
rtt min/avg/max/mdev = 383.001/413.380/431.798/19.964 ms
he he takk uansett.prøver å finne ut av hvem som gir meg best ping på disse serverne som ligger i usa,da det er de jeg spiller mest på :D
ligger på 150 nå men skal flytte så jeg må bestille ny leverandør.
Endret av (ODIN)
64 bytes from 69.93.113.69: icmp_seq=1 ttl=46 time=153 ms
64 bytes from 69.93.113.69: icmp_seq=2 ttl=46 time=153 ms
64 bytes from 69.93.113.69: icmp_seq=3 ttl=46 time=153 ms
64 bytes from 69.93.113.69: icmp_seq=4 ttl=46 time=153 ms
4 packets transmitted, 4 received, 0% packet loss, time 3004ms
rtt min/avg/max/mdev = 153.739/153.850/153.933/0.288 ms
64 bytes from 69.56.170.199: icmp_seq=1 ttl=46 time=154 ms
64 bytes from 69.56.170.199: icmp_seq=2 ttl=46 time=153 ms
64 bytes from 69.56.170.199: icmp_seq=3 ttl=46 time=153 ms
64 bytes from 69.56.170.199: icmp_seq=4 ttl=46 time=153 ms
4 packets transmitted, 4 received, 0% packet loss, time 3001ms
rtt min/avg/max/mdev = 153.801/153.930/154.111/0.412 ms
Det var rett og slett utrolig trege servere... Jeg sitter på Uninett med 100Mbps.
Pinging 69.93.113.69 with 32 bytes of data:
Reply from 69.93.113.69: bytes=32 time=181ms TTL=48
Reply from 69.93.113.69: bytes=32 time=180ms TTL=48
Reply from 69.93.113.69: bytes=32 time=185ms TTL=48
Reply from 69.93.113.69: bytes=32 time=183ms TTL=48
Ping statistics for 69.93.113.69:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 180ms, Maximum = 185ms, Average = 182ms
Pinging 69.56.170.199 with 32 bytes of data:
Reply from 69.56.170.199: bytes=32 time=182ms TTL=48
Reply from 69.56.170.199: bytes=32 time=181ms TTL=48
Reply from 69.56.170.199: bytes=32 time=180ms TTL=48
Ping statistics for 69.56.170.199:
    Minimum = 180ms, Maximum = 182ms, Average = 181ms
Tele2 ADSL 704/128 kb, Sandnes
Ikke trege... Langt borte!
Firstmile Carl Berner Oslo
Svar fra 69.56.170.199: byte=32 tid=642ms TTL=49
Svar fra 69.56.170.199: byte=32 tid=574ms TTL=49
Svar fra 69.56.170.199: byte=32 tid=592ms TTL=49
Svar fra 69.56.170.199: byte=32 tid=579ms TTL=49
minimum = 574ms, maksimum = 642ms, gjennomsnittlig = 596ms
Svar fra 69.93.113.69: byte=32 tid=524ms TTL=49
Svar fra 69.93.113.69: byte=32 tid=537ms TTL=49
Svar fra 69.93.113.69: byte=32 tid=544ms TTL=49
Svar fra 69.93.113.69: byte=32 tid=574ms TTL=49
minimum = 524ms, maksimum = 574ms, gjennomsnittlig = 544ms
E:\>ping 69.56.170.199
Reply from 69.56.170.199: bytes=32 time=166ms TTL=43
Reply from 69.56.170.199: bytes=32 time=168ms TTL=43
Reply from 69.56.170.199: bytes=32 time=165ms TTL=43
Reply from 69.56.170.199: bytes=32 time=169ms TTL=43
Minimum = 165ms, Maximum = 169ms, Average = 167ms
Hordaland. 800\128
Holder til i Bergen, og har gratis bredbånd via UIB :D
Svar fra 69.56.170.199: byte=32 tid=156ms TTL=46
Svar fra 69.56.170.199: byte=32 tid=157ms TTL=46
minimum = 156ms, maksimum = 157ms, gjennomsnittlig = 156ms
Svar fra 69.93.113.69: byte=32 tid=156ms TTL=46
Svar fra 69.93.113.69: byte=32 tid=157ms TTL=46
Svar fra 69.93.113.69: byte=32 tid=155ms TTL=46
minimum = 155ms, maksimum = 157ms, gjennomsnittlig = 156ms
28000/28000 (ifølge speedometer hos itavisen.no)
Endret av Sigurd2
Catch skal gi best ping, mener å ha lest her på forumet at NGT har elendig ping (til spillservere).
Knuser i allfall ADSL'n til naboen min - NGT'n min mot Telenor.
Men catch har jeg ingen erfaringer med da :blush: , men kan i allfall si at jeg som oftest bare blir slått på ping av for med Bredbåndsfabrikken, Lyse, og en del med "feite" SHDSL da...
det som er litt merkelig er at jeg ringte telenor på fornebu å lurte på om de kunne pinge adressene.der lå de på rundt 500 til 550 i ping å de har ganske så bra utstyr i forhold til meg,mens her hjemme ligger jeg på rundt 150 til 160.har ngt.
lurer på om jeg skal bestille catch.de virker solide.
sigbjørn2 du er sinnsykt heldig :D
Endret av (ODIN)
ping 69.93.113.69 -c5
64 bytes from 69.93.113.69: icmp_seq=1 ttl=51 time=170 ms
64 bytes from 69.93.113.69: icmp_seq=2 ttl=51 time=168 ms
64 bytes from 69.93.113.69: icmp_seq=3 ttl=51 time=169 ms
64 bytes from 69.93.113.69: icmp_seq=4 ttl=51 time=169 ms
64 bytes from 69.93.113.69: icmp_seq=5 ttl=51 time=169 ms
5 packets transmitted, 5 received, 0% packet loss, time 4035ms
rtt min/avg/max/mdev = 168.842/169.338/170.258/0.613 ms
Lik hastighet på begge 2. Har Catch SDSL 2mBit
Nå er det jo hastigheten over atlantern som tar tid da...
:thumbup:
