zyrex Skrevet 29. november 2011 Rapporter Del Skrevet 29. november 2011 (endret) Kan du prøve en 'cat /proc/cpuinfo' i terminalen, så skal du få en del info om CPUen, også hvilken MHz den kjører på. Funker ikke, skal det være en "sudo" forran? Edit: Det funket ikke det heller Merkelig, skulle ha fungert. Se eksempel under: morten@oracle:~$ cat /proc/cpuinfo processor : 0 vendor_id : GenuineIntel cpu family : 6 model : 37 model name : Intel® Core™ i5 CPU 660 @ 3.33GHz stepping : 2 cpu MHz : 1200.000 ---SNIP--- Endret 29. november 2011 av zyrex Lenke til kommentar
-alias- Skrevet 29. november 2011 Rapporter Del Skrevet 29. november 2011 (endret) Det funker hos meg, men kun stock hastighet vises! processor : 9 vendor_id : GenuineIntel cpu family : 6 model : 44 model name : Intel® Core™ i7 CPU X 980 @ 3.33GHz stepping : 2 cpu MHz : 3334.000 cache size : 12288 KB physical id : 0 siblings : 12 core id : 8 cpu cores : 6 apicid : 17 initial apicid : 17 fpu : yes fpu_exception : yes cpuid level : 11 Hvorfor legges det samme ut gang på gang, her er hele loggen? vidar@LinuxRigg1:~$ cat /proc/cpuinfo processor : 0 vendor_id : GenuineIntel cpu family : 6 model : 44 model name : Intel® Core™ i7 CPU X 980 @ 3.33GHz stepping : 2 cpu MHz : 3334.000 cache size : 12288 KB physical id : 0 siblings : 12 core id : 0 cpu cores : 6 apicid : 0 initial apicid : 0 fpu : yes fpu_exception : yes cpuid level : 11 wp : yes flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm sse4_1 sse4_2 popcnt aes lahf_lm ida arat epb dts tpr_shadow vnmi flexpriority ept vpid bogomips : 5399.22 clflush size : 64 cache_alignment : 64 address sizes : 36 bits physical, 48 bits virtual power management: processor : 1 vendor_id : GenuineIntel cpu family : 6 model : 44 model name : Intel® Core™ i7 CPU X 980 @ 3.33GHz stepping : 2 cpu MHz : 3334.000 cache size : 12288 KB physical id : 0 siblings : 12 core id : 1 cpu cores : 6 apicid : 2 initial apicid : 2 fpu : yes fpu_exception : yes cpuid level : 11 wp : yes flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm sse4_1 sse4_2 popcnt aes lahf_lm ida arat epb dts tpr_shadow vnmi flexpriority ept vpid bogomips : 5399.93 clflush size : 64 cache_alignment : 64 address sizes : 36 bits physical, 48 bits virtual power management: processor : 2 vendor_id : GenuineIntel cpu family : 6 model : 44 model name : Intel® Core™ i7 CPU X 980 @ 3.33GHz stepping : 2 cpu MHz : 3334.000 cache size : 12288 KB physical id : 0 siblings : 12 core id : 2 cpu cores : 6 apicid : 4 initial apicid : 4 fpu : yes fpu_exception : yes cpuid level : 11 wp : yes flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm sse4_1 sse4_2 popcnt aes lahf_lm ida arat epb dts tpr_shadow vnmi flexpriority ept vpid bogomips : 5399.78 clflush size : 64 cache_alignment : 64 address sizes : 36 bits physical, 48 bits virtual power management: processor : 3 vendor_id : GenuineIntel cpu family : 6 model : 44 model name : Intel® Core™ i7 CPU X 980 @ 3.33GHz stepping : 2 cpu MHz : 3334.000 cache size : 12288 KB physical id : 0 siblings : 12 core id : 8 cpu cores : 6 apicid : 16 initial apicid : 16 fpu : yes fpu_exception : yes cpuid level : 11 wp : yes flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm sse4_1 sse4_2 popcnt aes lahf_lm ida arat epb dts tpr_shadow vnmi flexpriority ept vpid bogomips : 5399.81 clflush size : 64 cache_alignment : 64 address sizes : 36 bits physical, 48 bits virtual power management: processor : 4 vendor_id : GenuineIntel cpu family : 6 model : 44 model name : Intel® Core™ i7 CPU X 980 @ 3.33GHz stepping : 2 cpu MHz : 3334.000 cache size : 12288 KB physical id : 0 siblings : 12 core id : 9 cpu cores : 6 apicid : 18 initial apicid : 18 fpu : yes fpu_exception : yes cpuid level : 11 wp : yes flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm sse4_1 sse4_2 popcnt aes lahf_lm ida arat epb dts tpr_shadow vnmi flexpriority ept vpid bogomips : 5399.77 clflush size : 64 cache_alignment : 64 address sizes : 36 bits physical, 48 bits virtual power management: processor : 5 vendor_id : GenuineIntel cpu family : 6 model : 44 model name : Intel® Core™ i7 CPU X 980 @ 3.33GHz stepping : 2 cpu MHz : 3334.000 cache size : 12288 KB physical id : 0 siblings : 12 core id : 10 cpu cores : 6 apicid : 20 initial apicid : 20 fpu : yes fpu_exception : yes cpuid level : 11 wp : yes flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm sse4_1 sse4_2 popcnt aes lahf_lm ida arat epb dts tpr_shadow vnmi flexpriority ept vpid bogomips : 5399.86 clflush size : 64 cache_alignment : 64 address sizes : 36 bits physical, 48 bits virtual power management: processor : 6 vendor_id : GenuineIntel cpu family : 6 model : 44 model name : Intel® Core™ i7 CPU X 980 @ 3.33GHz stepping : 2 cpu MHz : 3334.000 cache size : 12288 KB physical id : 0 siblings : 12 core id : 0 cpu cores : 6 apicid : 1 initial apicid : 1 fpu : yes fpu_exception : yes cpuid level : 11 wp : yes flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm sse4_1 sse4_2 popcnt aes lahf_lm ida arat epb dts tpr_shadow vnmi flexpriority ept vpid bogomips : 5399.84 clflush size : 64 cache_alignment : 64 address sizes : 36 bits physical, 48 bits virtual power management: processor : 7 vendor_id : GenuineIntel cpu family : 6 model : 44 model name : Intel® Core™ i7 CPU X 980 @ 3.33GHz stepping : 2 cpu MHz : 3334.000 cache size : 12288 KB physical id : 0 siblings : 12 core id : 1 cpu cores : 6 apicid : 3 initial apicid : 3 fpu : yes fpu_exception : yes cpuid level : 11 wp : yes flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm sse4_1 sse4_2 popcnt aes lahf_lm ida arat epb dts tpr_shadow vnmi flexpriority ept vpid bogomips : 5399.84 clflush size : 64 cache_alignment : 64 address sizes : 36 bits physical, 48 bits virtual power management: processor : 8 vendor_id : GenuineIntel cpu family : 6 model : 44 model name : Intel® Core™ i7 CPU X 980 @ 3.33GHz stepping : 2 cpu MHz : 3334.000 cache size : 12288 KB physical id : 0 siblings : 12 core id : 2 cpu cores : 6 apicid : 5 initial apicid : 5 fpu : yes fpu_exception : yes cpuid level : 11 wp : yes flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm sse4_1 sse4_2 popcnt aes lahf_lm ida arat epb dts tpr_shadow vnmi flexpriority ept vpid bogomips : 5399.86 clflush size : 64 cache_alignment : 64 address sizes : 36 bits physical, 48 bits virtual power management: processor : 9 vendor_id : GenuineIntel cpu family : 6 model : 44 model name : Intel® Core™ i7 CPU X 980 @ 3.33GHz stepping : 2 cpu MHz : 3334.000 cache size : 12288 KB physical id : 0 siblings : 12 core id : 8 cpu cores : 6 apicid : 17 initial apicid : 17 fpu : yes fpu_exception : yes cpuid level : 11 wp : yes flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm sse4_1 sse4_2 popcnt aes lahf_lm ida arat epb dts tpr_shadow vnmi flexpriority ept vpid bogomips : 5399.81 clflush size : 64 cache_alignment : 64 address sizes : 36 bits physical, 48 bits virtual power management: processor : 10 vendor_id : GenuineIntel cpu family : 6 model : 44 model name : Intel® Core™ i7 CPU X 980 @ 3.33GHz stepping : 2 cpu MHz : 3334.000 cache size : 12288 KB physical id : 0 siblings : 12 core id : 9 cpu cores : 6 apicid : 19 initial apicid : 19 fpu : yes fpu_exception : yes cpuid level : 11 wp : yes flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm sse4_1 sse4_2 popcnt aes lahf_lm ida arat epb dts tpr_shadow vnmi flexpriority ept vpid bogomips : 5399.84 clflush size : 64 cache_alignment : 64 address sizes : 36 bits physical, 48 bits virtual power management: processor : 11 vendor_id : GenuineIntel cpu family : 6 model : 44 model name : Intel® Core™ i7 CPU X 980 @ 3.33GHz stepping : 2 cpu MHz : 3334.000 cache size : 12288 KB physical id : 0 siblings : 12 core id : 10 cpu cores : 6 apicid : 21 initial apicid : 21 fpu : yes fpu_exception : yes cpuid level : 11 wp : yes flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm sse4_1 sse4_2 popcnt aes lahf_lm ida arat epb dts tpr_shadow vnmi flexpriority ept vpid bogomips : 5399.84 clflush size : 64 cache_alignment : 64 address sizes : 36 bits physical, 48 bits virtual power management: vidar@LinuxRigg1:~$ Edit: Ok, glem det siste, altså en gang pr. core. Endret 29. november 2011 av -alias- Lenke til kommentar
Mydog Skrevet 29. november 2011 Rapporter Del Skrevet 29. november 2011 (endret) Dett får jeg: cruncher2@cruncher2:~$ cat/proc/cpuinfo bash: cat/proc/cpuinfo: No such file or directory Edit: Skal vel kansje være ett mellomrom etter "cat" Edit2: Fikk det til nå cruncher2@cruncher2:~$ cat /proc/cpuinfo processor : 0 vendor_id : GenuineIntel cpu family : 6 model : 42 model name : Intel® Core™ i7-2600K CPU @ 3.40GHz stepping : 7 cpu MHz : 3436.177 cache size : 8192 KB physical id : 0 siblings : 8 core id : 0 cpu cores : 4 apicid : 0 initial apicid : 0 fpu : yes fpu_exception : yes cpuid level : 13 wp : yes flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm sse4_1 sse4_2 popcnt aes xsave avx lahf_lm ida arat epb xsaveopt pln pts dts tpr_shadow vnmi flexpriority ept vpid bogomips : 6872.35 clflush size : 64 cache_alignment : 64 address sizes : 36 bits physical, 48 bits virtual power management: Men den forteller meg ikke om CPU er klokket altså faktisk MHz Endret 29. november 2011 av minhund Lenke til kommentar
zyrex Skrevet 29. november 2011 Rapporter Del Skrevet 29. november 2011 Hmm, den skal egentlig fortelle den faktiske farten, slik at dere ser at hvor mye dere har klokket. Hva med denne: sudo dmidecode|grep MHz (case sensitive) Lenke til kommentar
ei57 Skrevet 29. november 2011 Rapporter Del Skrevet 29. november 2011 (endret) Den var meget bedre! Edit. Inntil jeg testet på i7 2600k, der hang den ikke med. Endret 29. november 2011 av ei57 Lenke til kommentar
Mydog Skrevet 29. november 2011 Rapporter Del Skrevet 29. november 2011 (endret) Hva sier dette meg? At CPU kjører på 3,8GHz? Kan det stemme med TPF på 6903 på 58:32 min? External Clock: 100 MHz Max Speed: 3800 MHz Current Speed: 3458 MHz Speed: 1867 MHz (0.5 ns) Speed: 1867 MHz (0.5 ns) Endret 29. november 2011 av minhund Lenke til kommentar
zyrex Skrevet 29. november 2011 Rapporter Del Skrevet 29. november 2011 Vel, da har jeg prøvd Var ikke så lett å finne ut av dette i Linux, gitt. Lenke til kommentar
Mydog Skrevet 29. november 2011 Rapporter Del Skrevet 29. november 2011 Vel, da har jeg prøvd Var ikke så lett å finne ut av dette i Linux, gitt. Takk for hjelpen uansett Har skjønt at det ikke er så enkelt i Linux. Lenke til kommentar
avo Skrevet 30. november 2011 Rapporter Del Skrevet 30. november 2011 Ser av statestikken at det ligger et svensk lag foran HW Så - jeg kaster meg på noen måneder fremover med det jeg finner av CPU. Nå i dag - 1 stk Dell R810 med 4x E7 4870 1 stk HP Z800 med dual X5660 Senere i dag: 3 til av Z800 maskinene I løpet av en ukes til: Håper på 20 stk Z400 W3565 Må jo varme opp på kontoret likevel 1 Lenke til kommentar
ei57 Skrevet 30. november 2011 Rapporter Del Skrevet 30. november 2011 Sjekk at du har passkey, du må registrere deg og får den tilsendt på epost. Det vil mangedoble poengene dine og svenskene vil bli tatt igjen relativt fort. Lenke til kommentar
avo Skrevet 30. november 2011 Rapporter Del Skrevet 30. november 2011 Sjekk at du har passkey, du må registrere deg og får den tilsendt på epost. Det vil mangedoble poengene dine og svenskene vil bli tatt igjen relativt fort. Done! Lenke til kommentar
ei57 Skrevet 30. november 2011 Rapporter Del Skrevet 30. november 2011 Kjempebra, og for slaget mot svenskene, Linux er det mest effektive våpenet. Lenke til kommentar
Mydog Skrevet 30. november 2011 Rapporter Del Skrevet 30. november 2011 avo: Får du utnyttet alle tådene på maskinene nå? Lenke til kommentar
War Skrevet 30. november 2011 Rapporter Del Skrevet 30. november 2011 (endret) Har dere link på hvordan dere setter opp 2600K for mest poeng? Mine driver å surrer med småoppgaver og leverer inn 4000poengspakker Pos 1: 1 stk 270-WS-W555-ER Enhetspris NOK 4 933,00 ekskl.mva<br style="font-family: arial, sans-serif; font-size: 13px; "> CLASSIFIED SR-2 DUAL QPI S1366 NMS ML<br style="font-family: arial, sans-serif; font-size: 13px; "> Forventet leveringsdato: 09.12.2011 Flyttet igjen ^^ Endret 30. november 2011 av War Lenke til kommentar
-alias- Skrevet 30. november 2011 Rapporter Del Skrevet 30. november 2011 (endret) Ser av statestikken at det ligger et svensk lag foran HW Så - jeg kaster meg på noen måneder fremover med det jeg finner av CPU. Nå i dag - 1 stk Dell R810 med 4x E7 4870 1 stk HP Z800 med dual X5660 Senere i dag: 3 til av Z800 maskinene I løpet av en ukes til: Håper på 20 stk Z400 W3565 Må jo varme opp på kontoret likevel Dette er det mest fantastiske jeg har lest siden jeg begynte å folde, og når du får dette i gang vil du produsere nesten like mye poeng som vi andre til sammen. Å ta igjen svenskene blir en ekstra bonus. Endret 30. november 2011 av -alias- Lenke til kommentar
OEH Skrevet 30. november 2011 Rapporter Del Skrevet 30. november 2011 Sjekk at du har passkey, du må registrere deg og får den tilsendt på epost. Det vil mangedoble poengene dine og svenskene vil bli tatt igjen relativt fort. Done! Hei avo, har du mulighet til å legge opp ett skjermbilde fra Fahmon slik at vi kan få noe ordentlig porno å se på? -OEH Lenke til kommentar
avo Skrevet 30. november 2011 Rapporter Del Skrevet 30. november 2011 Får ikke mer enn 32 kjerner til å spille spesielt bra. Samme både med og uten HT. Men men - 32 kjerner funker også. Kjører 3 stk Dual X5660 å også. ... and it's more to come. Lenke til kommentar
-alias- Skrevet 30. november 2011 Rapporter Del Skrevet 30. november 2011 (endret) Standard smp 7148 med TPF på 56 sec gir en PPD på ca. 127K Endret 30. november 2011 av -alias- Lenke til kommentar
OEH Skrevet 30. november 2011 Rapporter Del Skrevet 30. november 2011 Standard smp 7148 med TPF på 56 sec gir en PPD på ca. 127K Er ikke det veldig lite poeng for en såpass kraftig rig? -OEH Lenke til kommentar
ei57 Skrevet 30. november 2011 Rapporter Del Skrevet 30. november 2011 Det er tross alt Windows og uten å fyre på alle sylindre. Et par WU'er til, så kan han prøve å legge til -bigadv, og da vil den jo nærme seg 200k. Linux og 6903/6904 ville mer enn doblet ppd, men det er kanskje ikke praktisk mulig. Lenke til kommentar
