Hva er galt her...
[13:14:18] Completed 495000 out of 500000 steps  (99%)
[13:19:06] Completed 500000 out of 500000 steps  (100%)
[13:19:08] DynamicWrapper: Finished Work Unit: sleep=10000
[13:19:18]
[13:19:18] Finished Work Unit:
[13:19:18] - Reading up to 3699936 from "work/wudata_02.trr": Read 3699936
[13:19:18] trr file hash check passed.
[13:19:18] edr file hash check passed.
[13:19:18] logfile size: 56766
[13:19:18] Leaving Run
[13:19:20] - Writing 3792662 bytes of core data to disk...
[13:19:20]   ... Done.
[13:19:22] - Shutting down core
[13:19:22]
[13:19:22] Folding@home Core Shutdown: FINISHED_UNIT
[13:19:25] CoreStatus = 64 (100)
[13:19:25] Sending work to server
[13:19:25] Project: 6050 (Run 0, Clone 87, Gen 484)
[13:19:25] + Attempting to send results [August 15 13:19:25 UTC]
[13:19:32] + Results successfully sent
[13:19:32] Thank you for your contribution to Folding@Home.
[13:19:32] + Number of Units Completed: 11
[13:19:36] Project: 6041 (Run 0, Clone 233, Gen 178)
[13:19:36] + Attempting to send results [August 15 13:19:36 UTC]
[01:50:03] - Couldn't send HTTP request to server
[01:50:03] + Could not connect to Work Server (results)
[01:50:03]     (171.64.65.54:8080)
[01:50:03] + Retrying using alternative port
[07:51:27] - Couldn't send HTTP request to server
[07:51:27] + Could not connect to Work Server (results)
[07:51:27]     (171.64.65.54:80)
[07:51:27] - Error: Could not transmit unit 01 (completed August 14) to work ser
ver.
[07:51:27] + Attempting to send results [August 16 07:51:27 UTC]
[07:51:48] - Couldn't send HTTP request to server
[07:51:48] + Could not connect to Work Server (results)
[07:51:48]     (171.67.108.25:8080)
[07:51:48] + Retrying using alternative port
[07:52:09] - Couldn't send HTTP request to server
[07:52:09] + Could not connect to Work Server (results)
[07:52:09]     (171.67.108.25:80)
[07:52:09]   Could not transmit unit 01 to Collection server; keeping in queue.
[07:52:09] - Preparing to get new work unit...
[07:52:09] Cleaning up work directory
[07:52:10] + Attempting to get work packet
[07:52:10] Passkey found
[07:52:10] - Connecting to assignment server
[07:52:10] - Successful: assigned to (171.64.65.54).
[07:52:10] + News From Folding@Home: Welcome to Folding@Home
[07:52:11] Loaded queue successfully.
[07:52:22] Project: 6041 (Run 0, Clone 233, Gen 178)
[07:52:22] + Attempting to send results [August 16 07:52:22 UTC]
Og sånn har den stått i en del timer nå...
Jeg vil anta at inni er de like, og de klokker sikkert også omtrent like langt. Da er det egentlig bare å velge den billigste. Du får jo også i7 970/980 til omtrent halve prisen og ytelsen er langt fra 50% dårligere.
Nå kommer vel snart SB-E også, og de vil vel gå i7 980/990x en høy gang.
Hvis 980 (uten X) kan klokkes så er jo den interessant, men kan den det i noen grad?
  Kjetil Lura skrev (På 19.8.2011 den 14.53):
Ville bare si at jeg nå har fått wu P7620 som gir meg 5187Poeng på gpu gtx 460 810/1620 =PPD 11011
Kan ikke huske P7620! Hva er PPD for denne?
Edit: Det er øynene man først blir blind på, PPD= 11011 står jo tydelig der ja.:hrm:
Hvilke brytere må man sette for å få ned denne, -advmethods ?
Endret av -alias-
Skruer av adv på alle mine 11 gpuer, med de nye wuene går strøm forbruket opp med veldig mye.
strømforbrukt går opp, fra ca 2270W til 2573W.
Time per rame ca 1.43 sek til 6.47 per frame, med 11 gpuer så øker jeg bare ppd med ca 8000PPD.
For lite TTF, varmen er det største problemet for meg, ikke gpuene. De funker meget bra.
  ei57 skrev (På 19.8.2011 den 16.31):
SB-E betyr vel ny plattform LGA 2011 og det er et dyrt (les dyrere) alternativ sammenlignet med 990X. Da kan jeg heller vente på Ivy brigde som man antar kommer på 1155 som jeg har et ekstra kort av.
Endret av -alias-
LGA2011 vil bli svindyrt det første året, ville heller gått for de billigste 980ene uten X til 4000,- eller holdt meg til 2600K på SB. Prismessig vil også IB bli en del dyrere enn SB en god stund og for opptil 20% høyere ytelse og marginalt lavere strømbruk spørs det om det lønner seg.
Endret av Theo343
Alias:
Jeg har skrudd av adv på mine gpuer. PÅ denne maskinen gikk strøm forbruket opp fra 360w til 425W(PPD er det samme)2x 460 + smp.
Så jeg kommer nok til å skrue av gpu foldingen når P76xx kommer.
Edit: måler 1 gikk fra 360W til 425W, måler 2 fra 290W til 345W, måler 3 fra 660W til 773W, måler 4 fra 800W til 950W.
Endret av Kjetil Lura
Nå har jeg endelig fått igang ett par av folderne igjen(980X og 970) kun cpu da :p
Regner med å ha en SR-2 maskin i gang med folding i løpet av uka og en til når jeg får SR-2 nr 2 tilbake fra RMA i Tyskland. Skal også ha opp 2 stk SB rigger om ikke så altfor lang tid må bare bli ferdig med klokkingen på de.:whistle:
Liten notis angående strømforbruk, kjørte SR-2 med 2 stk X5690 på LN2 her og på 5,5 GHz på CPUene så trakk riggen 800W under Vantage CPU-test.:ph34r:
Mine GTX560Ti kjører med 950 og yter mellom 13 - 15K avhengig av type WU. Ved de mest optimale WUene ligger PPD på 17 - 18K pr. kort. Nå bruker jeg ikke disse i folding lenger, men kjører kun med 3 x GTS450 og ett GTX275 for å komme opp på statistikken. Alle disse ligger mellom 8 - 9K i PPD hver. Ut over dette er det kun BigAdv som kjøres. Har lagt inn en ordre på en i7 980 og er spent på hva den kan klokkes til, men vil ta ut en i7 920 som selges når nevnte er på plass. Har også bestilt meg ny bærbar, en ASUS G74SX http://www.dustinhom...duct/5010601025 som erstatning for min noe slitne hp pavillion ze5425ea fra 2003. Denne kan jeg mest sannsynlig også folde på når den er ledig. Skal også ha meg ny stuePC som blir en av de eksisterende riggene som flytter opp fra underetasjen til høsten. Når statistikken er ajour med hensyn til egen produksjon vil jeg stoppe GPU-foldingen igjen siden den uansett er for kraftkrevende. Satser på at jeg klarer å tegne meg en gunstig kraftavtale før vinteren kommer, ned mot 30 øre pr. kwh hadde vært topp.
Edit: Jeg vurderer forresten seriøst å investere i en en vindmølle som kan produsere max 10KWh under optimale forhold, og så inngå avtale med den lokale kraftleverandøren om levering av kraft. Kort fortalt så kan man fritt montere slike på egen eiendom etter søknad og levere kraft til det lokale kraftnettet etter avtale. Investeringen vil beløpe seg til ca. 200.000 og kan produsere ca. 5KWh i snitt over året. Jeg eier sammen med mine søsken, ca. 1500 mål utmark som er egnet for formålet, men som sagt, det er ennå bare under vurdering. Får jeg dette til har jeg "gratis" kraft i overskuelig framtid.
Endret av -alias-
